Question about Casio Wave Ceptor WV57HA-1AV Wrist Watch
Cannot get time to set correctly. Hands off ~45min Wave Ceptor atomic watch set on home city CHI. Time is off an hr on screen and hands are off about 45min. Cannot get it set correctly.
    President:
  • 2,501 Answers
You should be able to set your "home"city to give you the correct time but if it is an hour out, then it may be giving DST when it shouldn't (or conversely not giving DST when it should).
You can also se the hand to agree with the digital clock. The instructions are too long to write here but if you haven't go the instructions, you can get them by going to the Casio web site.
Enter "casio.com", select "support", then watches, accept the termd snd then select "watch manual archive".
Read the required number off the back of your watch and enter it into the search box. Click on "search" to obtain your instructions.
Posted on Feb 01, 2010
I have a disallignement of 10 minutes between the digital and the analogical time. The digital time is perfect how can I allign the analogical one?
You have to know that analog time "follows" digital time.Any hour/minutes correction on the display has direct effect on time/minutes hands.Some times, mostly after battery replacement,hands might have declination.That is why there is a function so called "Hands home position adjustment".Using this function you can align both hands to 12/00 position.If there is any declination (I think is your case) you can correct.Try to enable this function by pressing for 4-5 sec the upper left button(A) until "HAND SET" appears.If hands are not aligned exactly to 12/00 position, you must correct by pressing the lower right button (D) for forward movement or the upper right button (B) for backward movement.In fact, minutes hand is aligned,hour hand follows.When both hands are set to 12/00 (home position) press button A again.Time Mode returns to the display.Normally hands will now show exactly according to digital (display) time.I hope this will help.
May 23, 2015 | Casio WVA105HDA Wave Ceptor watch
My son seems to have set his Casio Wave Ceptor wv 58u to the incorrect time ..god knows how !!..any Idea How we correct it !
You need to manually adjust or set the hands to the home position as they are not where the watch thinks they should be. This can happen when you bring your watch close to a strong magnetic field. Look in the manual to do this. Afterwards your watch should set to the correct time.
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you resolve your problem. thanks
Aug 17, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Hands won't sync up
It sounds like the time zone may be incorrect; check your manual to see if this can be the case. Also, these devices may wait until some time between midnight and 3 AM to synchronize with the 'atomic' standard. Make sure you have the watch near a window as this may aid reception depending on where you live.
Mar 14, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Changing the hand time only w/o changing the digital time
For Casio Waveceptor:
--- A
( ) Button Reference
--- B
Set in correct order:
1) Hand Home Position
2) Digital Time Set
1) Hand Home Position:
Press and hold A and B for 5 seconds, Press A to move Second Hand to 12: position: (if not there). Press B to enter Hour/Min set mode. Press A to move both hands to 12: position. Hold A to move hands fast, Press A again to stop hands. All 3 hands are now at 12' oclock.
Press B to exit Hand Home Position mode and enter Timekeeping Mode.
2) Digital Time Set: (hands will self set when done)
Press and hold B for 5 seconds to enter setting mode.
Press A to advance current item or scroll through choices. Press B to set item and advance to next item.
<Order of Items to Set>
GMT Differential -> Daylight Savings auto/on/off -> Seconds -> Hour -> Minutes -> Year -> Month -> Day -> Day of week language -> Auto receive -> (back to Timekeeping Mode).
<Setting each Item>
GMT Differential: Press A untill your time zone is reached (E=eastern, C=central, M=mountain, P=pacific). Press B to set (advances to next item).
Daylight Savings: Press A untill desired DST mode is reached: ("At" auto, "On" after spring change, "Of" after fall change) Press B to set (advances to next item).
Repeat to set: Seconds (resets to :00), Hour, Minutes, Year, Month, Day, Day of Week Language, and Auto Receive (on/off).
For each item, Press A to advance, and B to set.
Pressing B to set last item exits Setting Mode and enters Timekeeping Mode. Hands advance to current time.
Good luck,
Techjoel
May 10, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Casio Wave Captor Watch wont set to correct time.
Apr 21, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Battery replacement for casio wave ceptor wvq-200hu WATCH
Download abridged instructions from casio @ http://world.casio.com/wat/download/en/manual
Apr 05, 2009 | Casio Waveceptor Atomic Radio Controlled...
Time sets about 10 minutes off
put hands in "home position" as described on page 2 (bottom right) in manual here
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw4756.pdf
Once executed, may take hands several minutes to set
Jun 16, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Instructions for casio wave ceptor 4303
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Nov 06, 2007 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Casio Wave Ceptor WV57HA-1AV Wrist Watch Logo
253 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
