Question about Philips 32PFL5403D/27 32 in. LCD TV
The red standby light flashes constantly, we are unable to use set. We have been told to unplug all connection to the set, leave for one hour then restart, we have done this, ITS JUST THE SAME!!!!!!!!!!!!!! Advise please
  • 1,476 Answers
You have tried the first thing I would suggest. Next count the number of times the light flashes. It should flash in a pattern approximately one sec apart, then pause 3 seconds and start the same sequence over. The number of blinks will help narrow down the area of the problem. I suspect it is either in the HV section or the power supply. Have you had a power bump recently? Lightning strike? Anyone else in the neighborhood have trouble? Find out the additional information and get back to me and I will try to help you out.
hardrocko
Posted on Feb 01, 2010
I can't turn demo mode off or Standby from flashing on my Sony CMT-MX550i, can't turn unit off without unplugging it.
Sony CMT-MX550i -- I had good results by pressing the "TIMER MENU" button on the remote and simply setting the time. After that, no more demo.
Jan 16, 2013 | Sony CMTMX500i Desktop Micro System
Tv will not stay on standby timer light flashing
On Sony the standby or red is for shutdown---
If you unplug the set and plug it back and turn it on and it repeats this look to see if the light is either constantly blinking or blinking a specific number of blinks---specific number would be an error code.
Apr 29, 2012 | Televison & Video
The red standby light is flashing twice with a pause, then twice and a pause etc. There's no picture or sound and the light flashed whether we have the tv on or off. Any suggestions?
This blinking is a diagnostic code. Please update this with the model number. These sets contain circuitry that will shut the set down and display a code like this when a problem is detected. With the model number, I can look up the problem and provide potential repair suggestions.
Thanks,
Dan
Aug 20, 2009 | Televison & Video
Flashing red standby light
Take it down from its mount and try to restart it if this resolves the issue your mount is too tight on the back of the lcd monitor.. This happend to me as well good luck with your BRAVIA
Apr 22, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Apr 14, 2008 | LG 26LX1D 26 in. LCD HDTV
Toshiba TV, no power, red light flashing
Unplug the TV for 2 minutes and plug it back on.
It should work.
Feb 09, 2008 | Televison & Video
Wont come out of standby
The problem is most likely a defective lamp. See your owners manual on lamp replacement as this can be done by the consumer.
Dec 05, 2007 | LG RU-44SZ51D 44" Rear Projection...
Philips 32PFL5403D/27 32 in. LCD TV Logo
428 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
