Question about RTO Bernzomatic Brushed Nickel Patio Heater
What kind of propane cylinder do I need for a table top heater
    Top Expert:
  • 12,650 Answers
U use the same tank that fits a b.b.q. a 30 lb it fits in the bottom
Posted on Feb 01, 2010
Need a regulator for Thermos Grill 2 Go
I bought this to replace the regulator I lost for my Thermos Grill2Go. Little modification to the grill and it worked like a champ. Portable Propane Table Top Regulator 1 by 20 Female Throwaway Cylinder... need-regulator-thermos-grill-2-go-2i4ggwcr0e0sverpwaph0wvr-1-0.jpg
Aug 22, 2012 | Thermos Grill2Go Fire+Ice
Model JDS032 Tabe top Heater. No gas flow
Start with the cylinder, make sure you have plenty of fuel, if down to the last bit it can slow right down. Make sure it's propane (butane will not work in cold weather) and check for leaks. Found this site very useful patio heater problem solving, they have lots of help pages.
Sep 11, 2011 | Stainless Garden Sun Steel Propane Patio...
When I let go the pilot button and the flame is on the minute I let go to turn it to max it die down each time!! what is wrong?
If you are running on butane try switching to propane, on cold nights butane will slow down and go out. If using propane then the first consumable item that fails on a patio heater is a Thermcouple, this will cause the pilot to go out if worn. Found this site very useful with lots of Patio Heater Problem pages.
Aug 16, 2011 | Endless Summer Round Table Top Patio...
I have a gasmate table top heater. It lights but remains on low despite the position of the button.
Check the fuel, if using butnae on cold nights it will struggle to get to full power. Always run on propane on cold nights. If that does not fix it you may have a leak, see leakage testing.
Jun 18, 2011 | Stainless Steel Patio Heater
I have a RTA patio heater and on the box says it will work with LP or Propane but in the manual doesnt go into how to hook it or what needs to be done to LP connection can this be hooked into a home supply...
You didn't specify which model you have (Table Top or Tall Patio Heater). In any event, it doesn't matter, as LP and Propane are one in the same. However, it can not be converted to Natural Gas. Rita makes a separate Natural Gas model for that type of hookup.
Feb 10, 2011 | Rta International Patio Heater
Table top propane heater: tank freezes, fire goes out
I have a table top heater and was wondering why I have flame shooting out of the top of it when I should have like a blue flame, what can I do
Dec 14, 2009 | RTO Bernzomatic Brushed Nickel Patio...
Procom ML300TBA Heater: Liquid or Gas
Propane exist in a liquid state when it is under pressure in a propane cylinder. When the valve on the propane cylinder the pressure on the liquid is reduced and the propane reverts back to gas state.
Also, regarding the tank you need....
the owners manual probably states what size you will need but, with most heater like the one you have it will require a 100 lb tank (approximately 25 gallons). You will also need an inline regulator set to 11" to 14" of water column between the tank and the heater.
Jan 09, 2009 | Procom ML300TBA Heater
Endless Summer Patio Heaters won't stay lit
Hi ColdinSF,
You need to remove the covers from the unit and blow out the gas lines with compressed air. If you can remove the gas lines blow out the lines and what they connect to like the pilot light and main feed line to the burner. Usually they gunk up with use and just need to be blown out with compressed air to clear the lines again. Maybe you have some dirt or foreign object from your gas tank which has clogged the line. Also check the igniter electric lines as well and make sure everything is connected properly. Especially make sure you tighten the gas lines you remove. Hope this helps.
Regards
Bryan
Oct 19, 2007 | Endless Summer gwt501a Open Flame Patio...
RTO Bernzomatic Brushed Nickel Patio Heater Logo
50 people viewed this question
Top RTO Pool & Spa Experts
john h
Jay Finke
Jay Finke
Ian Kime
Ian Kime
Are you a RTO Pool and Spa Expert? Answer questions, earn points and help others
