Question about Motorola Mobility RAZR V3
Icon when there is an incoming call- it shows that icon that looks like a zero with a line throught it (like a stop smoking sign almost) on my front display screen-what is it? what does it mean?
Provide me with some more information
Posted on Feb 21, 2008
Where can engine oil enter the engine
what color is the smoke has it got a blue tinge to it if so its the oil ring if its just loads of smoke the other possibility valve oil seal the spark plug seal which is in the rocker box or valve cover this stops oil seaping throught the plugs into piston you could get a compresion test to see if its a cylinder seal
Apr 26, 2014 | 1999 Mercedes-Benz E-Class
Kia sedona emmits white smoke with brownish oil dripping at the exhaust .is it from head gasket or someparts in the engine?
head gasket yes, bc antifreeze is entering throught the oil ports or down throught the rings, if the water get to the oil it will wipe your bearing out
Jan 08, 2013 | Cars & Trucks
Tractor will not start unless you poor gas into the carburetor. When it dose start it let out a small cloud of white smoke I have changed the fuel filter,spark plug & air filters on the tractor. It has...
It sounds as if your carb. needs cleaned, the fuel line is obstructed or the fuel filter is stopped up. All of these will prevent fuel from moving throught the carb. to the engine.
Jul 10, 2011 | John Deere Garden
Stalls out when stopped for red lights stop signs, and also when you are slowing down. Sometimes won't start back again when it does stall until you crank it several times, then you smell gas and black...
You have a bad fule pressure regulator to check to see if this is the problem look on your fule rail and you will see a round piece that has a vaccume line on it start car and un plug the line if gas is comming out of the regulator its bad. it floods the motor with gas it drives ok because you are hitting the gas and it allows more air in to compensate for the xtra fule, but once you let off gas its flooding out. Thats why you smell it and all the black smoke. hope this helps.
Mar 16, 2011 | 1998 Jeep Cherokee
I am going to see one of these bikes today, However dont much about bikes. What do i need to look for when i see it, to check if it is a good bike? . He says it is in excellent condition and for...
-Look at the wheel alignement at the back and see if front and back wheel are in a straight line.
-Check the steering and look for any sign of bent on the forks.
-Start the bike and observe how it idles.
-Revs the bike and look for any sign of misfire or engine cut off.
-Apply brakes to front and rear and observe if it goes down more than necessary,which could be either signs of brake pads or air in the brake the fluid system.
-Check all road legals issues, like tyres,horn, indicators,horn etc.
-Check the mileage and work out if it is genuine.
-Test the bike and observe if there is any sign that the steering pulls to one side and also when braking.
-If you could, then do a compression test to see if there is any sign of damage to barrel or piston or rings.
Hope these helps.
Dec 13, 2009 | 1991 Yamaha FZR 250 R
Norstar 7324-two lines show in use, but wont hang up
Power cycle the system. You need to go into lines/trunks and change the line typ from unsupervised to supervised so this will stop.
May 26, 2009 | NorStar M7324 Telephone
Smoke near the passanger front wheel
pull off the tire and remove the rotor. clean the bearings with carb cleaner and look to see if they have signs of heat stress(dark blue/purple disscolorations) if so replace both inner and outer bearings. also look for the same discoloration on the rotor. If it has the color, your brake caliper is hanging up. It also may of been something as simple as blown grass od weeds caught in the rotor and burned off when it got hot, thus the reason you havent see it since.
May 23, 2009 | 1994 Nissan Quest
Incoming messages alert tones
first of all open menu of your phone then tap on setup(the one with screw driver on it) icon to open it then select ring alert style and select your alert style you will see a bottun bellow displaying "EDIT" tap on it then a menu will apear with volume level, Ringtone line 1, Ringtone line 2, Massage tone....
you can edit all of them by taping on the folder type icon flashing in front of them......!!!!!
I think it will help you...if not then reply me at ik1788@gmail.com
Feb 02, 2009 | Motorola Mobility MING A1200
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
