Question about Sharp AR-BC320 All-In-One Led Printer
Sharp AR BC320 not printing correct colors
Our Sharp AR BC 320 is not printing correct colors (gray is printing blue) and yellow streaks are printing on black and white pages, and lastly, all colors especiallys blue and any light colors are streaky. Very dark blue and Very dark green are fine. The dealer cannot find the problem and has replaced every part (literally). He states that it is our software and/or saturations that need to be adjusted. We've had the copier for 9 months without a problem until now. We just learned this copier model was discontinued. Do you know why is was discontinued and what may be causing these problems?
  • 1 more comment
  • Sdaniele Feb 19, 2008
    This may be a duplicate submission - sorry if it is. The test page prints so so. Because it's a small area, it's not as noticeable as the actual color pages we print that have large color areas (brochures, etc). The print heads have been cleaned 3x in the last 10 days.
  • Sdaniele Feb 29, 2008
    Thqnk you. I will give this information to the dealer. They have taken the copier back and given us a loaner until they can fix it. We have not heard anything from them.
    Problem Solver:
  • 7 Answers
I am having a similar problem, except that all pages are printing yellow on the bottom half. I have cleaned out the extra toner out of the slot for the yellow, and wiped down the areas that were suggested by our technician. We still have the same problem and it seems to go away after cleaning for a few prints then it comes right back. I was thinking that this may be a toner cartridge issue. Any ideas? I have updated the drivers and the software, there have been no problems with this unit until we had a large amount of yellow printed on a newsletter.HELP!
Posted on Aug 27, 2008
    Scholar:
  • 67 Answers
First of all, this copier doen't have print heads that spray ink like an inkjet. Its print heads (4, one for each color) are LED arrays, all they do is emit light. They can get dirty, but not clogged with ink.
Suggestion: Make a color copy at the copier, then print a color picture from a workstation. If the copied page looks good and the printed one doesn't, the copier is probably OK. Reinstall the print driver. I suggest you download the latest driver just for effect.
This worked for me at a customers site just today.
Posted on Feb 28, 2008
  • AL Arena Feb 28, 2008
    dqwefqafqdf
    Genius:
  • 3,587 Answers
Sounds a lot like the print heads are clogged. Can you print a test page, and how does that come out?
Posted on Feb 19, 2008
I use my Sharp AR-BC320 as a network printer, how do I set the print mode to default black & white. It is currently set to always print color. I have searched the manual and is says nothing about print...
On the Print Window.
1. Click on the Properties button.
2. Click the Color Tab and Choose the "Print in Grayscale" option and Select "Black ink only"
3. Click the Printing Shortcuts Tab. Click the "Save As" button and assign a shortcut name you can remember.
4. Then click "OK". and print.
5. The next time you print a document just look for that in the printing shortcuts.
Mar 18, 2011 | Sharp AR-BC320 All-In-One Led Printer
I have a sharp ar-bc 260 have perfect black lines on copies only copy mode print mode is fine
Clean all your glass including the thin strip on the left side that handles scanning for the doc feeder. Run copies both off the glass and the doc feeder. If the line is still there then take off the glass, dust the inside scan cavity and dust your 3 mirrors with a new, lint free rag. Make sure your glass is completely clean before you put it back on.
Jan 17, 2011 | Sharp AR-BC320 All-In-One Led Printer
Just replaced cartriges and there is a streak
The print software should have a clean option for the printer, try and run the clean 2 times and see if this does the trick.
Feb 04, 2010 | Sharp AR-BC320 All-In-One Led Printer
Printing from a mac OSX.5.8 to a Sharp copier AR BC320?
You will need to purchase the Post Script Driver for that model. Sharp Copiers require a product key code to enable post script on their copiers. A sharp dealership will have to sell it to you as well as to get the product key code for the postscript driver.
Dec 10, 2009 | Sharp AR-BC320 All-In-One Led Printer
I am trying to find bulk toner for a sharp ar-bc320 I have been only able to find universal toner for other ar sharp models are they compatable?
The AR-C26TxU toner cartridges are only made for the AR-C260, AR-BC260, and AR-BC320. The cartridges are unique for these models in that they are the only ones in Sharp's entire color cartridge line that contain both toner and developer. I'm afraid you're going to be stuck with OEM in this instance, sorry.
Jul 17, 2009 | Sharp Office Equipment & Supplies
SOLID BLACK LINE FROM LEAD EDGE TO TRAIL EDGE
"dk" means the the life black drum is over. You need to replaced the drum and blade. Or you can replaced the whole drum cartridge. The line that you are getting from one of the blades, more likely from the black drum. Pull out all the drum check if there is toner on the drums.
Mar 20, 2009 | Sharp AR-BC320 All-In-One Led Printer
Sharp AR-BC320 Scanner Setup
login to the copiers web interface (the ip address of the printer ex: 192.168.XX.XX) you will see Network Scanning. Here you can change all the scanning e-mail options.
Aug 11, 2008 | Sharp AR-BC320 All-In-One Led Printer
Manual for Sharp AR-BC 320 All in one copier
http://www.sharpusa.com/files/cop_man_ARBC320.pdf
Aug 05, 2008 | Sharp AR-BC320 All-In-One Led Printer
Sharp AR-BC320 All-In-One Led Printer Logo
191 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
