Question about Casio PAW1500T-7V Atomic Solar Pathfinder Watch
The barometric pressure is incorrect - Casio PAW1500T-7V Atomic Solar Pathfinder Watch
  • 906 Answers
Good day,
hope this link below will solve your problem.
watches
Posted on Jul 30, 2010
Need shell/bezel
Either send to Casio or get new watch. I go with the latter
Sep 22, 2012 | Casio Pathfinder PAG40B-2V wristwatch
I calibrated my Timex WS4 using a known barometric pressure and set the weather conditions but the watch is telling me I'm at an altitude of -42 meters (which I'm not) and the temperature is at least 10...
You should carefully read the manual on this watch. It is a very sophisticated instrument realitive to its cost.
The barometric pressure in the CAL mode is set to the reference sea level. The pressure that is read in the other areas is the actual or relative pressure at your location.
There are some tollerences for the accuracy of these watches. What they are excellent at is seeing the relative differences or changes. I found that when I set the reference barometric pressure (Sea Level Pressure), everything falls in to place. I found the WP4 to be accurate to within about 15 to 20 feet accuracy for altitude most of the time. It is important to periodically check the barometric pressure from the weather office if you want it to be as accurate as possible.
When hiking or out trecking, it is advisable to check the watch's altitude relative to the map that you are using, or to a known reference. Then as you travel you can check for the altitude change.
Take care that this type of watch is to be used as a quick or easy reference only. It is not certified to be used in situations where life and safety are fully dependent on the readings from this type of watch. It is a precision instrument, but not as precise as the high end professional certified types. It is best to refer to proper maps (charts), and depend on a certified mechanical compass for absolute reference.
Jerry G.
Apr 04, 2011 | Timex Expedition WS4 WideScreen 4...
The ascent reading seems to be very inaccurate and the battery shows low after only a couple rides after installing a new battery. Anyone have a solution for the acent issue?
You need to send the watch into Suunto for service. The watch is obviously having an issue if it will not hold charge with a new battery and the Altimeter is not working correctly.
The Altimeters are Barometric pressure related and occasionally something goes wrong.
My experience is that Suunto is very good about fixing and/ or replacing when this issue arises.
Jan 24, 2011 | Suunto T6c Heart Rate Monitor and Fitness...
When using the barometer or altimeter on my my pag 40 - 2271 it shows err. How do I fix it? Do you know what page in the users guide shows how or gives directions on how to fix?
Same problem with my SPF-40, module 2273, after a small helical compression spring, silver color, fell out. I could not determine where it is suppose to be located. It could be the barometric reference spring for sensing the barometric pressure.
Nov 18, 2010 | Casio PRG-40T-7 Pathfinder
How does the altimeter function work? we can't find it on the enclosed instructions
Altimeters on watches are usually based on barometric pressure, since the pressure changes all the time you generally need to adjust the altimeter to a known altitude. You can look on USGS website to find the altitude of your area, or simply type in "altitude of city, state" in a search engine.
I hope I understood your question; if not, please reply.
Oct 17, 2009 | Timex Adventure Tech Altimeter 41501 Wrist...
Altimeter setting creeps up on Suunto Vector
It sounds like IC (integrated Circuit) in your watch is mulfunctioning, but can be something else. Can't say without inspection.None of the readings mentioned by you is acceptable.
As the watch is purely microelectronic, there is nothing you can do but to take it back to the retailer and ask for repair or replacement. If your watch is just 10 days old, this must be done under warranty and at no cost to you.
Don't forget to rate, please.
Jan 05, 2009 | Suunto Vector Wristwatch
Alti does not read correct alti.
Don't forget that the altimeter is barometric, and therefore the altitude reading will change depending on the air pressure - i.e. the weatherman may give the 'high pressure coming through' or that there is a low pressure giving rain - to get the true altitude, you need to know the true air pressure at any given point on the earth ~(where you are) then set this as the 'normal'. you will then get the correct altitude. Don't forget that if you are in a pressurised aircraft - as in allcommercial flights, the cabin air pressure is artificially kept at appx 4000-6000ft altitude
Dec 02, 2008 | Casio PRG-40T-7 Pathfinder
Incorrect altitude changes
Here is the link to the user manual for this watch if you need it; http://www.lacrossetechnology.com/k2100/manual.pdf page 12 gives you all the contact details for lacrosse. I couldnt find the info online to be sure, but some of these watches do have a separate pressure sensor for altitude and barometric pressure, and sometimes the path to one could get blocked or it could become faulty. I would contact la crosse and find a dealer to get the watch serviced, you could probably do it yourself but you need to get replacement seals from them anyway (these are important). ask them to check if the sensor is clogged, it happens sometimes. Hope this helps :)
Jun 18, 2006 | La Crosse K2-100 Wrist Watch
Casio PAW1500T-7V Atomic Solar Pathfinder Watch Logo
70 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
