Question about Husqvarna Chain Saw 20" Bar
Runs like it is flooded. Good fuel, good plug.
  • lindsay836
    lindsay836 May 11, 2010
    May need a carb kit. I will state the obvious.... what is the fuel mix you are using ?
    I beleive Husky recommends 40:1
    If that is ok there is a little air fuel mix on carb, try setting that.
  • dontbother10
    dontbother10 May 11, 2010
    What does a flooded engine run like? At Idle? At full throttle? Did you adjust something? Change elevation? Change fuel mix? Did you try cleaning the spark arrester (muffler)?
    President:
  • 2,220 Answers
No response to clarification.
Posted on Feb 09, 2010
1988 jeep Cherokee Laredo won't start turns over ,has spark, gets fuel
no engine size stated, (so i toss coin, 4.0L) 5miilion strong.
the 1988 is the gawd awful French RENIX fuel injection.
i owned 2 of these pigs. (sure it runs) but sux.
why?, no CEL lamps , no flash codes, no OBD1 , no OBD ! anything.
only the very old and rare factory and dealer tools can scan this pig.
lets do this better?
in vivid details.
NO start 101: (order matters too)
  1. compression at spec, on all 6 cylinders? (old engines do die)
  2. spark at all 6 spark plugs good,? not just 1.
  3. car is tuned up. spark plugs.cap rotor, wires, and filters?
  4. the ign timing light on #1 wire, shows spark landing near TDC 0 degrees or under hood stated spec. (open hood look up )
  5. i now check for flooding, is it? spark tips , TALK to me.?
  6. yes, then check fuel pressure. next.
  7. no, then are they dry, you said wet. ('gets fuel means what"?)
  8. if flooding, i unplug the fuel pump relay and start car with test fuel if it runs for 3 seconds and stops, that is a PASS condition so but if not 1, to 7 above was skipped. lets say its flooding
  9. if flooding did you try cranking per opr guide wide open throttle? this CUTS all fuel and clears all flooding on all gas engines. and for sure all EFI. gas engines.
  10. my guess is its running now. right? if here?
  11. if not, check fuel pressure per the fsm cranking, and the MAP sensor. out put voltage key on, and cranking. and post that.
  12. good luck.
get the engine to run on test fuel first. this saves big time labor
down time, and wasted parts , guessed at)
doing a real tuneup , is not ever a waste.
a tuned up engine pays back in lower gas costs. big time.
fuel is expensive.
Sep 28, 2014 | Jeep Cherokee Cars & Trucks
2006 liberty cranks but wont start
gas engine, not diesel.
its probably flooding, ever give it a 60k mile tune up, ever?
we check spark tips for flooding and dry,never do we guess at fuel pumps, ever. (pressure gauge is $20)
tips dry or soaking wet.
we check for spark , no gas engine car runs with no spark
so we check all cylinders for good spark
if spark is good and flooding (new spark plugs) we use
cranking wide open throttle wot. like the operators guide says.
start now? this cuts all injection, this magic PCM trick.
see scotty ,
1: compresson at spec, 2: spark good and timed. and 3: fueling last.
skip the silly ad.
note he says 2, but he ASSUMES compression is good. (oops)
but his tests are fast, and if it fails to start, see #1 above. ask
http://www.youtube.com/watch?v=064Ilsz8Fzg&NR=1&feature=fvwp
Feb 27, 2014 | 2006 Jeep Liberty
Suzuki Aerio 2004, will crank over floods out tho. Changed Plugs and Boots. New baterry too. Can smell gas @ Tail pipe. Wants to fire-but just won't catch. Where do I start looking for the answers.?
what engine? 2.3 or 2.5L?
all cylinders flooding??? spark tips on ALL dripping in gas?
check spark at all spark plugs ( ALL not just ONE)
if spark is good.
this engine is chain cam, so it makes huge noise before death.
did it?, nah
ok, so connect any $9 scan tool, and scan it. (barrow /rent.?)
you crank it for 5 seconds, not less.
and as you crank the scan tool RPM shows 250 to300 rpm and fails to start, the RPM on the tool shows you that the crank sensor is working
now release the key and do not turn off
look for DTC errors. got P0340,355? or any other DTC
that decodes to bad CMP or CKP/
yes, BINGO, the scan tool told you why spark is dead, or way off
timing,
the PCM will report Cmp or CKP errors even 1 in 6 pulses.
the PCM runs monitors against these 2 full time. and will see it fail.
and report, it, let it tell why spark is bad.
say spark is good. and still floods.
1: engine compresssion over 150psi? W.O.T?
2: flooding , i pull the fuel pump relay and crank now.
starts and runs for 3 -5 seconds, yes, that is the flood clearing
so i then try test fuel, runs perfect now (no fuel pump) ???
runs for 3 second, each test fuel usage. well good motor, good spark.
what more do you want? sure to run
so you have either insane high fuel pressure. or injectors leaking
can and does happen.
the tests are all in the FSM under injector and pump testing.
i check fuel pressure first. as its a mandatory thing.....
to factory spec. for unsaid engine.
then i do a injector leak down and balance check.
ask if you get this far.....????
Jan 24, 2014 | 2004 Suzuki Aerio
Suzuki vitara v6 will not start but engine check light comes on and i also changed the ecu
wow, you did it backwards, $$$$$$$$$$$$$$$$$$$$$
ever do the op guide lilsted tune ups at 60k intervals? miles>? if not why not?
did you try op guide stated WOT test, crank WOT, wide open throttle.
starts now (well it was flooded1) nothing, well, it's below.
watch scotty.
fuses good. battery at 12v not 10v. , fresh fuel, not 3 years old.
key on CEL glows.
cranks engine, cranks robustly.
you then check for spark. on all 6 COP coils. MUST WORK.
iS spark good or bad. .? ( all gas engines. not diesel)
good spark , yes,. try test fuel. (sold in stores,,,,,, in a spray can)
if test fuel runs good for:
no spark , attach any cheap scan tool, and crank for 5 sec.
http://www.fixkick.com/IGN_timing/no-spark.html#Cops
release key (not off) and see if P0340 or P0355 or close are thrown
YES, bingo and make sure RPM shows at near 300 cranking
if not, the CKP is dead.
A: 3 seconds each try, then the engine is good and so is spark if it sounds really good,..
B starts and runs, must have been flooded or no tune up ever.
C: starts and floods, again, and stalls, trouble shoot flooding.
D: Dead as a door nail. that means its:
1: bad engine, (compression way below 170psi)
2: or lost fueling. check spark tips , wet, is flooding or no spark.'
2a: or low fuel pressure, use a fuel pressure gauge.
0 or 2 psi bad, 20 bad, 30 good, 60 bad. 60 it floods. below 30 it starves. the FSM covers all pump tests, there are 6 tests.
there is also an injector balance test, if fails, the injector is dead or leaks all the time and floods a cylinder.
is this good, ?????
if not do you just want a simple guess?
ok my wild useless guess.
1: not ever tuned up;. "know today as, doing the service points''
Nov 24, 2013 | 2003 Suzuki Grand Vitara
I have a 2004 4 Runner. I've got 210k miles and it runs great however in the morning I'll drive to work (35 miles in traffic). Runs fine. At lunch I'll start and it runs rough like it misses or...
Hi Brian,
The airflow sensor is working with temperature. If there is a problem the car will flud with fuel. I suggest that you change this senror.
Good luck..
Aug 06, 2013 | Toyota 4Runner Cars & Trucks
'83 virago xv500k starts right up, runs solid, but
the fuel tap may be causing to problem, if it doesnt turn off it can also flood the engine over night and allow fuel into the sump which then vaporises as it gets hot and the breather allows this fuel back through the air cleaner causing rich mixture
May 07, 2011 | Yamaha yZFR125 Motorcycles
Fuel pump issue, gradual flooding
NEED TO QUIT GUESSING.. IS THE CHECK ENGINE LIGHT ON.. SCAN FOR CODES. IF NONE THEN NEXT STEP IS TO CHECK FUEL PRESSURE.. IF IT IS GOOD.. THEN IF IT IS FLOODING OUT. ONCE IT IS FLOODED YOU CAN PULL SPARK PLUGS AND FIND THE ONE THAT IS WET,,, SUSPECT THAT INJECTOR TO BE STUCK OPEN
Nov 29, 2009 | 1988 Isuzu Pickup 2WD
1993 Previa. Fuel floods the cylinders after long drive & parked
try running an injector cleaner thru the system.
you may have a dripy injector.
Nov 10, 2009 | 1993 Toyota Previa
Husqvarna Chain Saw 20" Bar Logo
46 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
