Question about Nintendo Legend of Zelda: Four Swords for GameCube
Link keeps getting stuck walking into a wall how do i fix this
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 34 Answers
Make sure all connecting plugs & wires are unplugged then plug them in tightly again, clean the disc, if you've used it a lot and it has wear & tear that could be an issue.Glitches happen sometimes and resetting things seems to work.
Posted on Feb 06, 2010
4A Slow Blow Fuse keeps blowing in my Prestige Triangle Tube 110 Solo LP with U125
Jack,
I just got mine fixed, so can for sure try to help you.
Something on the low voltage side is misbehaving. I can walk you through narrowing it down if necessary, but it's most likely the blower motor.
Here is how you can confirm. Unplug the wiring harness or harnesses at the top of the blower motor. The plastic can be brittle, so be gently. This will remove the blower from the equation. Then, start up the boiler. Did a new fuse blow? If not, it's the blower motor.
If there is a tube attached to the blower intake, remove it. Then stick a screwdriver into the small hole where the air sucks in. Try to rotate the fan. Is it stuck? Does it spin freely? You might be able to free it and get heat for a while, but you will probably need a new blower kit if it's noisy or stuck.
Post back if you need more help.
- Paul
Feb 22, 2015 | Honeywell Triangle Tube Prestige Solo 110...
Hello, I've got a 80 series Kenmore top loading washer. I recently had to replace its dogs due to agitation issues (problem fixed) but now not but 2 months later the "washer drum" (?) is hitting...
This is likely the washer wear pads. They are inexpensive and fairly easy to replace. Here is a video that will walk you thru it Washer wear pad replacement Now before fully disassembling check the tub springs and counter weight spring. Sometimes they break or rust out. If they look good then move on to the wear pads.
Feb 07, 2011 | Kenmore Washing Machines
I HAVE A ELITE WITH A STUCK DRAWER HOW DO I FIX
The link below will walk you through the warranty approved steps to fix your stuck cd door.
http://support.microsoft.com/kb/906936
Aug 03, 2010 | Microsoft Xbox 360 Elite Console
Oven not working f7 light on
F7 indicates a stuck button or the ERC needs replacing. This link should walk you thru testing and replacing the problem
http://appliancehelponline.com/ovenerc.html
Jun 28, 2010 | GE 24" Built-In Single Gas Wall Oven
Stuck in a pokecenter wall
Delete your save file and start over again. Press Up+B+Select on the title screen and press Yes. Or you could use a Walk Through Walls code (with GameShark, if you have one) to get yourself out of there.
May 15, 2010 | Nintendo Pokemon Red
Pokemon pearl wont work after using action replay
try to use th action replay walk trough walls cheat to get out it ussally works or if you've already tried this then I am sorry but you may have to delete your game file and start a new one.
If this doesn't help sorry but can you still rate this please. Xamous
May 29, 2009 | Nintendo Pokemon Pearl Version for DS
Cant get off the 1st level world 6 please helppppppppppppp
just go straight ,hang and hand to hand on cliff sides at half way drop down at cannon wall and follow the coins you have to run, jump against the wall and push off with kick to get to higher ledge i hope this helps
Mar 16, 2009 | Nintendo New Super Mario Bros. for DS
Enchanted climbing level help
I have made to the second climbing level but can't get rid of the giant monster.... It killed me 3 times................... For the first climbing level you have to go where the angry mushroom is and make Gisele walk between the wall and the small vine fence, The best way to do it is to make Gisele follow the wall by going against it. the rest is pretty easy just follow the instructions.( It's the wall on the right)
Apr 03, 2008 | Nintendo DS Console
Nintendo Legend of Zelda: Four Swords for GameCube Logo
73 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
