Question about InFocus Projector Lamp for IN24+, IN26+
Lamp replacement issue infocus in24+
Powers up with fan on for 1-2 seconds...then the red lamp light warning symbol lights up right by the green power light and the fan goes off
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
Either the lamp's seams aren't taped over with foil tape to prevent the premature shutdown due to the heat sensors being triggered, or the fan under the the colorwheel has stopped, maybe due to a piece of lamp from a previous lamp explosion being stuck in it, or the power supply/ballast is bad, or the eca on the engine itself is bad. The lamp is the easiest to try first. There should be foil tape over the seam on the side of the lamp you can't see when it is installed. If this doesn't work, take the front bezel off amd get where you can see the fan under the colorwheel and tunnel and power the unit up and see if the fan comes on. If it does thenthe eca on the engine or the power supply ballast is most likely bad and these are major repairs.
Posted on May 04, 2010
INFOCUS Lamp replacement
chances are its the projector itself that you are having an issue with, one more thing that you can do is for you to clean the filters, try cleaning the filters and try reinstalling the lamp, then power it back on, if you are getting the same thing still, have the projector service or if within warranty have it replaced. best i got. Thanks for using Fixya!
Jul 01, 2008 | InFocus X1 Multimedia Projector
Infocus projector powers on the green light
Hi I am Vortash check in your user manual this may be the signal to tell you that the projector is telling you that the number of hours for your bulb is up ( or indeed the bulb may have blown but this usually shows a red light if so ) if the bulb life monitior is at it's extent it wont let the light opperate and you have to reset the lamp hours you can find out how to do this in the manual under replacement bulbs .. if you have no manual you may be able to download one from off the net .from the manufactures support site .alternately you may have a ballast problem and it requires an engineer to sort it out . regards Vortash
Mar 30, 2010 | InFocus IN24 Multimedia Projector
InFocus ScreenPlay 4805 no projection. Unit powers on and green light blinks, but no light and no fan, eventually red light blinks continuously about 2 seconds between blinks. When the green light is...
the high-pitched sound is the colorwheel trying to spin up to speed. that may need to be replaced. check the inside of the lamp for bulges, black spots, fogging or flaking. if it has any of those, replace the lamp. you can get parts from an infocus service center or send it to them for repair. either way, try www.avsolutionsny.com they're really good. if you want to replace it yourself, there is a detailed step-by-step on my "tips" area. it's the same as the infocus x1, x2, x3 and sp4805. click on my picture and scroll down to tips. good luck!
Feb 01, 2010 | InFocus ScreenPlay 4805 Multimedia...
Wont light up
the colorwheel needs replacing. if the colorwheel won't spin, the lamp won't light. if you hear a high-pitched whir, the colorwheel works, which means there is a power supply issue. there is a fix for that, but you have to be good at soldering. if you are give it a try: http://www.infocus.com/service/asc/communications/tech_notes/2006/09/tn495g.pdf
Oct 05, 2009 | InFocus LP70+ Multimedia Projector
Projector shuts off within 30 seconds of power on
is the led lit on the top of the projector? what colors?
green is ok.
red flashing in sequence:
2 times- lamp hours exceed 200 hrs. replace lamp.
3 times- lamp failure. replace lamp.
4 times- fans not working. remove obstruction or replace fan.
5 times- temp too high. clean thoroughly.
solid red- undiagnosed error by projector. possible power supply or ballast.
also make sure the lamp door switch is working.
Aug 07, 2009 | InFocus LP 820 Multimedia Projector
Infocus IN24 lamp not lighting up
MAKE SURE BLUB WIRING IS THE SAME AS OLD BLUB, IN24 AND IN24+ WIRING IS DIFFERENT IN CONNECTOR.
Mar 20, 2009 | InFocus Projector Lamp for IN24+, IN26+
Infocus lamp not firing
more then likely the ballast has gone bad and the lamp is not getting the right voltage to fire. Only other thing you can do is remove the lamp the turn the power on and check the voltage at the connector. This will not check the triggering voltage mine you only the lower operating voltage. But since you have replace the bulb with a known good one I'm betting on the ballast is bad.
Dec 08, 2008 | InFocus Replacement Lamp Projector Lamp...
InFocus  Projector Lamp for IN24+, IN26+ Logo
379 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
