Question about Uniden PRO510XL 40-Channels Base CB Radio
Modification of frequency output of uniden pro 510xl
How do you turn up frequency output?
  • 204 Answers
Deweyp, hi, if you are wanting to turn the power up some on the radio, do this; tune L4, L5, L6, L9 for
maximum RF forward output. There are 2 versions of the radio, and both are listed as 510xl. If you are wanting to expand the freq's or add channels, then no, there is no mod for that radio. If your going to tune the radio for more power, make sure you have a power meter to watch the output. It is preferable to tune into a dummy load so your not broadcasting over the air. You tune the radio for peak output, using a steady awwww sound in to the mic. Just be careful as that radio has a fairly small driver and final transistor. Don't want to let the factory smoke out of it,,,
Here is what the little variable adjustments are for and what they control;
VR1 Squelch
VR2 TX Meter
VR3 RX Meter
VR4 RX IF Gain
Hope this helps you out, let us know,, Mechanic
Posted on Feb 19, 2008
Don't clip anything. In the older version clipping d14 would open the modulation power but ultimately burn out the finals. SO DON'T clip anything.
Posted on Mar 06, 2008
    New Friend:
There is a frequency conversion using certain crystals from old CB radios made back in the early years. I have a friend who has 26.895 in his because all of the locals talk on the lower channel. On most exports it's channel 34, 1 band down from regular CB band.
Posted on Dec 20, 2015
Dont touch the radio
simply buy a better antenna and perhaps an amplifier
you can get a RX and TX amp for £30 or so
this will boost both TX and RX
but you need to make sure your antenna is aok and has a good resonance and SWR
so you need a decent meter to check it with the added output
Posted on Dec 02, 2014
    Problem Solver:
  • 18 Answers
Well the question was
Modification of frequency output of uniden pro 510xl if you are wanting to add more frequencies or channels to your radio it is possible however it can be a bit expensive as well as have some legal issues instead i would like to invite you to become a ham radio operator and you have a wide range of frequencies to acsess and a plethora of different modes it is very easy to do and cost less than modifying and possibly damaging your equipment..
Posted on Jul 12, 2014
In the newer version clip D 203 and retune
Posted on Aug 28, 2008
Pro510xl schematic
do a search for it. uniden pro 510XL schematic. I found it.
Oct 23, 2013 | Uniden PRO510XL 40-Channels Base CB Radio
How to turn up modulation on uniden PRO 510xl? I noticed it has tuneable vr4, I used vr4 to turn up the modulation on my cobra 29 ltd bt but are they the same on all cb radios?
No they are different. the pro 510 doesn't have a variable like the 29.
just trace the audio wire back to the audio transformer there should be a transistor on that section. best is to change the value of the resistors controling it to increase modulation.. if you take it out.. it will be wide open.. and can cause issues like splattering on adjacent channels. same goes for cutting the audio limiting diode, will cause the same issues. leave the parts in the circuits just change the values to achieve 100% modulation on a scope or wattmeter with a modulation function.
Oct 18, 2013 | Uniden Bearcat Pro PC68XL CB Radio
How to turn the wattage up on a uniden pro 510xl
why does everyone want to turn up the wattage. the most you can legally put out is 4 watts.leave it as is and get a small 100 watt linier amp and you will smoke em.
Dec 01, 2012 | Cobra Radio Communications
On my uniden pro 510e I can transmit but I cant receive all I get back is static got any clues?
Which radio are you referring to, the Pro 510e or the Pro 510xl?
In any event, to transmit and receive clearly depends on your antenna, it's location and it's surroundings and HEIGHT.
Radio waves on these radios depend mainly on line of sight and propagation factors, If you have an indoor antenna, that could be the problem, if it's an outdoor fixture, it needs to be in such a position so that the coax cable isn't being interfered with by another electrical fixture, the Height of the antenna, is most important, the higher, the better, taking in all these factors and a bit of try this and see approach should find a solution to your reception/transmition issues. That's part of the fun of setting up a base radio, experimentation, configuration and the results you want will be worth the effort.
I hope this has been helpful for you.
Cheers, Peter
Jan 29, 2012 | Uniden PRO510XL 40-Channels Base CB Radio
I looking for sxematic diagram uniden pro 510xl
I hope you find the schematic diagram for your radio......
Aug 25, 2011 | Uniden PRO510XL 40-Channels Base CB Radio
I have a Uniden Pro 510xl, it's about 9 yrs old. I went to use it last week and after turning it on, found that there was no sound, (turned the squelch up) . When I keyed the mic, I saw that I was...
chk mic, lose cable in **** plug test with other mic .. also test with Ext speaker.. do u get any reading on meter / LED display during RX? does PA work? otherwise your sound chip is dead
Dec 30, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
I just have Uniden Por510XL (used) but don't know how to set the channel (programming) so it can match with my handheld radio (i use motorola GP2000)
well a GP2000 has a Frequency range of 136 - 174 MHz, 403-440 MHz or 435-480mhz
a uniden pro 510XL is a 27 mhz radio as far as i know...
Dec 09, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
How to program Uniden bc72xlt
It looks like Uniden went out of their way to complicate the programming process on the BC72XLT. To program a frequency into it, first turn the scanner ON, then press the HOLD button to stop scanning. enter the channel number that you wish to program (01, 02, etc.), press FUNC and PGM (E), followed by the frequency - including the decimal point. Finally, press E. Pressing HOLD again should advance the scanner to the next channel where you can start again. Need the manual? You can download it here:
http://www.uniden.com/pdf/BC72XLTom.pdf
For a comprehensive database of active frequencies in your area, visit
www.RadioReference.com
Nov 01, 2009 | Radio Shack Pro-97 Handheld Scanner
Need help in trying to boost mod/wattage on pc68xl dont have cash to take to radio shop and also add talk back. someone needed my conex more than i did use my radio everyday thank-you for your knowledge in...
Hi and welcome to FixYa,
Not much DIY (do-it-yourself) modifications on a Uniden Bearcat Pro PC68XL  Some that could be tried:
  • VR5 - adjust for max / best modulation;
  • L8, L9 & L10 - change coil spacing for maximum carrier output.
Good luck and thank you for asking FixYa.
Aug 01, 2009 | Uniden Radio Communications
Uniden Pro 510xl can send but not receive
If you look on the solder side of board you shoud see a straight line of 5-7 solder joints, look on the other side the audio vhjp is a bmack thin retangular ic chip. Not to worry you wont hurt anything by doing this. Its an old cb tech trick to test audio chips.GOOD LUCK.
Oh one other thing does the radio have same same problem in either vehicle? A insulating washer on the antenna bracket can cause this also,
Happy New Year , Tom
Dec 30, 2008 | Uniden PRO510XL 40-Channels Base CB Radio
Uniden PRO510XL 40-Channels Base CB Radio Logo
3,877 people viewed this question
Top Uniden Radio Communications Experts
Steve
eradiostore
eradiostore
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
