Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore side by side refrigerator model 106.56532400
Hi
Could a tech please advise where I could get a wiring diagram that is normally placed at the back of the fridge for a kenmore side by side refrigerator model 106.56532400?
Please advise if any further info is required from me.
much appreciated
Nash
  • 1 more comment
  • lyvonne Feb 23, 2008
    I have a kenmore side by side and am not getting but 60 amps to evaperater fan motor, any suggestions
    KENMORE MODEL 253.51693 NOT GETTING ENOUGH AMPS to evaperater fan motor. Any advice would be appreciated. Thanks
  • Anonymous Mar 22, 2014
    model 106.51564101
Thanks for taking this question.
Kenmore 22 cft side by side does not have air circulation. Freezer is cold at the bottom (ranges 5-45 deg from bottom to top). Refrigerator section is 30- 60 deg from bottom to top. Thermostat is good; compressor is working; no ice deposit on the evaporator coils; condenser coils have been cleaned; defrost heater is working. I do not feel the air draft I used to notice whenever opened refrigerator door. Is it possible that the air recirculation fan not operating. Location of this fan in the refrigerator? Regards, Prem
Posted on Feb 19, 2008
Kenmore refrigerator model 25378832790
WIRING SCHEMATIC Diagram and Parts List for KENMORE ...
www.searspartsdirect.com/model-part/25360132993/0582/.../00005.html
WIRING SCHEMATIC diagram for model # 25360132993 Kenmore-Parts Refrigerator-Parts (11). Full Size ... Refrigerator ice door insulation Part #: 5303917276.
WIRING SCHEMATIC Diagram & Parts List for Model ...
www.searspartsdirect.com/model-part/25331614100/0582/.../00005.html
WIRING SCHEMATIC diagram for model # 25331614100 Kenmore-Parts Refrigerator-Parts (8) ... Refrigerator freezer door hot tube repair kit Part #: 5303918222.
WIRING DIAGRAM Diagram & Parts List for Model ...
www.searspartsdirect.com/model-part/2536580250a/0582/.../00006.html
WIRING DIAGRAM diagram for model # 2536580250A Kenmore-Parts ... Refrigeratordoor hole plug Part #: 240479601 Substitution: 240494001 Learn why ...
Kenmore refrigerator model 25378832790 - Fixya
www.fixya.com/support/t26040123-could_get_schematic_above
41 mins ago - Kenmore refrigerator model 25378832790 Where can I get a ... awiring schematics for a GE Refrigerator model TCC18JAAC type LB18,. Jul 29 ...
Jan 05, 2016 | Refrigerators
I bought a kenmore sidebyside used from a friend model #106.56569400 serial # ss1954954, well it is not freezing. It was stored in her garage because it was too big to fit in her house. I have placed...
Sounds like the cold control has stuck open. Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
If it runs then that cold control is the problem.
If this doesn't work Do this:
Hi!
That is probably the compressor relay or cold control (Thermostat
The relay is on the compressor and needs replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 12, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I need wiring diagram for our General electric Fridge Freezer
I don't like the idea of someone just recharging a system without knowing what's truely wrong.
At this point, based on what you've said, I strongly recommend you call G.E. factory service or a dealer with a qualified service tech in the G.E. line.
G.E. has made the use of a lot of solid state boards, which may well be some if not all of your problems. It will be pricey, but a refrigerator is not a toy. I would advise the tech as well, that you had a recharge performed, and let him follow up on it.
Sounds like whoever worked on your machine isn't well qualified to service it. Newer G.E.'s can be a real bear. Sorry....
Oct 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water is sent to the ice maker at the same time that the front
Hi, I thought I sent you a response but I see it's still on so I'll try again. It sounds to me like the wires have be reversed on the two inlet valves. When the ice maker cycles, do you get water through the door?
If I can assist further, please let me know.
Thanks
Vic
May 14, 2009 | Kenmore 53542 / 53544 Side by Side...
Kenmore icemaker does not work
Hand drawn of the GE # WR30X1009 found in 10-12 yr old Kenmore/sears/GE side by side refers. Couldn't find one ANYWHERE so forgive the hand drawn. Mine would not eject ice, intermintant. Bad microswitch on the on/off/vacation mode between the normally open side.
Apr 03, 2009 | Kenmore Refrigerators
Need schematic Kenmore bottom freezer model # 79565002401
you can pull off the kickplate(underrthe freezer door, and if you reach up under theright hand side there will be( if no one has removed it) a tech sheet/ wire diagram for you r machine
Mar 10, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
WIRING DIAGRAM
The manufacturer normally places a wiring diagram inside the operator console. Remove the back panel and there should be a diagram taped inside. Some of these diagrams will show two circuits. One is for a gas dryer, and one is for an electric dryer. Make sure you reference the correct one. I hope this helps you. If you need further assistance please let me know.
Aug 13, 2008 | Kenmore 63942 Dryer
Kenmore # 50222000 Refrigerator Defrost Heater
HI DOROTHY.YOUR QUESTION IS A VERY TRICKY ONE BUT I WILL TRY AND ADVISE YOU CORRECTLY.WITH REGARDS TO THE WIRING NOT BEING STRONG ENOUGH I HIGHLY DOUBT THAT WILL CAUSE ANY PROBLEMS IN THE NEAR FUTURE.IF YOU ARE STILL FEELING UNEASY ITS BEST YOU GET A SECOND OPIONION FROM A DIFFRENT CONTRACTOR.GOOD LUNK AND REGARDS MOHAMED.
Aug 06, 2008 | Kenmore 50522 / 50524 Side by Side...
Kenmore 253.51399101
Maybe this will help .. should be diagram of dispenser http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0165000&brandID=0582&modelDesc=SIDE-BY-SIDE%20REFRIGERATOR&modelNumber=25351399101&documentID=P0104005&documentTypeID=PLDM&documentClassCode=PM&titleType=DISPENSER&titleID=00007&
Sep 24, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
751 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
