Question about Daewoo FR-094R Refrigerator With Ice Box
My daewoo fridge FR-094 mini fridge is not working
My daewoo fridge FR-094 mini fridge was working perfectly then all the sudden just stopped. It is still on but will not cool.
  • 409 Answers
SOURCE: Fridge not cooling
You most likely have a thermistor that needs replacing. Can you tell me the the temp. in the fridge? Most LG fridges have a 1 year warranty with extended warranty on some parts. If you could provide the model #, I can look into it further for you.
Posted on Feb 03, 2009
  • 400 Answers
SOURCE: some times water flowing from bottom side of the fridge
There should be a drain pan directly below the icebox which needs to be emptied from time to time. Some units have a drainpipe connected at the back, if yours has one, it may have become blocked.
Posted on Mar 13, 2009
  • 531 Answers
SOURCE: Fridge worked perfect for 3yrs, one day i took
you may have a big problem not sopose have the door open so long better you call service
Posted on Apr 02, 2009
buddymcl777
  • 67 Answers
SOURCE: help needed to clean the filter of fridge
You need to clean your coils - that is why your refrigerator is not cooling as well as it used to and will also solve the clean light. Whether they are underneath unit by taking off the kick plate or behind it is the same problem.
This should be done every 6 months (or more if dusty enviroment) to keep the problem was reoccuring. The brush accessory tool of a vacuum works best usually.
Posted on May 05, 2009
mgprice
  • 744 Answers
SOURCE: fridge side stopped cooling
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck! P.s Please don't forget to rate my solution Thanks! Mike
Posted on Jul 20, 2009
My Daewoo FR-291 fridge with freezer at topleaks 1/2 cup or so a day & onto floor sometimes. Hired one for $150 as told to turn ours off for 2 days. Leaked nxt day again. Thxs NZ
a thorough inspection of the tubes, filter, solenoid, ice maker and water dispenser should reveal the leaking component
also a thorough inspection of the defrost drain, drain tube, and dryer pan
Apr 08, 2017 | Daewoo Refrigerators
Can you recharge freon tank on Daewoo #fr-094r mini fridge
You can but they have no fill valves. You have to add fill valves and if you don't do it correctly you can seriously injure your self or others during the recharge process. You can also injure yourself while trying to empty the system. Best thing your could prolly do is just replace the mini fridge.
Mar 16, 2015 | Daewoo Refrigerators
DAEWOO FR-661NW GETS HOT
Just a thought i would check if there. Is it possible an ice build up around the fan could be stopping it from turning?
Jan 24, 2014 | Danby 16.7 cu. ft. / 473 liter Upright...
Fridge is beepng and now defrosting
TRY CHANGING THERMOSTAT... HOPE IT WORKS ITS RIGHT HAND SIDE OF FRIDGE BY LIGHT.
Feb 25, 2011 | Daewoo FR-147RV
I lost manual book for my fridge,(daewoo) How can
Go to this site and after open the page, click on down "Download Page"
http://www.pdf-manual.com/user-guide-instruction-owner-manual-daewoo-fr-094r%28ss%29-23349.html
Hope, you got it.
Jan 23, 2011 | Daewoo FR-094R Refrigerator With Ice Box
Hello, my daewoo fridge freezer has stopped working. The light comes on & it sounds normal, any suggestions?
SOMETHINGS LIKE THAT YOU CAN UNPLUG FOR A WHILE THEN PLUG BACK IN AND THEY WILL MAGICALLY WORK AGAIN, I GOT A NON WORKING MINI FRIDGE FROM CRAIGSLIST AND THE GUY SAID IT DIDN'T GET COLD, SO I ASKED HIM SOME QUESTIONS ABOUT IT AND HE ANSWERED THEN AND I ENDED UP TAKING THE FREE MINI FRIDGE HOME , ALL I DID TO MAKE IT WORK AS UNPLUGGED IT FROM THE WALL AND CHECKED ALL THE CONECTORS ON THE BACK NEAR THE COMPRESSOR, I DID THAT THEN PLUGED THEM BACK IN AND I HEARD THE COMPRESSOR START TO KICK ON AND WAS LIKE YES AND NO I HAVE A GREAT LIL MINI FRIDGE TO KEEP SODA FRESH AND CHILLED , SOMETIMES I GET A POP TO EXPLODE IN THE FRIDGE BECAUSE IT IS SO COLD INSIDE
Jun 25, 2009 | Freezers
Help needed to clean the filter of fridge
May 05, 2009 | Daewoo Refrigerators
Some times water flowing from bottom side of the fridge
Mar 13, 2009 | Daewoo FR-064R Refrigerator With Ice Box
Ref: Servicing of Daewoo Refrigerator
I am in search of Daewoo Refrigerator Service Centre telephone and address in Mumbai, preferably in Dadar. If you know, please mail at mbsabnisandco@hotmail.com or Ph. 22653791
From,
Mrs. Padma D. Mulay.
Oct 14, 2007 | Daewoo FR-147RV
Daewoo FR-094R Refrigerator With Ice Box Logo
346 people viewed this question
Top Daewoo Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
jasbo
jasbo
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
