Question about Vizio Televison & Video
Backlight not on green indicator light on - Vizio Televison & Video
  • 3 more comments
  • Arthur Peloso
    Arthur Peloso Feb 01, 2010
    the power supply is good
  • Arthur Peloso
    the power supply is good there are two inverter boardl i notice when i turn on the power tne one converter board a blue led com on the slowly goes or
  • Arthur Peloso
    the tv is vizio vw42l-fhdtv-10a as i stated befor the green indicater light is on there np picture and no sound ,the power supply is good. when i turn the power the led in one of inverter 's glows for 3 sec
    thank you art
  • Arthur Peloso
    vizio lcd tv model vw42i-fhdtv-10a
    power light stays on.no picture and sound and no backlight
    when i turn the power on one of the inverters led glows for 3 sec.
  • Arthur Peloso
    how would that effect the sound ? and did i say there are two inverter boards
    artt
  • 1,476 Answers
I understand you to be saying that the green indicator light (standby/on) is lit but there is no picture or backlight. If this is correct you more than likely have a bad inverter board. Not extremely difficult to replace if you are competent with a screwdriver. You can get the part at www.partstore.com Remove the back of the case. Probably 2 dozen screws, just go slow and make sure you have them all out. Do not force anything and if you think it will be confusing to reassemble make notes or draw diagrams. Identify the inverter board, usually on the left side of the unit. Unhook all plugs, identifying if necessary. Reassemble unit and you should be done and have a working set. Let me know how it goes and if you need any additional help.
hardrocko
Posted on Feb 01, 2010
  • Kim Yearick
    Kim Yearick Feb 05, 2010
    While you say the power supply is good, how do you know? Did you check for all voltages? Because a light on the inverter lights for 3 sec does not mean the power supply is good. Check for all the correct voltages on the power supply. If they all check good then you are probably correct about the power supply. You say there are 2 inverter boards. Check them both to see if one or both are bad. If they both check ok then you have a bad control board which you would not be able to repair. www.partstore.com should be able to supply the board. Let me know if you need any more help.
    hardrocko
  • Kim Yearick
    Kim Yearick Feb 24, 2010
    After reading all your posts it occured to me that what you are saying is that the unit basicly does nothing, no picture, no sound, green light, which only means that it is on. I would replace the control board. In vizio's this is a weak link.
    hardrocko
    Thanks for using FixYa
  • 3,230 Answers
Well first of all please tell us the model number of your TV, so we can help you in details......
Thanks
  • 10,594 Answers
That means back light inverter board could be bad or power supply board does not provide proper drive volts to back light inverter board so it is not working.
Need to check both boards accordingly and replace defective board to get tv back in business.
Let me know if you have additional question along with exact model number of your tv.
Thanks.
  • Shahid Electronics
    Shahid Electronics Feb 01, 2010
    Good, since you rejected my assistance so good luck.
Turn the tv on and the green light blinks and then turns off and comes back on then turns off again but the screen is black. What is wrong?
KDF 60XS955 intermittently turns off green light blinking then on after...
The frequency and color of the blinks will indicate the issue. There is a hold-down button sequence to try to backdoor your way into the set to see if the panel will light. You may have simply racked up too many "weird tuner faults" and need to reset it. My suspicion is that it's either that or bad panel backlight.
Unplug set, press and hold (on set) volume-down and channel-down and hold them while pluging in set. Will come on with "k" on screen, or will crash again if backlight bad. If it stays on, use your remote and arrow right then look for "fact init" and any other reset and turn them on. Arrow back up to "fact init" and hit enter. Let set recycle to green and unplug/re-plug in 5 seconds: the set should be in OOB state
ref:
Sharp lcd tv power button flashing
Feb 13, 2016 | Televison & Video
Electro help
It sounds that the back-light inverter has the fault. If there is any winding short [cannot detected by measuring with an Ohmmeter], this type of fault can occur. The only thing to do is replace the back-light inverter board. The LED blinks indicates a short circuit .
Apr 25, 2013 | Sony Bravia Klv 46X300A 40X300A...
My monitor screen is black. The green light is on but black screen
The green light usually indicates that the monitor is getting a signal.
The lack of a picture is an indication that the monitor itself is having a problem. I would test the signal with another monitor if you can get one.
I suspect that the monitor backlight has gone bad (if so, you can see the screen very faintly if you shine a light on it).
Or, the screen circuitry has gone bad.
Jun 30, 2011 | Computers & Internet
Black screen , red standby light flashing 4x repeatedly, unplug it and the green light comes on momentarily then resorts to 4 red flashing lighrts again. Sony KDL-40V2500 approx. 4yrs old. HDMI cables are...
4 blinks indicated of backlight malfunction. The unit shutsdown to avoid overload to the inverter board.
Check the backlights, busted backlight has a physical indication of fault like blackened end, crack end. You must replaced the busted one and your unit will back to normal operation again.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 16, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
The monitor will not come on. The indicator light just stays on red. We will unplug it and plug it back in, the power indicator light will flash to green then return to red.
You will more likely to have bad caps in the power supply which when they failed, will take out the fuse and MOSFET in the backlight inverter curcuits also. See example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 07, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
ViewSonic LCD Monitor Went Blank
It is probably a bad INVERTER and / or backlight fluorescent bulb.
Jul 02, 2009 | ViewSonic Computers & Internet
Black screen, blinking green light, nothing happens
Hi it is the indication of error code......can you tell me how much time does light blinks......
Jun 03, 2009 | Mitsubishi WD-52528 52" Television
The screen is black even though the green light is on
Your inverter or backlight need to be replaced those are the main components that light up the display.
If you find this helpful please rate so.
Thanks
May 04, 2009 | ViewSonic VA1912wb 19" LCD Monitor
No display
With the monitor hooked up and the computer on, you can take a bright flashlight and shine it on the screen and see if it is displaying a picture. If you can see a picture then you can go the route of fixing your back light. I have a spot light that I use and it works really well. If you can't see anything then you are probably SOL and have to replace the monitor.
May 14, 2008 | HP Compaq FP 7317 17" Flat Panel LCD...
Backlight is acting like a bad flour. tube .. everthing else OK
Normaly the backlights have a life of around 40k hours of working.
If your monitor is 3-4 years ,the backlight tube/s could be defective.Your description seems to indicate tube aging.
It's possible to replace the tube but needs a good amount of technical skill.
Do write if you need more help,Please indicate make exact model no etc.
Samir
Mar 22, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Televison & Video Logo
199 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
