Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
I need to unblock the drain pipe but i need to get the main body of the machine to come out further, how do i do this
  • Fisher and P... Master
  • 3,247 Answers
I am assuming you want to find out how to take the drawer out from the cabinet.
You will need a nose plier and follow the instructions on page 7 of the installation manual at
http://www.fisherpaykel.com/admin/pdfs/pdf_installations/526607O_DD_Install_USw.pdf
Make sure not to drop the drawer or stretch the hoses to cause breakage.
Hope this will help.
Posted on Feb 05, 2010
While moving my samsung top washing machine, I think my drain hose pipe has moved down the water level. Now machine is not able to retain the water while washing/soaking. I need to pull the drain hose pipe...
Although a few modern washing machines can operate with the drain pipe at any height, most machines will drain the water as soon as the drain pipe is placed below the machine water level.
The simplest solution for your problem would be to ask somebody with some handy man skills or hire a plumber to add a 2 inch PVC pipe to your drainage pipe which extends to a point behind your washing machine & then points upwards, making sure it is long enough to be at a higher point than your machines fullest water level.
This should be a relatively inexpensive alteration & will ensure that water does not drain unless the machine is on its drain cycle.
Please let me know if you need any further assistance.
Best wishes,
Graeme
Mar 10, 2011 | Samsung SW62ASP Top Load Washer
Hi, I have a 10yr old Neff s5543 built-in dishwasher, it is has been working fine but recently has stopped fully draining. I have removed it from the housing and checked all pipe work is unblocked and...
Hello there and thank you for choosing fixya
Ok there are acouple of things that can be checked on this along with what you have already checked
Drain solenoid Beneath some dishwashers, there's a timer-activated drain solenoid (an electro-magnetic coil) that opens a drain valve, to drain the wash water through a hose and out to the house's plumbing waste system. If this is failing it will not allow the water to drain from the machine fully
Timer Dishwashers have a timer behind the main control panel at the front top of the dishwasher, or behind the lower access panel. It is either a mechanical device like a simple clock, or it's completely electronic with just a digital readout. The timer runs the dishwasher in a pre-determined pattern. It provides the electricity to all of the dishwasher components at the correct time, for the correct length of time.
Oct 16, 2010 | Neff 24 in. S5543X2 Built-in Dishwasher
Could you please tell me what error codes 21 and 6 relate to on a Winterhalter GS502 dishwasher. Many thanks. Barry CER
error 6 relates to a blocked drain pump. if the drain pump is working ok check if the tank level sensor is operating or if the air chamber in the wash tank is blocked.
error 21 relates to the drain pump being activated. normally related to error 6.
also check water inlet solenoid valve is working correctly. ie not blocked or passing.
all parts of the machine can be activated manually by entering service mode.
when machine is off press service button or switch on main pcb.
p00 appears. press and hold main wash button. --- appears. using the long and short wash buttons you can scroll through parts of the machine. displayed as a01 a02 a03 etc.drain pump is a12 solenoid valve is a13. these are activated by pressing the button. when activating the drain pump the display will count down. this number is the water level in the wash tank. if it's counting down the level sensor is ok.
hope this helps
jarv
Mar 29, 2010 | Dishwashers
Dishwasher will not fill up.
Set the controls to off then power off at the mains for 30 mins and then power mains back on and run a drain program or a full wash program. If the water won’t drain away then the most likely problems are the door interlock switch is faulty, the drain water motor is faulty, there is a blockage in the drain outlet pipe or filter – this will need unblocking, there is a blockage in the water pump – this will need to be unblocked, the controller board is faulty – but this generally shows an error code. First turn off the mains power to the dishwasher then check the internal filter and screen and clean it thoroughly. Then check the waste water hose and any outlet valve and make sure that it is unblocked and free of any obstruction or waste material. If you have access to the water pump you can check that it is free of obstruction and is able to turn and that none of the impeller vanes have been damaged. Then if all this is OK then try turning on the mains power and running a hot wash cleaning cycle to flush out any remaining sludge / debris.
If the outlet pipe is clear and the pump motor is turning and there is no pump damage then there has to be a blockage somewhere. You could lay the out pipe flat on the ground with the end draining into a tray to see if any water actually does come out. If it does then you do not have a total blockage. This is because it will be most likely draining out of the machine due to gravity and shows that there may be a partial blockage of the pump is defective even though the motor may be running. You will need to remove the pipes to and from the pump to check for blockages and also remove the pump to inspect for damage to the impeller or a blockage in the pump housing where the hoses connect. If the pump housing is clear and the impeller can be turned freely with your fingers then the direct coupled or belt driven linkage between the motor and the pump is the most likely broken and will need repair or replacement. If the impeller cannot be turned easily and does not turn with the motor running then the impeller or the direct linkage is either seized or broken and will need replacing. If your pump and impeller is belt driven then check that the belt is not slipping – this will normally result in increased noise and a possible smell of burning rubber
Dec 30, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Water remains at bottom after dish cycle is complete . Dishes come out clean and everything seems normal except for the water that remains at the bottom of the dish washer. I realize that a small amount of...
If the outlet pipe is clear and the pump motor is turning and there is no pump damage then there has to be a blockage somewhere. You could lay the out pipe flat on the ground with the end draining into a tray to see if any water actually does come out. If it does then you do not have a total blockage. This is because it will be most likely draining out of the machine due to gravity and shows that there may be a partial blockage of the pump is defective even though the motor may be running. You will need to remove the pipes to and from the pump to check for blockages and also remove the pump to inspect for damage to the impeller or a blockage in the pump housing where the hoses connect. If the pump housing is clear and the impeller can be turned freely with your fingers then the direct coupled or belt driven linkage between the motor and the pump is the most likely broken and will need repair or replacement. If the impeller cannot be turned easily and does not turn with the motor running then the impeller or the direct linkage is either seized or broken and will need replacing. If your pump and impeller is belt driven then check that the belt is not slipping – this will normally result in increased noise and a possible smell of burning rubber.
Dec 28, 2009 | Whirlpool Dishwashers
My bosch diswasher is 2 months old and now the water doesn't drain. how can i fix it
Dec 28, 2009 | Bosch Dishwashers
Water not draining
Oct 01, 2009 | Frigidaire Dishwashers
Blocked dishwasher drain
First can you hear the drain pump running when the machine goes into drain cycle?
If you can then what you can do is pull the dishwasher forward and locate where the drain pipe (cyphon) is connected on the back of the machine,this is normally connected to a short plastic tube via a hose clamp.Loosen this and remove the pipe shove a hose down it and clear,replace and test it should work.Just a few pionters when a unit is not draining,first check in the botoom inside of the machine there is a filter remove and ensure this free from obstuction,also while the filter is of visually and with your hand feel for any obstruction in the machine where the filter goes.
Give this a try and let me know if this helped if it does not we can go to the next step.
Feb 05, 2009 | Electrolux Dishwashers
Bosch WET2820 integrated washing machine. Cycle gets stuck on "anti-crease 1". Have followed instructions in manual for unblocking drain pipe, hose and suds pump although problem (doesn't drain...
was a hair clip stuck in the drain pump..
fixed like this:
Use the small draining pipe that is fitted to the filter housing to drain the water down.
Take the filter out from front bottom.
Inspect and remove any debris blocking the drain pump.
et voila! working!
Jul 10, 2008 | Bosch Washing Machines
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
105 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
