Question about Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer
Not drying , spins and makes all the right noises but no heat
  • Hotpoint Master
  • 3,463 Answers
The fault is probably due to thermostat or element not working.
Remove the top cover, and you will see the heater manifold on the top right of washer, this is where the stats and element are located.
Also check for broken wires.
Posted on Feb 02, 2010
Dryer won't spin
If you have kids and they over fill the dryer it strains all systems including the heater because it cannot get rid of excess heat. Solution*** Possibly needs a new belt
Dec 07, 2012 | Maytag Dryers
Whirlpool imperial 80 won't heat much
That clicking noise is normal. You may have a thermostat problem. It sounds as though it isn't letting the element get hot enough, or cycling the element on/off too often.
May 12, 2012 | Dryers
When in use, my dishwasher at times, makes a lot of repeating noise and it appears to tick.. th digital reading on the right blinks CL CL CL CL then HOT then goes back to tell you the remaining time, and...
Some dishwasher noises are normal, like the hiss of water rushing through the water inlet fill valve, or the hum of the pump motor, or the slosh of water. But if your dishwasher is making strange sounds or is unusually loud, it's time to investigate. A thumping noise could be the drain line vibrating against the cabinet; a grinding noise could be caused by a popcorn kernel being stuck in the chopper blade area of the dishwasher.
The CL is normally indicated child lock has been activated.
Dishes typically dry by the end of the dishwashing cycle, with one exception-plastic items. Because plastic doesn't retain heat like glass, ceramic and metal do, you'll almost always see drops of water on plastic items after the cycle finishes. Rinse aid helps water drain off all dishes so they dry better. Make sure that you fill that rinse aid dispenser when it's empty. A heated dry setting also is an option to enhance drying. You may have this option turned off to save energy, but if your dishes aren't drying as well as you'd like them to, you might want to consider turning it back on. Consult your owner's manual and select the cycle options that fit your needs and your energy usage goals. If your dishes don't get dry even though you've selected the heated drying option, then the heating element could be broken or the high-limit thermostat for the element may have tripped in error, preventing the element from heating. A malfunctioning vent or drying fan could also prevent dishes from drying. Check out this troubleshooting video that could help you correct a drying problem: Dishwasher Not Drying Dishes Video.
Oct 26, 2017 | Frigidaire FDB1502RGS Built-in Dishwasher
I have a indusrial admarial 10g and it makes a noise when spinning it still heats up to dry clothes could you tell me whats wrong please and to to get into it to fix it thank youi
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 18, 2010 | Dryers
When the heat was on withefrost i hear a noise from under the hood of my 2003 monte carlo ls it sounde kinda like something tryna spin or spinning making a noise right when i turned off the heat and...
That is your a/c compressor kicking on and off to create air to the defrost. The a/c compressor will only kick on when the a/c is on or the defrost.
May 07, 2010 | 2003 Chevrolet Monte Carlo
LG gas dryer DLG0452W drum makes a clicking noise
one of the dry drum baffle screw might be lose are there might be something caught inbetween the dry drum front seal are rear
Apr 24, 2010 | LG DLG0452W Gas Dryer
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
Fujitsu heat pump noise
i would check the blades on the condenser fan motor and make sure they are not hitting anything if they are not, spin the fan see if the fan spin freely, it should, if it doesn't it could be the bearing in the motor are dry and going bad
Jan 22, 2009 | Fujitsu 24C1 Air Conditioner
Maytag electric dryer makes noise from heating compartment--sounds like fan blades maybe hitting something?
I don't know that I can help you in any way other than to say that you are probably right. But some times the blower wheels do come loose and spin somewhat freely on the shaft and make a similar noise. But when that happens, you will usually notice a vibrating sound right after the drum stops spinning. Because the blower wheel continues to spin for a second or two. But I have seen, popsicle sticks, jewelry, bobby pins,those plastic white things that are under the collar in shirts and all sorts of other things in those blower wheels making noise.
Good luck
Jul 27, 2008 | Maytag Dryers
Washer: Thundering herd of elephants. Dryer: Increased drying time
if vent is clean, did you push it too far back afterward and flatten vent hose? also blower fan may be loose on motor shaft resulting in slower rpm also may be excess lint in blower housing ..washer suspect lower bearing although not sure what a stampeding herd of elephants would sound like ..if noise is on spin if during agitation suspect transmission gears ..both will require new transmission ..if noise is more of a knocking noise possible broken bolt in basket trunion block remove agitator to ck
Jul 15, 2008 | Frigidaire FEX831CS Top Load Stacked...
Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer Logo
301 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
