Question about Cameras
My camera got wet in the snow and it comes on but
My camera was left outside in the snow for 4 days and it comes on but the lens is fuzzy when you go to take a picture will it dry out and be fine or is it to damaged?
  • 6,831 Answers
Hello
Ok, you just might be able to safe this device, but, there is a possibillity that yoou need to send the camera in so that the dried damp on the inside of the lens itself can be removed.
This is something that i suggest that you do not try yourself, as the disassembley of the lens is a very complicated task.
If the damp inside the lens is still wet, put the camera in a sealed container with about 3 cups of rice. Leave it in the sealed container for about 3 days.
If this does not work, the water damp is already dried, thus, the lens itself needs to be disassembled. This will cost about $40 to repair.
Hope this can be of help.
Kind regards
Andrea
Posted on Feb 01, 2010
How do I turn my event by kyocera on its completely of I left it in snow for two days.
What makes you think it's okay to try to turn it on after it's been in snow for two days?? It's probably not.
You can try this:
WET cellphone fixed in 3 MINUTES not 3 days
Feb 16, 2015 | Kyocera Cell Phones
I left my nikon D3100 outside with the tripod and i forgot to get it,then suddenly it got wet from the rain,what will i do?
Remove the battery imediately, the memory card and the lens. Place the camera body, lens and memory card in a warm dry and place for several days to dry out completely.
When the camers is dry, insert the battery, lens and memory card, turn on the camers and set the date and time.
If the camers does not work charge the battery and try again.
If it still does not work then you need to send it to the Nikon service centre for repair.
Jan 15, 2012 | Nikon D3100 Digital Camera
There is a foogy spot in the interior of the lens, dead center. The camera has not gotten wet or been left outside. All my pictures are now blurry. Camera is about 1 year old.
Do you live in a hot, humid area? If so, this could be condensation that has left a mark on the lens after evaporating or, as some have experienced, mold growing on the lens surfaces.
Nov 11, 2010 | Nikon COOLPIX L100 Digital Camera
Water problem with canon digital camera
u must let it dry if you did not remove the battery when the unit got wet then its a goner water damage sends electronics to there grave fast! if battery is left in the gold and copper traces start to corode ! and in minutes not days!
Aug 29, 2009 | Canon PowerShot A95 Digital Camera
Pictures fuzzy when you look through the viewer.
The viewfinder and the picture lens are totally separate. If it looks fuzzy, and then comes out fuzzy, the capture screen inside needs cleaned. The main lens and viewfinder lenses should be cleaned too.
Get estimates before you say yes to the work. It might be cheaper to buy another camera, unless you can do the work yourself.
Aug 06, 2009 | Sony Cyber-Shot DSC-P52 Digital Camera
Kodak c340..water in lens...
i kept the camera on, that means the lens was open too..........after a good 4-5hours later when i checked it was back to ''foggy'', and another few hours later it was back to normal.........hurrah!!
Feb 02, 2009 | Kodak EasyShare One Digital Camera
Olypus sp-500z Lens won't come out
If the batteries are cold or the camera senses condensation then it may malfunction. Let it stand in the warm room for 1 hour prior to booting up. cold batteries dont put out the same voltage.
Oct 29, 2008 | Cameras
BLURRY OR FUZZY LENS
Perhaps you have had the camera in a very humid environment and now there is condensation inside? Perhaps try putting it somewhere warm and dry (not hot) for several days. Switch it on and off (and zoom in and out a bit) a few times during this period to change the air inside the lens. This will help expel the moisture.
I assume that it isn't just finger marks on the front of the lense? If it is, you can use a cleaning cloth (for eye glasses or from a camera shop) to clean it.
Jul 20, 2008 | Samsung Digimax A402 Digital Camera
My videos are fuzzy with lines in them. Only when I film outdoors, which is what I am using the camera for. Any hints?
Its fairly massively over exposed, the vertical lines are a product of that.
4 things I can think of it may be, not knowing which camera you have..
1)the camera could be in night mode - switch to normal or outdoor
2)the exposure compensation is turned up - reduce the setting
3)the camera has crashed, remove main (and backup battery if it has one) and leave for a few hours (you will know if you left it long enough as the settings in the menu will return to default and the clock will reset) and/or check the manual for a reset/return to factory defaults option.
4) The aperture is stuck, this is a surprisingly common fault, in many situations it goes unnoticed as the camera will simply use a higher shutter speed to compensate but often the video modes have fewer shutter speeds available - There is some risk in this it depends how annoying the problem is, how attached you are to the camera (though I've cured many like this, and when suggested to others, many reports of sucsess) and if the warranty has expired.
In video mode maybe outside or with a very bright light shining down the lens, using some thick carpet on a solid surface, give the camera a few sharp bangs against the side near the lens and bottom. What happens is if the camera has got damp at some point, maybe brought in from the cold outside to a warm house, condensation can build up in the lens, the aperture and shutter are made of PTFE film which is a very thin plastic and this can cause either to get stuck, causing under or over exposure or simply a black screen.
Beyond this it needs a service center
May 26, 2008 | Olympus Cameras
Cameras Logo
174 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
