Question about Samsung ML 1710 Laser Printer
Samsung ML 1710 Laser Printer, over active feeding
The minute we turn on the printer it starts shooting blank paper from the drawer to the output tray non-stop. We've cleaned out the inside with compressed air. Any ideas?
    Genius:
  • 3,587 Answers
Sounds like there's something in the print queue..disconnect it from the computer, and try it again.
Posted on Feb 19, 2008
My printer just refuses to pick up paper. It sounds like it's going to print, then quits & red light comes on. Do I need to clean the rollers???
Yes. Remove the paper tray. Lift the printer and you have to see paper feed roller it is rubber, just clean of dirt with cloth and alcohol or water.
Feb 04, 2011 | Samsung ML 1710 Laser Printer
Samsung 1710 stops before printing
to fix the problem you have to press the plate that the paper sits on down until it clicks into place once you do that it should work fine.
Oct 29, 2007 | Samsung ML 1710 Laser Printer
Paper rollers wont feed paper from paper tray
Pull out a paper cassette, lift up the printer and under you see paper feed roller (it is rubber), just clean roller with cloth and water or alcohol
Sep 03, 2010 | Samsung ML 1710 Laser Printer
The paper gets blocked evry time i start the printer
It could be that small pieces paper is still stuck in the rollers. Make sure also that the paper feeder is properly placed on its correct location. Other things you can do is to put some more paper on the tray. See if it will feed the paper.
Please post back if you still have any concerns.
Aug 21, 2009 | Samsung ML 1710 Laser Printer
ML-1710 Printer won't print
Our printer at work does this and I found that a piece of paper was stuck under the rollers. As soon as I removed it the paper went through. Another problem could be that you may need to FAN the paper and make sure the other side is feeding in first. Hope this help
Mar 20, 2009 | Samsung ML 1710 Laser Printer
Paper jam
You could try cleaning the tires if you can get to them and check to see if there isn't any paper stuck in the paper path.
Jun 11, 2008 | Samsung ML 1710 Laser Printer
Paper scrolling
Sometimes there is a spring in the paper tray which pushes the paper upwards so it presses against the rubber roller in the body which pulls the paper into the printer. If this spring has become dislodged or similar, it won't push the paper up with enough force for it to work. Also, somethimes in an older printer or one which has seen much use, the rubber roller can become deformed, causing a similar problem. This one is much harder to fix because spare parts are usually either not available or extortionately priced!
Apr 21, 2007 | Samsung ML 1710 Laser Printer
Samsung ML 1710 Laser Printer Logo
93 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
