Question about HP Photosmart 3310 Printer
My printer is printing off color, already tried all settings on the printer. what else can i try?
    Sergeant:
  • 206 Answers
Goto the HP Printer Solution Center. Open the Printer Toolbox. Under Device Services, you can Align and clean the print cartridges. Print a test and sample page.
Also the Help button opens another box. Search Adjust Color. Look for Adjust Color. From here you can learn to adjust Hue, saturation, and use enhanced colors.
Good Luck
Posted on Feb 01, 2010
My printer DataCard SP 35 started printing only in grayscale suddenly (with a colored ribbon). Before it ware printing colored cards.
I think rain doesn't have anything to do, unless you had your printer outside...
Maybe a light interruption could make your station start over without proper settings. Try checking your printer driver and see if it has the proper settings for ribbon and not printing on black dots.
Jan 17, 2014 | Datacard SP35 Printer
My printer can not print in color
Open the document you wanted to print. Go to File then Print. In the dialog box you will see many printing options, to choose paper size, resolution, etc etc. Your problem must be in the Color option. You must have set it in Grayscale. So select Color.
Nov 21, 2011 | Office Equipment & Supplies
Cannot print in black because color cartidge is out of ink
There is a 'low toner' override in the menu system, but if this has NOT been set already, a 'flag' will be set on the chip on the cartridges that are low/empty.
The printer needs to 'see' cartridges that are usable, i.e. NOT empty, in order to function.
It is possible to replace just the chips on the colour cartridges, but then any colour printing quality could be compromised of course, as the colours will be low/empty. You would then be able to use the printer as if it were a mono laser, just changing the black cartridge when needed
Apr 27, 2010 | HP Color LaserJet 2600n Printer
Card Pictures will not print
Change the Printer's Spool Settings.
  • Go to START - SETTINGS - PRINTERS.
  • Right Click on the PRINTER and choose PROPERTIES.
  • Under Printer Properties, select the DETAILS tab and click on the SPOOL SETTINGS button.
  • Change "SPOOL DATA FORMAT" from EMF to RAW (it may already be on this setting.)
  • Click on PRINT DIRECTLY TO PRINTER. Then click on OK.
  • Now Select the GRAPHICS or COLOR tab. If there is an option for RASTER mode, select this mode. Then lower the DPI setting and click on OK.
  • Also, make sure that the Print Mode is set to NORMAL and not Best.
  • Close the Printer Properties window by clicking on OK.
    3. Now set the printer as a default Printer. Right click on the PRINTER icon in the Printers Window and select "SET AS DEFAULT" to place a check mark by this option.
    Please try printing and let me know if that fixes it.
  • Apr 02, 2009 | Creative Home Hallmark Card Studio Deluxe...
    HP 640 Fax series not printing
    If it is a color printer, try printing just grayscale or black& white.  It is is already set to print just b/w, try printing in color.  Basically you may be out of ink.  Run the printer utility to clean the heads and see if anything changes.  A new set of cartridges should fix the problem, I believe.
    Hope this helps...
    ~enov8
    Feb 16, 2009 | HP 640 Inkjet Fax Machine
    Printer won't print anything but a test page
    Check printer settings. Also check windows setting for the printer. Also, be sure the printer is not offline.
    Mar 05, 2017 | HP Office Equipment & Supplies
    Colors not printing
    hmmm..interesting..you get new drivers on that printer? try here, just in case it's an older set for your operating system.
    Mar 16, 2008 | Canon MP610 Photo All-In-One Printer
    Empty ms word printout
    Hi, You can try: 1. go to Start, Printer and Faxes, right click on your 3745, click on Properties, Printing Preference; 2. Check to see if you have any Advanced tab or button; 3. Check if you can set the printer to text only; 4. Check if you can set the printer to use black ink only. 5. In MS Word, verify through the use of Print Preview that your document is as you would want to be printed; 6. In some instances you may have to set manually text color in MS Word. While your document is open, click Ctrl + A to select all, then choose font color to "Black". Alternately, in your MS Word, you can click on "Format", "Font", "Font Color" set to "Black" rather than "Automatic" and set this as the "Default" setting. Hope this be of some help/idea. Post back how things turned up or should you need further information. Good luck and kind regards.
    Sep 29, 2007 | HP DeskJet 3740 InkJet Printer
    Colored Ink problem
    Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
    Jun 08, 2007 | Lexmark Color Z35 InkJet
    HP Photosmart 3310 Printer Logo
    112 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
