Question about LG Refrigerators
Have self defrost fridge and water builds up in the bottom. can not locate drain pan?drian plug? or where the water in comming from. can not find owners manual and model # is LRTN 18320ww
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
Remove freezer cover. use hot water and a turkey baster to remove ice from drain. then blow out with short hose.
Posted on Feb 01, 2010
Water leaks on floor, where isthe defrost drain pan? the manual indicates that water might build up in drain pan, the connections with the ice maker are all dry.
The drain pan is usually located closest to the floor - behind the kick space or toe space grill at the bottom of the fridge. Most often the water that collects in it is evaporated by the heat generated by the compressor and airflow from condenser fan located close to the pan.
Make sure the water is coming from the defrost drain hose - not from water sources elsewhere in the fridge (leaking water / melting ice into the fresh food compartment, etc.). If found, take action to correct.
Oct 19, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Water from fridge not going down plug hole into container. How ofter should the water container be emptied at the back of the fridge/freezer I have a sub zero frigerator #550 its about 15 years old....
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. .
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.You can use a hair dryer and remove the ice buildup
Oct 30, 2008 | Refrigerators
Defrost water not draining into pan under unit. Instead the water is sdettling in the bottom of the freezer, freezing and eventually leaking onto the floor.
You have a defrost drain that is plugged. You will have to locate the drian and clean it out.Try looking in the freezer side way back and on the bottom.Also you may be able to get to it from behind the refigerator.Hope this helped.
May 29, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Water dripped on bottom of fridge
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved.
Think this will solve the problem....
Jul 28, 2010 | Kenmore 57029 Side by Side Refrigerator
My side by side for some reason has water coming out from under it..i check the water feed line and its good!I then checked the drain plug in the frezzer and noticed the whole bottom of the frezzer had...
What is a "drain plug"??? Never seen one on a fridge ;)
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in.
Good luck! :)
Vlad
First Choice Appliance
Dec 21, 2009 | GE GSS20IEP Side by Side Refrigerator
There is water building up in the bottom of the fridge ( under the crisper drawers). If I leave it there it will freeze. What is causing the water? The fridge is 18 years old.
drain hose is plugged... the freezer it need to drain water when if goes into defrost .the drain from the bottom freezer down to the bottom of the fridge... there is a pan under the fridge that holds the water until it evaporates
Sep 19, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Mine collects water under the crispers also.
Aug 17, 2009 | Kenmore 64802 Top Freezer Refrigerator
I have a maytag MSD2754GR, the freezer bottom is all iced
The drian hole has become stopped up and ice has accumulated in the the drian hole. You will need to unplug the fridge and remove the cover on the back (located at the bottom, 6 screws). On the freezer side there is a drian hole with a rubber 90 and a clear line that runs to the drain pan. Remove line and unstop. Don't not put the line back on yet.
Now for the fun part, remove the basket and the two bottom shelves from the freezer. Half way up the back there are 2 screws that need to be removed. After removing screws pull up on the top cover to so you can remove the bottom cover. The bottom cover maybe froze to the coils and to the inside drain pan. Break the ice with a butter knife, and remove cover ( do not hit the coils). Now you need to break the ice that is froze to the the pan and under it. Once you have remove all the ice you will see the drain hole, use a small pointed object to break ice that is in drain hole. Now you can put the drain line back on and make sure that the other end is in the drain pan under the fridge. Now reassemble the fridge and plug it back up.
It took me about 20 minutes to do this.
Hope this helps.
Jun 22, 2009 | Maytag MSD2456G Side by Side Refrigerator
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
Fridge is leaking water all over the place.
The defrost drain opening or drain hose is plugged up with ice or crud. If the drip pan is bone dry, it's a sure sign that the drain opening or drain hose is clogged. Trace the drain hose back to see where it pick up the condensate in the refrigerator cabinet. Remove whatever pieces you need to to clean that sucker out. Door gaskets are torn or not making good contact with the cabinet. No? Well then where's all that water coming from, Einstein? It can only come from the humidity in the outside air--your fridge can't make water, dontcha know
May 10, 2006 | Maytag MBF2256H Bottom Freezer...
Refrigerators Logo
217 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
