Question about KitchenAid KSM150PS Artisan Series Stand Mixer
Beaters will not turn, motor runs.... - KitchenAid KSM150PS Artisan Series Stand Mixer
  • 148 Answers
They seem to have a plastic gear built in as protection for overloading (prob). When the machine counters to much resistance that gear will strip its teeth causing the machine to not be able to turn, that it what seems to be the grinding problem. If it is not the plastic gear then it another gear that is "stripped(of its "teeth") I hope your problem is not a severe, but if your mixer is "locked up" then at least you found the problem...
Hope this helped, if it did (or not) please rate, thank you!
Posted on Feb 03, 2010
One of my blades is stuck and I can't engage the release
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
Jul 19, 2011 | KitchenAid KSM150PS Artisan Series Stand...
First time using bread dough beater It was hard to put on and am unable to remove
as far as possible.
5. Pull beater from beater shaft.
Jul 17, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Bread dough beater will not come off
as far as possible.
Beater won't turn, but motor is running.
Hi, Did you push the beater in so that it clicks. If all is good there, gear box maybe at fault or jammed. Take it to a service center for repair. If you are machanicly inclined (DIY) Take it apart and see why its not turning. Good luck.
Jun 04, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Beaters will not move
You have probably stripped a gear in the gear housing. Here is the breakdown of the gearbox:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212010.pdf
The newer "more improved" mixers use plastic gears and they can't take the beating, no pun intended, and fail.
The good news is that the most likely gear to fail is cheap. Here it is on amazon.com:
http://www.amazon.com/KitchenAid-W10112253-Worm-Gear/dp/B0006HLAVA
http://www.misterfixit.com
Mar 25, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Motor runs, beater stopped rotating. Some gear sounds heard before it stopped. Beater will not turn at any speed setting.
drive gear or shear pin stripped. Common on this model. Return to repair centre. Expect to pay approx $150.00 to repair, sorry.
Sep 14, 2009 | KitchenAid KSM150PS Artisan Series Stand...
The beaters won't go around. The motor is running
I can't solve this problem, but mine just died doing the very same thing. Motor is running, the revolving base is turning, and the beaters are just sitting there. Ruined an entire batch of divinity!
Aug 30, 2009 | Sunbeam Heritage 2346 Stand Mixer
Turntable does not turn. Motor runs. Beaters work.
I have the same one, and the turn table has never turned on it's own. from looking at the bottom of the stand, i think the mixers are supposed to turn the bowl, so i just give it a little turn, and the mixers kinda take care of the rest. BTW, i got 2 sets of beaters with mine and i dont know what the second set is for, do you? contact me at rawemo@hotmail.com
Feb 18, 2009 | Sunbeam Food Mixers
Beaters don't turn
You should try to replace the beater turners or try to fix the problem that causes the beater turners not to work.
May 01, 2008 | Sunbeam Heritage 2346 Stand Mixer
Motor runs but the beater does not move
you most likely stripped the plastic gear (Worm gear???).  This gear is designed to fail to prevent the motor from burning out under EXTREME loads (i.e. when a metal piece falls into the bowl). The plastic gear is much cheaper than a new motor.  Look around on this site to see how to get at/repair the gear.  I've found many parts on eBay.com and also PartSelect.com.
Dec 16, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
256 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
