Back to:
Tags:
Philips AZ1300 CD Boombox
Constant 'Err' and 'No Cd' (by 2 users)
posted by Neozim11 on Feb 19, 2008
That is what I keeping getting when I put in a CD. Even with a real music CD, it still gives me an error message. It rarely plays CDs anymore. My warranty expired and i don't think the lens is broken. It is spinning when i open it, which indicates to me that everything should be fine. I really have no idea why it is not working. I haven't dropped it or anything. It's been like this for a while now, but recently it just does not seem to play anything anymore. I can't get good reception here in my room, so i can't listen to the radio so all that's left is the CD player. If that does not work maybe i should just throw the Boombox out and get a new one. What should i do and is there a problem?
Comment by Neozim11, posted on Feb 19, 2008
I used a combination of solutions #1 and #2. It seems to working better than when I first bought it. I got a lense wipe that had alcohol on it and cleaned the lense meticulously and the entire boombox to remove all dust. I didn't know the lens needed to be relubed with alcohol or anything like that. I was just cleaning it with a damp towel. Thanks for the quick response. I appreciate it.
ah okay, it really does not matter anymore since it functions properly now. It must have been the lens was smeared/dirty. Thanks for everything.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Jinyx, posted on Apr 26, 2008
My Monsoon CD player in my VW golf reads "Error" when a CD is put in and immediately spits it back out.
Best Solution
FixYa! (100)
Benimur
Rank:Guru Guru
Rating: 87%, 2426 votes
Your post/description could be indicative of just that, your unit can no longer read the disc.
This could be brought about by:
1. dirty, dusty, smeared optical lens or the laser eye;
2. stuck lens carriage;
3. defective laser eye.
#1 could be corrected with the use of a CD cleaner commonly available at computer stores/shoppes. Alternately, you can use a fine, clean small brush;
#2 if visible on top could be cleaned with cotton buds and household alcohol. You need to re-lube when it has dried up;
Additionally, a can of compressed air would also be of help in removing any dust or foreign materials inside the disc mechanism.
#3 would require the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Comment by Benimur, posted on Feb 19, 2008
Hi again,
Am glad to be of assistance and appreciate the rating.
My apologies for giving you the impression that the lens need to be re-lubed. It is the carriage where the lens sits on that needs to be re-lubed as well as the shafting that guides it. Please refer to the image below.
Cheers.
Rating Locked! (?) Neozim11 has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Constant 'Err' and 'No Cd':
I don't want to Accept this solution
Can you Help with these Boomboxes problems?
Boomboxes
This unit has no output to the speakers. The headphone...
Boomboxes
I've bought a Sanyo DMP-M600 from Japan recently. I've got...
Boomboxes
I have a three cd changer that was given to me, used. It...
Boomboxes
It takes a few tries to turn the disc portion on and when...
Boomboxes
I select function and tape, however, neither tape deck...
Loading problems.
Repair Service
Find Boomboxe Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
