Question about Honda Karcher G2400HH-R Pressure Washer
Honda 2400 psi before it went out i cold tap the end of the wand on the ground and the pressure would return now when pull the trigger there is no pressure only a fine spray .its a karcher with a honda motor thanx
  • Bernie Goncalves May 11, 2010
    it sounds like you have a bad pressure solenoid valve,this is how it knows when to turn on the pump pressure .you can search the web under karcher and you will see the valves for about 60 dollars.
  • 251 Answers
there is a small ball bearing inside the nozzle on the end of the lance , this can get jammed or missaligned and the nozzle orifice can get blocked , clean this or replace the whole lance with another 200 Bar lance .
hope this helps
Posted on Feb 02, 2010
Pour some 3 in 1 oil in the pump inlet without hoses connected. Fire up and shut off in a few seconds, repaeat a few times. Hook up water hose not the wand hose, blow oil out. In the wand itself, spay WD40 in the inlet and blow through it making sure the trigger works. Mines been running years!
Posted on Jun 29, 2010
  • Zoli Semanate
    Zoli Semanate Jan 14, 2015
    Also if you loose pressue and the bove doesnt wortk. Its your unloader valve sticking. Pop the plastic umbrella thing off. Siply pry off the big rivet in the plastic. Unscrew the top and pull barrel thing out. Straighten shaft if bent, clean, and grease barrel with waterproof grease if available (Bel Ray motorcycle), Re assemble. Should work as new. My machine running top shape 14 years now.
  • Zoli Semanate
    Zoli Semanate Jun 12, 2016
    Follow up: My machine is now 16 years old and running like a champ. Ive had to replace O-rings in wand hose and above mentioned greased unloader valve that's it. I use Mobile 1 synthetic in motor. Like a champ.
How do I keep wand from blowing off trigger
Push it on and turn it, it should lock in place,
Jul 11, 2014 | Honda 2500 PSI Gas Pressure Washer
I have a Honda XR2600 pressure washer. When the wand trigger is pulled, the throttle does not open, the RMD just drops. If i manually open the throttle, it works fine.
Your engine produces max horsepower at 3600 rpm. The engine throttle should be set to max before you pull trigger. Pressure washes generally do not have automatic throttle. You do not have to use max power, but enough power to keep the engine running when trigger is pulled. You washer will actually last longer if you only use about 75% of rated capacity. Good luck
Oct 15, 2011 | Karcher 2500 PSI Pressure Washer
I have a Honda GC160 5 horsepower power washer with 2400 psi. When its cold it is easy to start but after it has been running for a while the only way to start it is to have the water shooting out of the...
you are not choking it for warm restart are you?? maybe you have a carb clog issue?? try running seafoam in your gas for a tank or two...just 2 ounces at a time is good. dont overdo it!!
Jun 29, 2017 | Garden
Let go of wand trigger pressure will not come back
spill valve is stuck and needs to be cleaned and greased common problem....also check all connections for blockage in line
Jul 21, 2010 | Karcher 2500 PSI Pressure Washer
Starter cord wont pull
Try removing your spark plug, you could have fuel on top of the piston or even "vapor lock". If that doesnt work try squeezing the trigger of gun/wand as you pull.
May 31, 2010 | Honda Pressure Washer PSI 3000
New Troy-Bilt 3000 psi - Very Hard to Hot Start
When you run the unit and shut if off, release the pressure from the spray wand before trying to restart the engine. This built up pressure will cause it to be very hard to start as you have found out. If it does not start on the second pull release the pressure again. Another option is do do what I did on mine. I simply put a pull tie on the handle so I can pull the trigger back and use the pull tie to hold the trigger open. Make sure if you do this, that you remove the high pressure orifice from the end of the wand before attempting to start the engine. Otherwise the pressure will come on abruptly and could injure you or do property damage.
Apr 25, 2010 | Briggs & Stratton Prosumer 20324 Gas...
I have a karcher 2400 psi pressure washer and it doesnt get water pressurized when pulling wand trigger.
the most comon problem with thease is a stuck bypass valve, this is the valve that alowes the water to bypass round the pump when the triger is closed, when they stick all of your pressure runs around the pump and not out of your nozzle,,
its located in the centre of the pump on the top, undo the 2 cap screws pull out valve greese and re fit
Jun 08, 2009 | Honda Karcher G2400HH-R Pressure Washer
Whe using the honda 3000 psi power washer, I've
Are you putting the soap nozzle on the end? Either that or depending on what type of nozzle you have, some times you pull out or push in the nozzle to switch it to soap.
There has to be no pressure to draw the soap, so you either have to put in the soap nozzle in, or if it has an adjustable end, set it to soap by pushing or pulling.
You cannot spray high pressure with soap unless your unit is equipped with another siphon hose for pressure soap.
May 03, 2009 | Garden
Pressure is fine when first started ,if trigger released no Psi
Your uplift injector valve in the water pump is sticking. You need to remove this part. Lube the top o-ring only with a water proof grease. Reinstall this part. You will be up and running again.
You need to use needle nose vise grip tool to easily remove the valve. You need to grind down the vise grip tool to fit the opening where the valve is installed.
To prevent this problem from reoccuring use a pump guard additive.
Apr 05, 2009 | Karcher 2500 PSI Pressure Washer
Honda Karcher G2400HH-R Pressure Washer Logo
873 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
