The washer does not always empty all the water. Need to go to another cycle to complete the emptying of all the water
    President:
  • 842 Answers
Probably a blocked filter. Take a look at my article http://www.fixya.com/support/t3144835-not_draining_water_not_spinning I hope this will help you
Posted on Feb 02, 2010
I have an Amana front load washer, it will run through a complete cycle when empty but will not run with a load in it.
Hi Ben
I see you have posted on this before , I think you may have done this already judging from your post , but have you checked the filter on the drain pump? also when you run a cycle empty, is it filling and draining the water correctly , or is there water left in the machine , and last is the drain hose high enough to make sure that there is not a "syphoning" effect taking place as in when it fills with water it drains at the same time , just a thought let me know.
Oct 13, 2017 | Amana Front Load Washing Machine Washer...
Will not rinse or spin
I have had similar situation with my top load washer over the years. It has been the timer 3 times and the water pump 1 time.
How I came up with it being the timer. The knob which you set it on the type wash you want. Put it on a different cycle and see if it completes the wash cycle. example if my washer is not working when I put it on heavy wash cycle I might put it on the casual wash cycle. If you change the wash cycle and it goes through the complete cycle it is probably the timer which is part of the knob you change for different wash cycles with.
If it stops when it is time to empty the tub on all cycles it may be the water pump which empties the tub. The one time I had a problem with the water pump it was a small piece of coal had the pump locked up. I never figured how it got out of the tub and to the pump but I put it back together and it worked fine.
It should not go into the spin cycle if the tub is full of water.
Two of the timers I bought cost 40 - 60 dollars. One was 140 dollars I bought a new washer that time because the washer only cost 220 dollars.
Dec 03, 2017 | Estate Washing Machines
Dish washer will not empty all the way out when cycle is complete
Try checking the outlet pipework, it may not be all downhill, problem with dishwashers is they tend to have standing water in the drain, you need to make sure the pipe has a good tilt, and flush your pipes regular with a cleaning agent for dishwashers.
Jun 09, 2012 | Dishwashers
Machine doe not appear to spin completley
The pump relay is cutting out so a replacement is in need
May 15, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
There is always water in the drum even after a laod but after it sits empty the tub fills with more water
This might be a problem with your locking mechanism which is preventing the washer from actually performing a complete spin cycle. It will drain and appear to function but the high speed spin never actually takes place.
Aug 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Drum will not empty water
sounds like its not going thru the complete spin cycle and empty could the timer control switch its all intergrated in one all the the different application s the cycles goes thru all report back to the timer control switch and when the cycle is complete the timer goes to the next cycle i f the timer is defective it well keep on going reguardless and go to the next cycle unfortunately the cost will run around 250.00 for the part good luck
Aug 10, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Door locked and will not open. i ran an empty cycle to see if that would work and it doesn't.....thanks! Margit
IF water is left in machine then door wont unlock, check pump, run drain cycle. If pump runs but doesnt remove water, then check filter at bottom (small door on bottom front) water will come out when this is done. If washer is completely empty of water and door locked then you may access lock release tab from bottom or reaching down from top to lock asm. Then check lock
Jul 19, 2009 | LG WM1814CW Front Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
