Question about LG CED 8120B CD-RW Burner
Install to computer problem
Trying to install the 32x32x52x CD-RW&16X DVD-ROM Combo Drive tomy Dell Computer. It does not read it, it says secondary hard drive not found.
    Brigadier General:
  • 6,966 Answers
Sounds like a case of jumper settings. If the CD-RW was installed as secondary IDE to an existing hard drive which is the Master, pls set jumper to SL. They are located at the rear of the CD unit between the IDE connector and the audio out.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 19, 2008
  • Louie  Role
    Louie Role Feb 19, 2008
    Sorry, the "secondary IDE" should read as slave IDE.
HELP MY COMPUTER WONT READ ANY CD'S EXCEPT A DVD,, WHAT IS THE PROBLEM?? ANY HELP
hi
you have either one of these ..
5187-5619 = DVD-ROM/CD-RW combination drive - 48X CD-R write, 32X CD-RW rewrite, 48X CD-ROM read, 16X DVD-ROM read
EL436-69001 = 48X DVD-ROM CD-R/RW optical drive - 48X read, 32X read, 48X read, 16X max write speed
make sure you buy CDs or DVDs which are speed compatible to your optical drive or COMBO drive speeds
if you are busying compatible speed CD media, then take some compressed air (can) and clean the drive bay and inside the optical drive area, to dedust it .
go to this site and review all the related sites .. read carefully and try to figure out what the possibility (issue) is .
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=15887&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=431075
if ALL this fails, you may have to replace the DRIVE itself
i hope this helps
Nov 08, 2010 | HP Pavilion a705w PC Desktop
I have a HP model dvd1040i-H16 Super Muti DVD Writer Man.Date april 2007.I'm trying to install in a Dell GX 260 is this player a IDIE Cable or Sata?I don't think Dell supports Sata is there some way to...
Should be IDE cable...IDE interface according to the specs. You computer has IDE connections so the drive should work.
Product Specification Model HP DVD1040i Lightscribe 20X DVD Burner/Black/Retail Manufacturer HP Mfr Part # DVD1040i Buffer 2MB Interface IDE
Include
  • Internal DVD ±R/±RW drive with DVD±R up to 20X, double-layer recording, DVD-RAM, and LightScribe direct disc labeling
  • Software CD including electronic user's guide
  • Quick-Start placemat
  • Getting Help guide
  • Installation screws
  • Nero 7 Essentials
Data Transfer Rate (Read)
  • DVD-ROM up to 16X (CAV)
  • CD-ROM up to 48x (CAV)
  • Data Transfer Rate (Write)
  • DVD+R up to 20X (CAV)
  • DVD+RW up to 8X (ZCLV)
  • DVD-R up to 20X (CAV)
  • DVD-RW up to 6X (ZCLV)
  • DVD+R Double Layer up to 8X (ZCLV)
  • DVD-R Dual Layer up to 8X (CLV)
  • DVD-RAM up to 12X (PCAV)
  • CD-R up to 48x (CAV)
  • CD-RW up to 32x (ZCAV)
  • Access time
  • DVD 160 ms
  • CD 160 ms (typical)
  • Supported Disc
  • CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
  • CD Text, CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM
  • OS requirement
  • Windows 2000 Professional SP4
  • Windows XP Home edition
  • Windows XP Professional
  • Warranty 1 Year Weight 3.3 lbs
    Jan 12, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
    Optical drives do not recognize disk when trying to load new disk
    If you cannot read those CD-disks in _any_ computer, then the disks are "bad".
    If you can read those CD-disks, then it's time to replace the CD/DVD drive. Find a smaller computer-store -- often they will remove the "dead" drive, and install the "new" drive, for $0.00, or for a small fee, if you buy the new CD/DVD-writer from them.
    Nov 18, 2009 | Dell Inspiron 530 -Intel® Pentium®...
    How to install samsung sh m522c without
    goto samsung website you should be able to find the driver you need and dwn load it. If you don't have internet access right there you can download it from another computer with web access onto a flash drive and put it on your computer.
    Oct 30, 2009 | Samsung SH-M522C/BEBE 52X32X52X/16X IDE...
    My cd rom in not on my computer anymore and will not read a cd how can i reinstall it
    Try to visit the dell or cd/dvd manufacturer website and download the proper driver for the model of the cd-rw/dvd-rom drive.
    Sep 26, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
    DELL laptop does not read blank DVDs
    the combo drive you listed above is a cd-rw/ DVD-ROM....meaning that it will play and burn cd, cd-r, and cd-rw disks. the dvd rom will only be able to play dvd-rom and dvd-r disks providing they are in the proper format. check that the disk in question is not a dvd-rw or (+2) disk. the drive will not recognize that a disk is in the drive if the disk isnt compatable. try a dvd movie, if that works then a dvd-r, if that works then try a dvd-rw +1. if the last option doesnt work then you will have to stick with the dvd-rom and dvd-r, or purchase a dvd-rw drive to install.
    GOOD LUCK AND DONT FORGET TO RATE MY POST!! :D
    Mar 18, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
    Cd rom drive
    Hi
    Please use the Cd/Dvd Drive with the following specification:
    CD-ROM/DVD-ROM/Disk drive
    8X max DVD+/-RW Drive with DVD+R double layer write capability
    Or
    16X DVD-ROM drive, 16X/10X/40X CD-RW drive
    Regards
    ELLIN
    Sep 20, 2008 | Dell Dimension 8200 PC Desktop
    Pc died
    Hello, I have had similar problems with that same motherboard in the past and have found that resetting the cmos (see users manual) or just taking the battery of the motherboard for a few minutes can solve this. CAUTION please remove the power lead on your tower before touching any components inside, and earth yourself first by touching metal.. as static discharge kills pc components..
    Hope this helps.....
    Tony.
    Sep 09, 2008 | ASUS K8N4-E Deluxe Motherboard
    Sony CRX300E CD-RW/DVD-ROM Combo - DVD doesn't read
    do you have software/program that supports DVD.
    Try a different DVD/Movie/Disk or alternative.
    Also install a program, such as Nero which will give you physical characteristics of the drive.
    Finally go to device manager, and remove or uninstall the device, reboot the computer and setup again. This can sometimes remedy the problem.
    ensure that the drive is set as Master/Slave. if on the same Bus/IDE channel as a hard-drive. set as master/slave opposite to what the hard-drive is setup as.
    Hope this helps.
    Mike @ Compurepair.
    Feb 24, 2008 | Sony (crx300e) CD-RW/DVD-ROM (Combo)...
    My dell inspiron4150 notebook is my problem
    Trying this should sort it, if not a drive fault:- Right click My computer>properties>device manager>hardware, then on CD/DVD devices line, click '+' sign then right click on your CD drive and click uninstal. Re-start your notebook and Windows should find it again and install drivers automatically. Try a cd in see if any better. Please rate solution
    Nov 20, 2006 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
    LG CED 8120B CD-RW Burner Logo
    149 people viewed this question
    Top LG Computers & Internet Experts
    Alun Cox
    Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
