Question about Bosch 1274DVS 3" x 21" Belt Sander
The pad between the bottom plate and sanding belt is worn, torn, and folded/disfigured on one corner. What is it's function and where can I get a replacement?
    Problem Solver:
  • 14 Answers
I've replaced this on mine several times (they're under $4, so I've got a few on hand), and wonder if the sliding plate should be cemented to the base plate in some way. Of course, then it wouldn't be a "sliding" plate, but maybe it wouldn't tear itself to pieces...
Posted on Oct 20, 2011
  • 154 Answers
That pad is usually made of cork or graphite It's used to give the back side of the sanding belt a soft and slippery surface to run on so it won't over heat/tear and fail. The part you need is P/N 2601098037 Any Bosch service center will be able to get one for you. Go to BoschTools.com and look under "find a service center"
Posted on Feb 11, 2010
How to change sanding pad
Here is a link to the manual to your Royobi p400. You can download it. Tried to copy & paste the illustrations but they did not show up. Go to page 14 of the manual. Looks pretty easy, just peel down from top. Good luck. & happy Sanding.
CHANGING SANDING SHEETS AND PADS
HOOK-AND-LOOP
See Figure 8.
PAD
The sander is packed with sanding sheets and scrubbing
pads designed for a variety of uses. To change sheets and
SANDING
pads, simply pull the used sheet off the base and attach the
SHEET
desired sheet by pressing the sheet or pad onto the base
of the sander.
ROTATING THE SANDING SHEETS
See Figure 9.
The majority of wear in a precision sanding application occurs
at the tip of the sanding sheet. The unique Tri-Flex design of
the sanding sheets allows you to detach and rotate the top
two thirds of each and extend the life of the sheet.
To rotate the top of the sheet, simply remove the top two
thirds along the perforation. Rotate the sheet so that a clean
corner is located at the tip of the base. Press the sheet firmly
onto the pad.
NOTE: Scrubbing and polishing pads are not perforated
and cannot be rotated.
Apr 24, 2014 | Ryobi P400 18 Volt Corner Cat S
Honda mower drive cable
The drive belt may be worn and slipping on the pulley. (assuming it is a belt driven model). This would cause the mower to lose a great deal of power to the wheels. By adjusting the cable only, you are effectively adding a little more friction to the belt/pulley interface which in turn will provide a bit more power but the belt may still be slipping on the pulley(s) which is where you could still be losing the majority of your mowers self propulsion. Some Honda models may also employ a belt tensioner that simply adds tension to the belt even if the belt becomes stretched out & worn but the pulley's can become glazed (slippery). If it is a direct "pulley to pulley" drive with a single drive belt (no tensioner) the worn belt can also glaze the pulleys and cause further slipping. You can reface your pulley(s) contact surfaces with a very light grade wet sand paper (1000 grit), a coarse grade steel wool or a scotchbrite abrasive pad, thereby giving the belt more "purchase" on the pulley(s) contact surfaces. If you do perform a refacing of the pulley(s), it is strongly advised that you replace the drive belt as well. Your mower will then function as it did when it was new. Hope this helps.
Mar 29, 2014 | Garden
Re - Phaser 8200DP Solid wax printer; very often doesn't pick up paper from bottom tray, resulting in 'jam' message. Also, tends to fold the top corner of a two-sided (duplex) print job on exiting after...
Clean the pick up rollers with alcohol. They need to be really grippy.
If it's folding the corner of paper I expect there is a bit of torn paper stuck in it.
Oct 29, 2013 | Xerox Phaser 8200 Laser Printer
My Porter Cable 4" Belt
I would check both rollers for debris on them, also check the plate on the bottom for unusual wear, be careful for sharp edges and make sure the front of the plate is not worn excessively. Then I would turn the front roller without the belt on it to make sure not out of round and moving smoothly. Lastly if you are using directional belts make sure installed properly with the arrow pointing to the front of the sander. Let me know if you need more help before voting and I will see what I can do.
Feb 13, 2011 | Porter Cable Cable 363 4" x 24" 1500 SPFM...
The flexifoot on my old baracuda is split
What do you mean by flexifoot, and what do you mean split? The large rubber disc is called the "durometer" disc (on the G3 it's called a finned disc). The small rubber pad the the big one fits over is called a "foot pad", the foot pad fits over a hard piece called the foot plate. That being said.... if your referring to the durometer disc being split, or torn, I assume it is very worn out and needs to be replaced. if it's new and torn then it may still work fine. if it is worn out chances are you need to replace the foot pad, and possible a couple other pieces.
Sep 16, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
I can't get the velcro pads to stick to my Ryobi RS280VS sander
Sounds like it is time for a new backing pad. Usually the hooks get cooked and/or caked so that they don't have the "claws" to grab the fuzz on the sandpaper. If this is a well used backing pad, the hooks eventually just break off from heat and wear.
Nov 28, 2009 | Ryobi Tools & Hardware - Others
I cannot remove the plate to pute the other plate on
Here's a copy of the manual instructions...
Detail Sanding
Your tool is equipped with a teardrop base which allows you to use it on large flat surfaces
and tight spots or corners.
The pad tips may wear unevenly, depending on use. The pads are designed to allow you to
interchange and /or rotate the diamond tip.
Fitting Sanding Sheets ( Fig. 2)
• Detach the two diamond-shaped tips from the sanding sheet.
If this doesn't provide enough information, take a look at the pictures in the manual at the following link: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/589307-02,MS550GBMS550GH.pdf
If you still have difficulty getting the base off, write back and let me know specifically what the trouble is and I'll try to help you with it.
• Hold the tool with the sanding base facing upwards.
• Place the sanding sheet onto the sanding base.
The diamond-shaped tip can be reversed and replaced when worn.
• When the front part of the tip is worn, detach it from the sheet, reverse it and press it onto
the sanding base again.
• When the whole tip is worn, remove it from the sanding base and fit a new tip.
Tip of the Sanding Base ( Fig. 3)
When the sanding base tip is worn, it can be reversed or replaced.
• Remove the screw.
• Reverse or replace the worn part.
• Fit and tighten the screw.
Finger Attachment ( Fig. 4)
The finger attachment is used for fine detail sanding.
• Remove the screw.
• Remove the diamond-shaped tip holder from the sanding base.
• Fit the finger attachment onto the sanding base.
Contour Holder Attachment (Fig. 5)
• The contour sanding pieces are for sanding curved surfaces and grooves.
• Remove the screw.
sanding base.
• Fit the contour holder onto the sanding base.
Fitting and Removing a Contour Piece (Fig. 6 & 7)
• Choose the contour sanding piece profile most suitable for your application.
• Place one end of the contour sanding piece into the recess at
the front end of the profile holder.
• Push the other end of the contour sanding piece until it clicks
into place.
To remove the contour sanding piece, push it forward then pull the rear end out of
the profile holder (fig. 7).
Fitting a Sanding Sheet Onto a Contour Sanding Piece (Fig. 8)
• Align the sanding sheet with the contour sanding piece.
• Press the sanding sheet onto the contour sanding piece, making
sure that the sanding sheet follows the shape of the profile.
Mar 23, 2009 | Black & Decker MS550GB Mouse 5 Amp Detail...
Roller on a hoover turboPower 3100 fold away won't turn
the top hood will come off. there should be 2 screws under the front corners and 2 more on top toward the rear of the hood. lift hood off. this will expose another cover, simply remove these 3 screws to get to the roller and belt
Jan 14, 2009 | Hoover U5178-900 Vacuum
Face plate
the face plate is not removable it only folds down
Apr 10, 2008 | Pioneer DEH-P6600 CD Player
ROLLER BRUSHES WON'T ENGAGE
THESE BRUSHROLLS HAVE A RUBBER PAD WHICH IS CALLED A CLUTCH PAD. THIS MAY BE WORN, OR THE SLIDERS MAY JUST NEED A SMALL WASHER WHICH YOU CAN GET FROM YOUR LOCAL RICCAR DEALER. ALWAYS MAKE SURE YOUR LINKAGE ROD IS CONNECTED PROPERLY. ROD SHOULD BE ON THE BOTTOM PLATE SIDE, IF YOU HAVE THE MACHINE TURNED OVER WITH THE BOTTOM PLATE OFF IT SHOULD BE ON TOP OF THE BRUSHROLL.
Oct 27, 2006 | Riccar 8955 Upright Vacuum
Bosch 1274DVS 3" x 21" Belt Sander Logo
260 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Tom Chichester
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
