Question about Ovens
I have a Chef Select Plus fan forced oven which stopped working. The fan works and the lights come on but it doesnt heat up. I have no instructions and dont know how to get the element out. Any help would be great.
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    barkencoa
    • 3463 Answers
    SOURCE: smeg oven
    Sounds like you need a new oven element fitting.
    Posted on Dec 08, 2008
    SOURCE: I have a Chef Select Fan Forced wall oven Model
    I have had to get an electrician to replace thermostat.
    Posted on Dec 10, 2009
    SOURCE: creda europa solar plus double oven
    Hi, hold down the minute and cook button and at the same time hit either the plus or 1 button to set a time and then oven will work. each time the power is off this needs to be done. hope this helps
    Posted on Sep 26, 2010
    SOURCE: manual for chef select fan
    David, I had the same problem. Try viewing this video - it worked for me.
    best regards
    Bob
    http://www.ehow.com/video_7508261_remove-oven-door.html
    Posted on Jan 01, 2011
    Have a chef fan forced wall oven model number EOC624W - everything working except there is no heat
    Check the house circuit breaker for the oven. If 240 isn't present, everything else will work except the heating element. The circuit breaker will have it's handles joined so if one trips they both trip. Unfortunately, this doesn't always work, Meaning one can trip without tripping the other so only 120 volts is supplied to the oven.
    Dec 13, 2016 | Ovens
    Chef Norfolk Deluxe fan forced oven. Oven, lights and separate grill - all lights went out, lost heat and stopped working.
    there is a fuse inside the plug,unplug it to check it,please report the other posts
    Jun 15, 2015 | Ovens
    I have chef EGC651S oven with separate grill. On fan assist oven only heats up to a certaain temp and doesnt get any hotter what could be the reason for this
    Probably thermostat problem, although some chance you have one side of a 220vac breaker not working. In otherwords oven heating element is "getting" half of the required power. Call electrician!
    Mar 08, 2015 | Ovens
    My Chef Classic Wall mounted fan forced oven stopped working. Its grill section working. Fan and the light in the oven working well. Bot oven doesnot heat up. Please give a tip what is probably wrong?
    The bake element has gone bad. They can visually look fine but still be bad. To check and replace that element you will unfortunately need to kill the power and remove it from the wall. Remove the back cover. Check for a low resistance (around 16 ohms) across the bake element. If the resistance is high the element is bad. Google the make and model for a replacement element.
    Dec 26, 2014 | Magic Chef Ovens
    Where can I source a Chel Select Fan Forced Oven Manual from please?
    You can try searching for Chef Select online but the age of your oven may make your search unsuccessful.
    Jul 28, 2014 | Ovens
    My Chef Select fan forced oven has no heat. I have replaced the fan motor and the element, but still no heat. What else could be wrong with it?
    Check that it is not been set on automatic. Try turning the timer /clock control through 24hrs and it may go click, fixed
    Feb 21, 2013 | Ovens
    I have a fan forced chef classic wall oven and the fan has stopped working....why ould this have happened/
    There has several reasons the fan could have stopped working:
    -It is possible the fan wiring/connections have become loose or unplugged
    -It is possible that the fan motor has worn out or become jammed over time due to debris
    -If you recently cleaned your oven, the fan could have stopped working if it came into contact with any caustic oven cleaner.
    Hope this helps.
    Feb 28, 2011 | Ovens
    Used self cleaner on my Kitchenaid oven and now oven doesnt work.... not the household fuse any suggestions
    Is it a fan forced oven? Does the fan and the light come on when you turn it on but no heat?
    Feb 06, 2011 | KitchenAid Ovens
    Don't know how will the chef premier fan forced grill work please help thanx neha
    The fan radiates the heat to the food to be cooked in the steady heat . when the heat is modest the fan does the convecction well to keep all the areas well heated.
    So use only the required heat and the best timing
    Sep 11, 2010 | Ovens
    Ovens Logo
    933 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
