Question about Canon PIXMA iP3000 InkJet Photo Printer
Printer has no Power
I've check and verified that:
1. there is no cut/scratches on the power cord
2. properly connected in a 110V AVR. proven that AVR is working as well. tested in two different 110v power outlet.
Before this thing happened, some times when we turn on the printer it doesnt turn on. It will take 2-3 times pushing the power button before it turns on.
Another I thing that I have observed, not sure if related, wheneve I print something in draft there's a noticeable printing sound, just like the sound of an old printer.
  • phinmang Mar 25, 2008
    Yup, same thing. Was working, now nuthin'.
Hope you dont mind me joining this discussion. I have the same promblem no power on my Canon MP600. Had this printer for about 8 months and hardly used. Printer on Surge protector, cables connected properly, tried diff. outlets and power cable but still nopower.
Posted on Feb 29, 2008
    Genius:
  • 3,587 Answers
How long has the printer been in your family? sounds like it's starting to let you know it's on it's final episode.
Posted on Feb 19, 2008
Last night I cut my computer off and it froze on the shutting down screen so I held down the power button and it cut off. Now when I cut it on the light on the monitor is orange. It's Gateway 817GM. Help?
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Jun 27, 2014 | Computers & Internet
HP F4140 Printer - all lights flashing, blinking E
This is a printer hardware error, you cant try below reset methods.
Power Drain:1. Unplug the printer power cord from wall and the printer, disconnect USB cable from printer.2. Press and hold the power "ON/OFF" button for 30 seconds and release it.3. Connected the power and check the printer.
Dec 08, 2011 | HP DeskJet 6988 Printer
Lexmark E450dn will not power on, power cord is working
This issue may be due to one of the following:
  • An incorrectly set power switch.
  • An improperly functioning power outlet, surge protector, or power supply backup.
  • A poorly connected power or data cable.
  • A defect with a third-party (i.e. non-Lexmark) option such as a memory card.
  • An incorrectly connected or malfunctioning optional paper tray.
  • A malfunctioning printer component.
Please try the following steps:
Step Action 1 Make sure the power switch is in the "on" position. If it is, power off the printer. 2 If your printer's power cord is plugged into a surge protector or uninterruptible power supply (UPS), unplug it and connect it directly to a grounded wall outlet. Some of these devices can interfere with consistent electrical flow and cause the printer to fail to power up properly. 3 Disconnect the power cord from the back of the machine and then reconnect it. Make sure the power cord is plugged in all the way. 4 Disconnect any data cables (parallel, USB, Ethernet) from the rear of the printer. Any defect in a data cable may cause an electrical short circuit that could cause a loss of power to the printer. 5 Turn the printer on, this time with only the power cord connected and plugged directly into a grounded wall outlet. 6 If the printer still fails to power up, power off the printer once more. Verify that the outlet is working properly by connecting another device to it to see if it receives power. You can also try plugging the printer into a different grounded outlet. 7 If possible, try another printer power cord. 8
Verify that the printer is the correct voltage type for the environment in which it is being used. A 110V (low-voltage) printer will not work properly in a 220V (high-voltage) environment, and vice versa.
  • NOTE: Look at the rear of the printer and locate the electrical specifications sticker. Verify that the voltage rating on the sticker is the correct voltage for your printing environment (i.e. 110V or 220V).
9
Remove any third-party (i.e. non-Lexmark) options, such as memory cards, as they may interfere with proper printer functioning. Also remove any paper-handling options such as an optional second paper tray. 10
Attempt to power on the printer once more with all options removed, having verified that other devices work from that power outlet.
If there is still no power, the printer may require service to fix the issue. Please contact Lexmark Technical Support or a local service provider.
Oct 14, 2011 | Lexmark E450dn Laser Printer
Fax says phone off hook
  1. Unplug the power cord from the back of the printer and from the wall outlet. Reconnect the power cord to the wall outlet, but don't connect the power to the printer just yet.
  2. Perform a partial reset by disconnecting the power cord from the wall. Then, hold the # and 3 while reconnecting the power cord. Release the buttons once the cord is plugged in. When you release both buttons, the issue should be resolved.
  3. Perform a semi-full reset if the partial reset did not work by pressing and holding # and 6 while reconnecting the power cord to the printer and hold for 1 min after plugging in the power cord. When you release both buttons, the issue should be resolved.
  4. Verify that the phone cables are properly inserted into the wall jack and the back of the printer if you are receiving a "Phone off the hook" error message.
Jan 11, 2011 | HP Officejet 5610 All-In-One InkJet...
My printer is showing error oxdo5do1od recycle power how can i over come that
Please perform the following steps:
Step 1: Power Cycle
1. “Shutdown” your computer.
2. Verify that the unit is switched ‘on’.Unplug the all-in-one from power and ‘disconnect’ the connection port.
3. Wait 30 seconds.
4. Plug-in only the ‘power cord’.
5. Repeat steps 2-4 two more times.
6. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
7. Restart your computer and check the functionality.
Step 2: Partial reset:
1. Unplug the power cord from the unit.
2. Press and hold # and 3 buttons together while plugging in the power cord back to the unit.
3. Turn on the unit
If the issue persists, perform the following:
Step 3: Semi ful reset:
2. Press and hold # and 6 buttons together while plugging in the power cord back to the unit.
3. Turn on the unit.
If the issue persists, pleae conect the unit to a diffrent power out let. Also please chek if the unit works fine in the stand alone mode (with out connecting to the computer). If the issue persists, replace the printer
:) Dr Tony
Apr 19, 2010 | HP Officejet 5610 All-In-One InkJet...
I have a All in One HP Printer 1210 - it does not seem to want to print. The check paper and check cartridge lights are flasing. There is no paper jams and the cartridges are in the machine properly. ...
First, make sure your printer is not plugged into a surge protector.
Then, try a reset of the printer:
Follow the steps below to power cycle your all-in-one:
1. Verify that the unit is switched on. Unplug the all-in-one power cable from power socket and disconnect the connection port(USB cable).
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
Semi-full Reset :
To perform the semi-full reset on the printer, Disconnect and then reconnect the power cord. When the lights begin to flash, press and hold the On/Resume and Number of Copies buttons. When only the On/Resume light is flashing, release the buttons. When the On/Resume light is steady, the reset is complete.
Mar 21, 2010 | Office Equipment & Supplies
I also have HP 6310xi all in one printer with power reset message
1. Please make sure that the power adapter is working properly. Also connect the unit to a different power outlet and verify.
If the issue persists, please perform the following steps:
Step 1: Power Reset:
1. Disconnect the unit from the computer. Verify that the unit is switched ‘on’. Unplug the power cord from the back of the unit.
2. Wait 30 seconds.
3. Plug-in only the ‘power cord’.
If the issue persists, perform the following steps:
1. Take the cartridges out of the unit. Unplug the power cord from the unit.
3. Turn on the unit and insert the cartridges.
This will solve the problem...
Jun 23, 2009 | HP Officejet 6310 All-In-One InkJet...
My computer cant find my printer its a lexmark 2600
Have you tried the following steps?
1. Power off your computer.
2. Power off the printer and remove the power cord.
3. Check the cable connection between the printer and the computer to make sure it isn't loose.
4. Put the power cord back in the printer and power it up. Do all lights show up as normal? Green? Or are some flashing?
5. Power on your computer.
6. Under the printers folder, right click the installed printer and go to properties. Print a test page.
How is the printer connected? USB or parallel port?
Apr 19, 2009 | Office Equipment & Supplies
Won't turn on
If you do not have a volt meter, there are some things to try. The first couple of things sound silly at first, but we have to check it.
1. Plug something else in the outlet you use for your printer...verify the outlet has power. You probably use a surge protector (power strip) and we need to verify it has power.
2. Remove the power cord from the printer (if it is the type you can take out) and swap it with the power cord for the computer. A cord we know works! The cord may be loose where it connects to the printer...and snug in the wall.
3. If this fails to get the printer going, we'll need to take a look inside and make sure no fuse or overload switch is tripped or blown.
Good Luck!
Apr 07, 2009 | HP Photosmart 8250 InkJet Printer
Hp photosmart C5250 all in one
Thank you for the information
Please check if you have inserted any Memory Card into the All-in-One.
1) Connect the printer directly to the wall outlet and
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
Please perform the following steps to reset the printer to factory settings.
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord
Regards,
Sagarjd
Jul 25, 2008 | HP Photosmart C6180 All-In-One InkJet...
Canon PIXMA iP3000 InkJet Photo Printer Logo
115 people viewed this question
old marine
old marine
