Question about Refrigerators
I have a frigidaire refrigerator with top freezer. model frt21nfrd2. About 12 years old. With a light inside you can see light in the top right of the refrigerator door. Seems to seal good every where else. The freezer door was eazy to align, but how do you align the bottom door. I loosened two bolts at the bottom hinge and had someone try and lift the door but did not help. I did not know how much pressure to put on the door--can't afford to buy one right now--and I did not want to take the bolts all the way out. Any help or advise would be greatly appreciated. I am certainly a novice at this type stuff. Thanks
    President:
  • 1,218 Answers
Good day,
If you need to lift the main door, first remove all product from both doors. Shut off the machine. Too much stress on the compressor running with no doors.
Remove top cabinet bracket for the freezer door and lift freezer door off.
Remove center bracket, and lift main door off. Keep track of all shims and spacers.
You wil need additional spacers between the bottom bracket and the main door.
However, sometimes the door pin opening on the bottom of the main door has deteriorated and cannot be repaired. Check visually as to it's condition.
If it is beyond repair, then one solution is to reverse the doors to make use of the other side of the main door. Parts may be necessary from your local appliance parts house.
Posted on Feb 01, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
Remove freezer door. now remove hinge on top of bottom door. lift bottom door off. now place a washer on bottom hinge and re install everything. this should solve your problem.
In the house we just bought there is a copper brown top freezer Frigidaire which says it is a Deluxe 17. Cleaned it and plugged it in. Set freezer unit for "normal:" and refrigerator on...
Freezers only buils up layers of ice after multiple opebing and closing of doors allows fresh air inside, the moisture then freezes out of the air and builds up in layers on the cold surfaces. Note that the more ice that builds up decreases the efectivness of the freezr and thus costs more to run. To test try making ice cubes in atray. The number 1 setting on the fridge will be the warmest setting. Hope this helps.
Sep 29, 2017 | Frigidaire 16.5 Cu. Ft. Top-Mount...
My top freezer refrigerators freezer works fine but the refrigerator part does not cool. It is only 2 years old. Any ideas?
t probably needs a defroster timer. You can take it apart and clean the contacts with some sand paper to fix the old one. It's located just behind the light bulb2_bing.gif. You will have to lower the cover for the light to get to it. Defrost the top freezer2_bing.gif by leaving it off for a period of time or take the shelves out and blowing hot air into the rear vents until ice melts. Then reinstall timer and plug back in. Get the whole model number and go to appliancepartspro.com to get a diagram. I fixed mine in less than an hour. frt18il6dw
May 27, 2010 | Frigidaire FRT18B5J Top Freezer...
My frigidaire refrigerator is sweating on the inside. what should i do? its a one door model with ice maker and freezer on top. i don't remember the model. 5 years old.
High humidly could cause condensation or the magnetic seal could be bad.
A couple of things to try;
The easiest thing to do first is to clean around the rubber seal very good with mild soap and water and the metal which the magnetic rubber seal contacts to seal the door. If you find a crack or a deformation of the seal it will let condensation it the refrigerator.
Does the freezer auto defrost or is a lot of ice bult up around the freezer walls? If so manually defrosted the freezer.
Dripping from the Ice maker water supply?
Jul 15, 2009 | Frigidaire Refrigerators
WHERE DO I FIND A REPLACEMENT TIMER DEFROSTER FOR FRTC03L3DS0 ... FRIGIDAIRE MANUFACTURED BY ELECTROLUX ... SMALL REFRIGERATOR WITH FREEZER COMPARTMENT SEPARATE APPX TWO YEARS OLD ... STOPPED COOLING ......
Could you recheck the model number for your refrigerator. The number you listed is for a oven. Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • Thanks, Sea Breeze
Mar 27, 2009 | Electrolux Refrigerators
How old is my refrigerator?
Here is a --->link<--- to download the manual for your unit.
this --->link<--- will allow you the ask Frigidaire what year the unit was manufactured.
hope this helps
clarkco
Feb 17, 2009 | Refrigerators
Frigidaire not cooling & freezing cold enough
We ahve a two year old Frrigidaire Freezer. every year same time it seems to correct itself(?), like self defrosting etc, and takes a long time come back to its cooling level. This is made in brazil G series. Please help.
V/r Syed
Dec 23, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Nov 10, 2008 | Frigidaire FRT15B3A Top Freezer...
Refrigerators Logo
119 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
