Question about Toshiba 32A50 32" TV
No picture Thin line across middle of screen
The tv was working fine but I noticed the picture starting to shrink. If you tap the side the screen would pop back up. Now only a thin line appears. I would like to know problem and toshiba part# to fix if possible.
  • Anonymous Mar 10, 2008
    thin line acrross, sound ok; I resolder all connections on the board ** result.
  • Anonymous Jul 11, 2008
    picture shrink. after tapping the side of the monitor, the picture pops back again. some repair technicians suspect that the part called vertical is loose. how do i fix it?
    Brigadier General:
  • 6,966 Answers
Most problems indicated by your description involved the Vertical IC. With your post "tap...pop back up" signifies a loose connection or to be more specific a cold solder. I suspect that no part(s) need top be replaced but would however require re-application of heat with the use of a soldering iron.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 19, 2008
Hi there My Sansui TV screen started showing thin white horizontal lines across the top of the screen. All of a sudden the screen starts condensing the picture into fine lines across the middle of the...
It is an indication that you have a problem on the vertical section on the main board. The faulty parts is the electrolytic capacitor which affect the linearity of the screen that's why you encountered that kind of problem.
I've advice you to send it to repair shop or look for a qualified technician to isolate the faulty electrolytic capacitor and do re-soldering for some dry joints on the main board.Once replaced the capacitor your unit will back to normal again.
thanks for using fixya...
Jan 07, 2011 | Sansui TVS2750 27"
JVC picture turns into a single line in middle of screen.
This is caused due to random falure of vertical scan circuits. It generally is caused by dried out capacitors or bad driver IC. Unfortunately it will get worse. If you fail to turn the TV off quickly you will burn a permenant horizontal line on the tube. Trip to the repair shop I am afraid.
Nov 30, 2009 | Televison & Video
Black horizontal line across the middle of the plasma TV screen
It could be a defective Y-Buffer board, or a defective Plasma panel.
Oct 25, 2017 | Pioneer PDP-425CMX 42 in. Plasma...
Insignia 32" Tube TV NS-RTV32
The vertical output IC LA7847 is failing. It will likely fail permanately and you will have just the horizontal line. The set will require service. Just do not run the set very long in this state. That thin white line can likely burn into the crt phospher and will show all the time thus ruining the glass picture tube...
Jun 05, 2008 | Televison & Video
Thin line across screen
Sounds like cold solder joints in the vertical circuit and also check around the yoke plug.
Apr 04, 2008 | Televison & Video
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Picture Shortens, Converges, eventually the set shuts off - $50 for Correct Solution
Open the TV amd turn it on in a position you can see the picture, possibly through a mirror. Now gently tap all of the metal heat sinks on the circuit board until you find the one that is sensitive it will have a small chip mounted vertically on it, with probably like 7-10 pins. The number on the chip will most likely be an "LA****" number. Now turn the circuit board (UNPLUG FIRST) over and resolder the pins. This is your problem 99% of the time. Be very careful there is High Voltage inside this TV.
Apr 26, 2007 | Zenith IQB36B42W TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Toshiba 32A50 32" TV Logo
581 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
