No bass HELLO ALL, OUT OF ONE SPEAKER ALL I CAN HEAR IS WHAT SOUNDS LIKE TWEETER SOUNDS. I TRIED REPLACING THE WOOFER BUT NO CHANGE CAN YOU HELP ME FIGURE THIS OUT? ANY HELP WOULD BE GREAT! INFINITY sl-30 BOOKSHELF SPEAKERS
  • 4 more comments
  • hillybill Feb 19, 2008
    IF YOU MEAN THE RECEIVER AMP MAYBE BAD .I HAVE ANOTHER PAIR OF SPEAKERS THAT SOUNDS FINE HOOKED UP TO SAME.
    IS THERE A SIMPLE WAY TO TEST THE PASSIVE CROSSOVER?
  • hillybill Feb 23, 2008
    hello,.
    after running the wires directly to the woofer, it appears to be the crossover that is bad.
    i am curently shopping for a crossover, but have not replaced it yet.
    thanks to both of you for your patience and expertise!!
    m.howell
    hey, thanks for the info!
    i just a novice trying to narrow it down, and with your help and patience i will eventually put this speaker back in service.again, thank you guys very much!!
    m.howell
    hey, its me again i meant to ask you what is a cold solder ? and how can you idenify it
    thanks m.howell
  • hillybill Feb 24, 2008
    HELLO,
    I PUT THE NEW CROSSOVER ON AND THAT TOOK CARE OF THE
    PROBLEM. I JUST WANTED TO THANK EVERYBODY THAT TOOK THE PATIENCE TO HELP ME.YOU GUYS REALLY KNOW YOUR STUFF!! I WILL
    DEFINITLY USE YOUR SERVICE IN THE FUTURE IF I NEED TO.
    THANKS AGAIN!! HAVE A GOOD NIGHT!
    M.HOWELL
    Brigadier General:
  • 6,966 Answers
Since you have replaced the woofer, it is possible that the passive crossover network inside the speaker is the one in question.
Alternately, it is also possible that the signal source (amplifier) that might be the issue. Can you pls try wiring your speakers the other way around - left speaker goes to the right output of the amp and vice-versa for the right speaker. If the problem changes speaker, then it is the amplifier that should be attended to.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 19, 2008
  • 4 more comments
  • Louie  Role
    Louie Role Feb 19, 2008
    Sorry ginko for doubling up. Guess you posted while I was composing my reply. Cheers.
  • Louie  Role
    Hi again,
    Yes there is. Wire the woofer direct to the speaker wire but not the tweeters (or the mid range if any). Pls try at relatively low volume level/settings during testing.
    Cheers.
  • Louie  Role
    Louie Role Feb 23, 2008
    Yo Ginko,
    You think it was fixed?
  • Louie  Role
    and hello again hillybill,
    It is very seldom that crossovers go bad. You might want to have a closer look. It is possible that the problem may be a case of loose connection or cold solder. Normally passive crossovers are a combo of inductors and capacitors. Often the capacitors are for the mid range and tweeters while the inductor or coil are for the woofers. There are even crossovers with no coils but simply capacitors just for the tweeters with the woofer directly connected to the speaker wires.
    In any case, glad that you have figured things out and appreciate the rating too.
  • Louie  Role
    hi,
    A solder joint is a connection used with lead and a soldering iron. Cold solder would then be when the said joint looses conductivity/connection. Normal/good solder would be shiny, bright and silvery in color; on the other hand a cold solder would be dry, dull, grayish in color.
    This link would provide you with images for reference.
  • Louie  Role
    Louie Role Feb 24, 2008
    Glad to be of assistance and appreciate the rating too.
  • 19,396 Answers
If you hear a very high pitch hissing sound coming out from one channel then probably your amp final is gone, in that case you will need to work at component level to fix it
  • 1 more comment
  • Ginko
    Ginko Feb 19, 2008
    If you change speakers and it is fine then is not the amp. In this case is the spekers, maybe a short.
  • Ginko
    Ginko Feb 19, 2008
    No prob ben
  • Ginko
    Ginko Feb 19, 2008
    did you fix it?
Remote reset
Yes the woofer and tweeter can be replaced but the woofer needs a recone kit to repair as the whole speaker cannot be replaced without replacing half of the speaker enclosure.... call JBL pro or a service center for help.
Oct 08, 2013 | JBL EON15 G2 Main / Stereo Speaker
Very little output from tweeters Samson Resolv A6
same issue here, my 6 inch woofer is good but the tweeter is not producing sound, i opened the box myself, theres not signal going to my tweeter, how can i check to see if its a wiring or other issues to diagnose myself? heres some pics
Aug 10, 2012 | Audio Players & Recorders
Why is there four plugs on the back of speakers?
With four plug you will have a jumper from on plug to the other. (e.g. Positive to positive and negative to negative.) This is for single connection (two wires.) If you use two connections (four wires) you take out the jumpers. the bottom pair is normally for the bass and the top for treble. This is to make the speakers clearer, and sound better. As for louder,? I don't know some people think it does some don't. With better clarity of sound, you do get the feeling of it being louder.
Apr 27, 2012 | Audio Players & Recorders
The top part of the mackie speaker isnt working. all that is working is the big bottom part, and the sound sounds like the bass is the only thing coming out.
The typical cause of this is a blown tweeter or the tweeter has broken off of the horn and fallen inside the cabinet. Remove the screws from the horn and carefully remove the assembly. Try the speaker at low volumes to see if you hear any sound at all. Next, remove one of the wires and using a 9Volt battery quickly touch the 2 leads on the tweeter. If you don't hear a click, the tweeter needs to be replaced. Contact Mackie service for a replacement.
If you hear a click, then the problem is in the crossover or amp and further investigation willbe required.
Dan
Jun 05, 2011 | Mackie SRM-450 System
How do i install my component
from the speaker outputs of the head unit / amplifier. Connect from the positive and the negative outputs to the respective positive and negative input of your X-over box. Now connect from the X-over woofer/midbass output to the bass driver. Now do the same for the tweeter from the X-over from the tweeter output to the tweeter. Make sure that all the positives and negatives are correctly connected.
If you are going to use your head unit to power the speakers then you should know that:
White & white with black stripe is the Front Left Speaker output
Grey & Grey with black stripe is the Fron Right Speaker output.
Green is rear left
Purple is rear right.
I think you get that the black stripe speaker cables are the negatives.
good luck
dreamsystems.
Feb 11, 2011 | MB Quart - 5.25" 2-Way Component Speakers...
I have a pair of custom made bookshelf size speakers that I love. They are older speakers that use french made Focal 7" dual voice coil drivers. One mid-bass 7" driver and one tweeter per...
Well, fortunately it was the woofer that blew out. The reason I say that is because woofer material should have little to do with accurate reproduction in that frequency range. Since I don't know the model number of the speaker that was discontinued, I can suggest to you what can be done to get a satisfactory result.
1st If you have the model number on the Bass Driver AND Focal has the specifications. Go ahead and match the characteristics using THEIR data. The most important characteristics, besides the size of the driver would be the efficiency of the driver in terms of dB out. And the resonance frequency.
If these two are matched up closely, you should be good to go.
Focal is known to make good drivers, however, if you have to go to another manufacturer and you match the specs as above, then you should still do well.
If you get a newer Driver from focal, some of the characteristics may have been improved upon over the older driver. Such as transient response. If that were improved upon, It wouldn't sound really different, but it would seem tighter in the bass range.
One other thing I suggest. If you do as I suggest above and are pleased with the result, Go ahead and replace the woofer in the other speaker.
One additional point worth mentioning. Many of the foam surround speakers used in the old days in audio have failed because the foam has literally rotted away, as may be the case with your woofer. I know, as I have re-foamed enough of them. If you find a satisfactory woofer with a butyl rubber surround, it will never rot.
That would be the best replacement, as it would be permanent (if you don't badly overdrive it)
I've been an audiophile for most of my life, and I love music. I REALLY feel for you. I think that you will come out this just fine.
I hope this helps you,
Best,
Mark
Jan 19, 2011 | Audio Players & Recorders
Internal wiring schematic for a JBL 4311 WX-A
the conductor xxx\blk is the minus or black( from speaker) the outher is positive\red pin from speaker) the woofer is bigest speaker inside is connected on the crossover at low output, tweeter at high output, if you connect wrong you can burn speakers and crossover, you can test with very low volume on amplifier.
1st connect low to woofer, it only her low freq below 500Hz like drums and bass, if connect on med out the speaker is working as handpocket old radio audio. if connect on high the speaker is like no audio out. (the woofer take about 60-75% of amp power).
2nd connect the midrange at mid output you can listen to human voice cristal clear. if connect on high output you listem like esteric female shouting.
And connect the tweeter at the empty output
Take particular attention on polarity terminals, if you exchange the polarity you have a moofle sound traped inside of speaker, and some structered box noise who may open the box panels in future.
Feb 16, 2010 | Audio Players & Recorders
CL-51 Braxial component
ok well do u have a amp hooked up on the speaker and if not u could have dust in there or it could be a blown voice coil in the woofer part it self best way to check is to take a cotton swab u use in ur ear andgo along the coil part the speaker u no the brownish looks like ornge wires sum thing like that and do it very gently swab around the coil let me no if that helps
Apr 05, 2008 | Cdt Audio CL-51 Car Component System
Bi-amp
After examining a picture of a 5802 ( I have been servicing adcom for over 20 years ), these are not bi amp posts, but bi wire posts.
Bi-amp means that 2 amps are being used, one for highs, one for lows. This means that you have no crossovers in the speakers, instead, you have an electronic crossover between the amps and the pre-amp. The highs and lows are separated in the electronic crossover. One amp handles the lows, one handles the highs.
Bi-wire means that you have the crossovers still inside the speakers. The amp handles the full range of music ( highs-mids-lows ). Different kinds of speaker wire produce different results. If you have bi-Wire terminals on your speaker, they come with shorting wires, that tie the tweeter + to the woofer + on the back of the speaker, and the tweeter - to the woofer - . When the shorting wires are removed completely, you have now electrically separated the tweeter and woofer from each other, while maintinaing the crossovers ( inside the speaker ) for each.When this is done, you can now bi-wire the speakers and amp, and use different kinds of wire for the lower frequencies and the upper frequencies, depending on your ears ( everyone hears a little differently, thats why there are so may makers of components, and wire ).
Why do we have crossovers?.....the tweeter voice coils ( the things that make the sound ) are made of hair thin wire. This wire cannot handle much power and if you were to put bass in to a tweeter, you would burn the tweeter out almost instantly. A tweeter is a very light, fast moving device which can react very quickly to high frequency sounds ( symbols, triangles, guitar strings....). Woofers are more rugged. They have voice coils made of heavier wire and are designed for larger movements that Bass demands. Subsequently, woofers aren't very good for high frequencies because they are slower devices.
So what do we do ?.....Keep the lows away from the tweter and the highs away from the woofer.....thats the job of the crossover.
In the event that your speaker has the crossover OUTSIDE the speaker box, you should check ( as always ) with the manufacturer of the speaker to see how it can be changed to suit your needs. Remember to always read and follow your owners manual. Good luck....Rob
Feb 22, 2008 | Audio Players & Recorders
147 people viewed this question
 Grubhead
Grubhead
