Question about Dell Inspiron 1545 Notebook
The left side of my screen keeps flickering, eventually making the screen dark and totally black. do i have to change the screen or change the inverter? please help dennis
  • 152 Answers
Dark screen means your ccfl bulb not working so replace inverter
Posted on Feb 01, 2010
  • 644 Answers
The way you have disribed the problem you are having points to your lcd back light has gone, the only real way of testing this is to take the inverter out and test it on another dell laptop, you could take it to your local store and have them test it for you, even though the flickering does happen when the inverter fails, it normally happens to the whole screen not just the one side, and the screen still lights but not as bright.
My first thought is its definatly the back light but its worth testing the inverter to be sure. i hope this helps and post back your finding.
Sharp LED TV 3 years old stays dark on left side of screen for about 10 minutes after it is turned on. What could be causing this?
It seems to be capacitor{s}. Check the sharp website to see if there is any recall or special warranty on this unit.
Dec 15, 2013 | Sanyo 46" Class LCD 1080p 60Hz HDTV,...
VIZIO 42in LCD HDTV - Dark colors and flickering
It sounds that the back-light CCFL lamp is faulty. It is time to replace it. When replacing, do it to all CCFLs, because, the life time to these lams are expiring now, as the set is nearly 4 years old. Check this link http://electronicshelponline.blogspot.com/ to get more details about how to replace the CCFLs. Pull up older posts there. Some among it have details.
May 29, 2013 | Vizio 42 in. LCD TV
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
My hp CPTOH-0602 was flickering and then stopped and now the screen is dark with a big black area in the top left corner
it was a screen back light failure, the lamp get busted in the upper portion of the panel display. to access this part you will need to remove the back cover using a philip screw driver. the back light is covered with metal shielding.to replaced the back light, be careful in disassembling the cover not to damaged the lcd screen panel.
Nov 26, 2012 | Televison & Video
My screen goes dark. I can make out the picture but the left side is almost black, and the rest of it looks dark and/or flickers black.
I was told to replace the master and slave inverters as the capaciters were popped, still didnt fix the problem, have you had any luck???
Aug 16, 2011 | Philips 47PFL7422D/37 Television
My Compaq 14" laptop (LED
does it keep flickering? If so, there is a small circuit board in the top below the screen that can go bad, resulting in your screen eventually going dark---I had to use a flashlight to see anything. I would have it checked by a service tech soon.
Feb 14, 2011 | Compaq Presario CQ50-215NR Notebook
No picture screen remains black some flickering
hi
what you are experiencing is that your screen bulb is burnt.the screen bulb is what lights up your screen, its just like a fluorescent tube,when it is burnt it flickers for a while and it later goes off.. the only solution is to change the screen bulb as soon as you can
goodluck with that!
Feb 17, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
Samsung LN-T4661F with black shaded area.
The back light is beginning to fail, thats why it goes shaded but you can still the picture on one side, do a google search for back lights for your make and model, there a few how to's to help you with changing the back light.
Feb 17, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
Toshiba Plasma 42
plasma42 color flickers in and out and now its just snow,now its black screen. still have sound.please help me.. what board should i replace??
Dec 29, 2008 | Toshiba Televison & Video
MD96015 Monitor problem
Sounds like you may have a bad LCD backlight or inverter. When the screen is dark, take it into a dark area and see if you can see the screen dimly showing. Or, shine a flash light on the screen and see if you can make out anything showing up.
Try this and let me know what you find.
Ron
Dec 10, 2008 | Computers & Internet
Dell Inspiron 1545 Notebook Logo
522 people viewed this question
Alun Cox
