Question about Canon BJC 4400 InkJet Printer
Green light flashes, will not print. Checked all
Green light flashes, will not print. Checked all troubleshooting. Bought within 1 year
  • 4,041 Answers
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Posted on Feb 01, 2010
    • ise piq Apr 01, 2011
      This is how I just fixed a Canon MP800 all in one with the flashing green & orange lights (a series of 9) & error code 6800. Left it UNplugged from the electrical outlet over night. Plugged it in the next day & turned it on. First window now showed a different error iu30 or some such, & showed a graphic of the ink cartridges with problems recognizing them. Held down the RESET button until the graphic showed the first cartridge as ok, (the picture will change), let go and held down the RESET button again for the next cartridge & so on until all 5 were ok. The screen then changed to a menu asking me what language I would like. Used the arrow keys around the OK button to select English. Then pressed OK for that language. The screen then changed again & said it would have to do a printhead alignment & to put paper in the printer. I put paper in & pressed the OK button again. It took about 5 minutes for the print head alignment. The paper with the alingment marks came out printed correctly. The next screen showed a normal screen which usually defaults to the Copy properties. Turned the printer off & on again a few times & everything was fine. Have no idea how long this will last or what caused the problem, but it is fixed for now. Related Problems & Solutions Filter Problems by Issues:
    Why did my yx545 zboost work within a week thelight stays green no signal !
    The quick setup indicates that a steady green light means that it is ready, and there is no activity. A flashing green light means there is activity. That's all the further I can troubleshoot with you without knowing how you have it set up. If you continue to have issues, contact zBoost at support@zboost.com or 1-800-871-1612. They will be able to troubleshoot much better. If it turns out to be an issue with the device, it does come with a 1-year warranty, so they will be able to replace it. Customer Support
    May 20, 2014 | Pantech Zboost Yx029 High Gain Antenna -...
    Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
    Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
    Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
    I just bought a hp photosmart c3140 tri-color cartridge. after 8 small prints the ink low level lights flash-rendering my printer unusuable. i re-fill the tri-color, and reset the printer. still the...
    I would be taking it back to the place of purchase and asking them to replace it. Or contacting HP directly with the problem.
    You can contact HP via their home page of their website, or use the link below for troubleshooting and support:
    http://welcome.hp.com/country/au/en/support.html
    NOTEs:
    1. Unless you are printing a final copy of an item it is a good idea to always print in Draft Quality (to save your ink). HP Printers allow you to do this. This setting is generally within the Print window, when you select Print.
    2. When you are printing a final copy then switch from DRAFT to BEST quality.
    Feb 10, 2010 | HP PhotoSmart C3140 All-In-One InkJet...
    The printer flashes orange light five times, and green once
    Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
    1. Start with printer OFF
    2. Hold down RESUME and then hold down POWER
    3. Release RESUME
    4. press RESUME twice, then release POWER
    5. let green light blink until printhead has finished moving.
    6. Select functions below with RESUME, execute with POWER
    0 presses - green light - Test Print (exit service for i960)
    1 press - orange light - EEPROM info print
    2 presses - green light - EEPROM initialise
    3 presses - orange light - reset waste ink counter.
    This also applies to the i550, i560, i950, i960
    Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
    Canon i560 not printing, status light flashes 4 amber 1 green
    4 blinks of the amber light says that the ink is empty, at least 1 cartridge is empty.
    Jun 21, 2009 | Canon BubbleJet i560 InkJet Printer
    Flash is not flashing
    Common problem with flash charging transformer and/or bulb.
    Needs replacement.
    Does the green light blink or steady when you take picture?
    Apr 05, 2009 | Fuji Zoom Date 120 35mm Point and Shoot...
    Battery Charge light flashing 4 red one green Dell Inspiron 9200
    usually, its an indication that the battery is nearing the end of its useful life. you can try to use another battery to isolate it further. If the same thing happens with another battery, chances are, the mobo is failing. Flashing the BIOS can usually help with battery issues. If another battery works fine and your computer is within its first year since you bought it, you can request a replacement battery from Dell
    Mar 11, 2009 | Dell Latitude D600 Notebook
    Printing problem
    Turn off printer
    Hold down green button
    Power on printer. (cold reset)
    In printer properties choose print directly to printer, then choose print test page.
    Weird problem
    Feb 06, 2009 | HP LaserJet 1320 Printer
    Can't print
    It flashes orange for a few seconds, and then back to green, and then back to orange every few seconds. I can't shut it off unless I unplug it. It also makes a horrible racket.
    May 08, 2008 | Canon S 750 InkJet Printer
    Green light is flashing and printer will not print. It has paper and a new toner cartridge.
    try putting a piece of paper in the tray 1 (Bypass) and then pressing the green button hopefully it should print. If it does then you have sent a print job to the bypass and not the tray. If you press the green button and it prints form the tray check what media type you have set within the print driver.
    Hope these work for you
    Thanks J
    Jan 07, 2008 | HP LaserJet 1320 Printer
    Canon BJC 4400 InkJet Printer Logo
    1,705 people viewed this question
    old marine
    old marine
