Question about Whirlpool Washing Machines
The agitator wont turn on unless I slam the lid shut
We had this problem where it would not agitate with the lid closed. We would push on left side of the lid about halfway between front and back to get it to push on the switch and start agitating. It got worse and worse, until I removed the left hinge which is the lever that pushes on the switch and bent it slightly (straightened it). It lid switch was fine - it just needed to sense that the lid was closed.
Posted on Aug 19, 2012
  • 5,911 Answers
The most common cause of the symptoms you describe is a lid switch malfunction.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30. Prices differ between sites so shop and compare.
If you have questions, need additional assistance, please post back with your model number (located on a nameplate along the wash tub opening under the washer lid), so I can provide you with better assistance. I hope this helps you.
NOTE: Slamming the washer lid is not recommended as this can contribute to premature failure of the lid switch. This is the number ONE cause of broken lid switches.
Posted on Feb 02, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
Lid switch
Posted on Feb 01, 2010
2 Suggested Answers
  • 23 Answers
SOURCE: my washer wnot agitate unless i slam lid
is the lid up during the filling process? the new washers will not agitate unless the lid is down. no need to slam the lid.. There is no pin to push the activator switch.. they are controlled with a magnet...
Posted on Jul 31, 2009
My washing machine fills up with water but does not continue the wash cycle. Sometimes when you slam the lid the washer will continue the wash cycle to the end. Other times the washer stays filled up...
Sounds like the lid safety switch is either out of adjustment, or needs replacement.
Most washers will fill with the lid open, but no continue a cycle where the drum or agitator spin, unless it senses the lid is closed.
Oct 01, 2013 | Whirlpool Washing Machines
Kenmore 80 Series washer won't agitate/spin
Check out the video at the link that I'm attaching and see if it leads you in the right direction toward changing the lid switch. The switch should be checked for loose/corroded electrical connections and checked for continuity using a multimeter or ohmmeter. A lack of continuity means a bad switch. If bad it will have to be replaced, Sorry for your trouble and I hope this helps. Best wishes.
http://www.youtube.com/watch?v=fC8SY3cU1Yc&feature=PlayList&p=A8EAB62928245279&playnext=1&playnext_from=PL&index=61
Sep 08, 2009 | Kenmore 24032\24036 Top Load Washer
The washer turns on, fills with water, then stops. Agitation won't start unless you slam the lid or sometimes if you "nudge" the setting forward and then pull out and then in.
Sounds like door switch may be failing, or the wiring between door switch and timer has loose connection. You can replace the switch or check ther wiring, or bypass the door switch circuit by jumping the leads at the timer
Aug 02, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
My washer wnot agitate unless i slam lid
Jul 31, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Must repeatedly slam top loading door shut for machine to start
on the inside of the lid there is a lid switch hole that a plastic tab goes down through the switch could be bad or the screws holding the switch in could be lose or broken
Mar 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Won't agitate or spin
Try slamming the lid a little bit to see if the safety switch is stuck or something. It is probably a child safety thing preventing agitation or spin to start. if the switch is not working properly, then the washer will "think" that the lid is still open. It is to prevent some small child that is unsupervised from falling in it and getting killed. Some machines will still agitate even with the lid up and some wont. There is a little small hole somewhere that has a little switch that the lid hits. That could be the problem. If not I don't know of anything else myself to do since im not an appliance man. Just hope that this helps.
Jul 27, 2008 | GE WJSR4160DWW Top Load Washer
Will not go pass the wash cycle to spin or drain
There is at least one safety switch activated by the lid.
Depending on machine construction, these are somewhat exposed to water incursion that eventually causes them to fail.
The slamming of the lid is causing the failing switch to make enough contact to allow it to spin.
If you are lucky (I don't know your machine), these may be located toward the rear of the housing where they can be fairly easily replaced.
Jul 19, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Won't agitate!
does your model have a drive coupling its between the motor and gearcase,when they brake the machine wont wash or spin and makes a wierd noise
Jan 12, 2008 | Whirlpool LSR6232J Top Load Washer
Have to slam the lid
The same thing happened here. It turned out to be the lid switch. It can be accessed by taking off the back plate (behind the controls) by unscrewing three screws and two screw bolts -simple.
I removed the lid switch and tested it with an ohm meter - instructions are on this site. You should have continuity across machine-motor, as well as across machine -line. (These are labeled on the switch).
If you don't have a meter and you still want to see if that's the problem, after you have removed the lid switch, short the machine and line connectors, (you'll see these labeled on the lid switch so you'll be able to figure out which wires go with what) as well as shorting the machine and motor connectors. Both of these need to be shorted. That bypasses the switch and will activate the motor and controls.
That's what I did to confirm that it was all a "lid switch " problem. I ordered a lid switch from this site for $24.95 for the repair, and will use the "shorting process" to do a couple of loads of wash as I wait three days to get the switch. Good luck.
Dec 16, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
941 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
