Question about MSI K8N Neo4-F Motherboard
Starting computer When I press start button from shutdown mode, it wouldn't start right away. I disconnect power cable, toggle the switch between ON/OFF, while pressing start button. After several such attempts, it starts, but produces two loud and long beeps with constant sound in the background. My friend told me to shut it down right away.
  • 1 more comment
  • AndreyKo Feb 19, 2008
    Thank you very much for your reply.
    No, it doesn't show anything unusual. Just loading. But after it's loaded, it shows in the bottom bar that the network cable (cat 5) is disconnected, while the cable was connected and I was able to go on-line. And the "background" sound (not very loud, but constant) is always on.
    Thanks,
    Andrey
  • AndreyKo Feb 20, 2008
    Hermit, 1st of all, thank you for your help.
    I tried other keyboard. Didn't work. Let me tell you how it works.
    First, the front button wouldn't start the computer. After several presses, it would start, but turn itself Off within 3-5 sec. After that the button freezes again, and you had to hit it several times before it starts the computer. Then sometimes it would turn Off again in about 5-10 sec, sometimes not. All this is accompanied with sound coming from monitor. Yesterday I found a small fan on the MB which seemed to be malfunctioning. It rotated unevenly and seemed to cause tripping of computer. I took it off and cleaned. Now it's working OK and the computer doesn't trip. But the buzzing sound's still there. It's steady, but becomes louder for 3-5 sec at every step of booting. First, when computer starts identifying its hardware, then it gives a even louder sound when it starts loading Windows, and the most loud sound when it opens Windows (displays Window welcome screen). Between these three steps it clicks (like in a bad phone communication) and blackens the screen for about 1 sec. After that it works OK (at one point when I started it, the screen was greenish). After the computer is shut down, the monitor gives one more louder sound and then goes to standby. Oh yes, and I found three files in quarantine, infected by Trojan Horse.
    I think I gave you the whole picture. Thanks again for the help.
  • AndreyKo Feb 24, 2008
    Hermit, I don't know if you received my comment, because I hit the "Fix it" button and everything disappeared. I thank you very much for your help. Your help really helped. I replaced the monitor and now it works fine. I also checked the old monitor on another computer and it did the same things. So the problem is the bad monitor.
    Thank you again.
    Andrey
Thank you all guys
Posted on Feb 25, 2008
Good for you, Adrey! Am glad you found the goblin finally. See you around, okay.
Your power and data system need inspection inside the MoBo. Hardware problems produce warning beeps, especially RAM and VIDEO. Check these first to make sure they are in slots.
Does it show anything on the screen while it's beeping??????
Please provide more information and come back
Posted on Feb 19, 2008
  • Anonymous Feb 20, 2008
    Let's start with your keyboard. If windows is running and a constant sound persists, it could vey well be a stuck key on yoour keyborad. Try a different keyboad or unplug the keyboard after the computer boots.
    The network diconnect sign can be ignoored if you can get online, but if you can't, try replacing your network cable terminating clip--the one that goes into the network card. Also check the other end coming out of the switch or wall socket.
    Let us know, okay
  • Anonymous Feb 21, 2008
    Hey, Adrey,
    Your computer sounds like a Harry Potter scene! (Kidding :) I want to say that that thing has more than one problem. It is one of those where I would disconnect things one by one and reconect backward to isolate the problems. Let's try this,ok
    1. Once it's booted and wailing, turn off the monitor that you say wails loudly. Does the sound stop?
    2. Remove the sound card and speakers, then restart the computer. Any sounds?.
    3. Disconnect the HDD and CD Drive and turn the PC on, let the fan run for a minute. Any sounds?
    4. If you have a different monitor, try it and see the diffrence.
    5. Remove the cooling fan from the processor and turn PC on for only 30 seconds. Any sounds? Don't keep it on without the fan too long thou.
    This process of unplaugging parts you are suspecting are faulty will give you a basic idea of where the sounds are coming from,
    Your MoBo may be having a problem, like getting ready to die, or has a short somewhere.
    Your power supply is also suspect, and could cause variable power relay and cause Harry Potter type events.
    Let's keep drilling down, okay.
I downloaded photos on computer ,now I get card not initialized ? what do I do? Its a fujifilm camera..
Insert the memory card into the camera to format it if you are receiving error messages such as "Card Error" or "Card Not Initialized." Press the "Menu/OK" button then press the left/right directional button to select the "SET" option. Press the up or down direction button then press "Set Up" and press the "Menu/OK" to access the setup screen.
Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • 2 Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
  • 3 Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.
  • 4 Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • Read more: How to Troubleshoot a Fuji E500 Digital Camera ' eHow.com http://www.ehow.com/how_7636592_troubleshoot-fuji-e500-digital-camera.html#ixzz1OOyWsAIU
    May 31, 2011 | PNY Optima Pro 2GB Secure Digital Memory...
    Installed new cartridge still says low in ink
    1. Disconnect the power cable.
    2. Hold down On/Off button.
    3. Reconnect the power cable.
    4. With the power button still down, press the Stop/Reset button twice.
    5. Release the On/Off button.
    6. The printer is now in factory mode (wait until idle is displayed)
    7. Press the right arrow button (next to the OK button) repeatedly until Shipping Mode 3 is displayed.
    8. Press the OK Button
    9. Wait until "Without Cleaning" is displayed and then press the Stop/Reset button once.
    10. A test page should print.
    11. Open the cover. (the cartridges should position themselves at the far left - the cartridge removal location)
    12. Disconnect the power cable.
    13. Remove both cartridges.
    14. Close the cover.
    15. Reconnect the power cable.
    16. Press the On/Off button.
    17. Wait until a Replace Cartridges message is displayed. Now insert the cartridges.
    18. Wait until the printer is operating in its normal mode. The display shows the normal start menu
    Dec 24, 2010 | Canon PIXMA MP470 All-in-One Printer
    Starting problem
    shut down the computer completely ...........disconnect all the external devices if any connected ........also disconnect the power cable at the back of the pc and with the power cable disconnected press and hold the power button of the computer for 10-12 secs and then reconncet the power cable only and restart the computer and see .
    Jun 07, 2010 | HP FK784AA Pavilion Slimline s3650f...
    Disable viper alarm
    Yes the best way is disarm the alarm and put in a Valet Mode
    To activate the Valet Mode do the following:
    There is a push button or toggle switch to disable the alarm (to engage the valet mode). Without knowing where this
    switch is you won't be able to disconnect the alarm.
    1. Put the key in the ignition and turn it to the "on" position.
    2. Flip the toggle or hold the push button for at least 5 seconds.
    3. The LED. light will stay solid on.
    4. Turn the ignition off
    5. Release the push button. If you have a toggle leave it alone in step 2
    Jan 07, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
    Ipod woulnt connect to itunes
    Reset your iPod:
    1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
    2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
    Then connect it to your computer and see if it is recognized by iTunes.
    If not, try other USB ports on your computer, especially any on the back panel.
    Dec 29, 2009 | Apple iPod nano
    How to shut down dell inspiron 530 computer - the button only takes computer to sleep mode
    I assume you use Windows Vista.....
    In vista the default action of the power button is configured to sleep mode..
    So to shutdown the PC you can press "Start - right arrow - right arrow - right arrow - Enter", or you can navigate to the same using the mouse & selecting shutdown from the list besides the lock icon.
    You can also change the power button configuration this way goto " Start-Control Panel-System and Maintenance-Power options-change plan settings (under the current plan you are using) - change advanced power settings - Power buttons and lid - Start menu power button" click on settings and select shutdown, apply & save the settings and close this window.
    Now you can just click the power button to shutdown your computer.
    Jul 05, 2009 | Dell Inspiron 530 Desktop Computer
    I have sansa sandisk e 260. last time, after charging it in my computer, i plug it out without having safety mode in the computer. After then i can not open my disk. when i try to turn on pressing on Menu...
    1. Download the Sansa firmware.
    2. Turn the player off.
    3. On the top of the player is a Hold switch located.
    Move it to the right so you see "Orange".
    4. On the left hand side of the player is a Record button.
    Press and hold the record button while connecting the player to the computer.
    Continue holding the Record button until you see a new icon under "My Computer": named "16MB FORMAT".
    Once you see that icon release the Record button.
    5. Drag and drop the download firmware files to your player (16MB FORMAT).
    6. Disconnect the player from USB cable.
    Several things will be displayed.
    When you see Key Lock, System Shutdown, move the Hold switch on the top back to the left.
    Otherwise download the Sansa Updater and start follow the points 2-4 and start the Sansa Updater.
    After updating the firmware follow point 6.
    Jun 08, 2009 | SanDisk Sansa e260 MP3 Player
    My computer will not recognize it.
    I would start with attempting to reset the iPod to get it to connect to the computer. If that does not work, attempt to force it into disc mode. And if all else fails try another USB port on your computer or a friends computer. If it does not work try a different cable with your iPod to ensure that it is not just a cable connection :) Below is a step by step on resetting an iPod as well as disc mode just in case you need the information :)
    Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
    If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
    If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
    When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
    Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
    Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
    If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
    May 18, 2009 | Apple 20gb Ipod Mp3 Player With Click...
    Upload fotos
    Here's how...
    • Starting PC mode
    If you connect the USB cable to a USB port on your PC and then turn on the power, the camera will automatically switch to "computer connection mode".
    In this mode, you can download stored images to your PC through the USB cable.
    The LCD monitor on the camera is always turned off in PC mode.
    • Connecting the camera to a PC
    1. In any mode, except Voice Recording mode, press the Menu button.
    2. Press the LEFT/ RIGHT button and select the 'SETUP' menu tab.
    3. Select the 'USB' menu by pressing the UP/DOWN button and press the RIGHT button.
    4. Use the UP and DOWN buttons to select 'Computer', and then press the OK button.
    5. Press the menu button twice and the menu will disappear.
    6. Connect the PC to the camera with the USB cable.
    • Downloading stored images
    You can download the still images stored on the camera to your PC's hard disk and print them or use a photo editing software to edit them.
    1. Connect the camera to your PC with the USB cable.
    2. On your computer's desktop display, select 'My Computer' and double click 'Removable Disk' - 'DCIM' - '100SSCAM'.
    3. Select an image and press the right mouse button.
    4. A pop-up menu will open.
    Click the 'Cut' or 'Copy' menu.
    - 'Cut' : cuts (i.e. moves) a selected file.
    - 'Copy' : copies files.
    5. Click a folder where you want to store the file on your PC.
    Don't forget to rate this solution once you've tried it !
    Good Luck.
    May 20, 2008 | Samsung NV3 Digital Camera
    While in BIOS command mode, turned of - not possible to start anymore
    Hi Marc, Hope you doing good. Please try the following solution : 1. Disconnect the power cable. 2. Take out the battery 3. Keep holding down the power button for 60 seconds. 4. Put the battery back in. 5. Connect the power adapter 6. Make sure the Power adapter is switched on and laptop is on AC Power 7. Wait for 5 minutes and try to restart the computer 8. If it still doesn't starts. 9. Hold down the power button for 60 seconds with AC adapter and battery connected 10. Try to restart now and check. 11. If it still doesn't switch on 12. Take out the battery and run on only Ac adapter and restart. Please advise if this still doesn't helps.
    May 06, 2007 | IBM ThinkPad A22m 2628 Notebook
    MSI K8N Neo4-F Motherboard Logo
    128 people viewed this question
    Top MSI Computers & Internet Experts
    vsri9
    Alun Cox
    David
    David
    Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
