Question about eBay Auctions
I have some flat silver spacers for a bracelet that I did not order and I do not know what they really go on! The name on the package is: Fan chao jun, from Singapore. On the back it says metal bead,value $8.00. I have no idea where these came from? Could you let me know so I can know what to do with them?
    Guru:
  • 226 Answers
It seems that the item was sent to the wrong address, you need to contact the shipping carrier who delivered the package to send back the item to the seller. Shipping carrier company will be able to do that for you.
hope this helps... please dont forget to rate,,, thanks!
Posted on Feb 02, 2010
What do I do to get my silver bracelet restrung?
Try to find a bead shop that does that sort of work in your area our store does that barrows Jewelers in Toledo Ohio
Jun 14, 2016 | Watches
My order total had three items. My receipt said I
Take a photo of the received items. Get back to the supplier and tell them you are missing one item. You can also stop payment of this invoice by blocking the check (cheque); blocking the vendor on your credit card or advising paypal of this incident. Ask for a refund if you are not happy with response. The item may have been stolen during delivery process. Good luck.
Oct 16, 2014 | Computers & Internet
We replaced the rear tire and brake on a 2005 yamaha 1100.each time it is reassembled, the tire is really tight to try & turn it. Any suggestions?
Quite common to get the parts in the wrong order. You should bave a shouldered spacer and a flat washer.
so looking from the back of the wheel...on the right side you should have the following..
wheel
shouldered spacer with shoulder into wheel.
brake caliper bracket
flat washer
swingarm.
if the washers are in the wrong order it pulls caliper against rotor causing the drag
Mar 20, 2011 | 2005 Yamaha V Star 1100 Classic
Tissot Seastar 1000 Does anyone know of a source
Tissot is Swatch. They do not sell parts! You need to contact the company OR where you purchased the watch.
http://www.tissot.ch/?mod=stores&action=search&search=&regions=2&countries=195&countryregions=&option=cs
Jan 14, 2010 | Tissot Diver Seastar 1000 Auto Steel Large...
Replace Kirby legend II fan (impeller blade)
In order to replace the fan you will buy a 2 or three piece lexan fan kit containing the fan a spacer and shaft.
You must remove the carpet head and then looking from the back of the machine you will find a series of philips screws on the outer edge of the fan housing facing towards the front, several of which may be partly covered by the motor housing. You will remove the forward facing screws to allow the housing to separate and reveal the fan.
If you are lucky there will be a sideways hole through the impeller shaft allowing you to slip a nail through to help twist the saft to unscrew it while holding the fan .
The shaft will turn off revealing a threaded motor shaft with spacers which the broken fan will slide off revealing a second spacer at the back . Be sure to replace these spacers in the same order when re-assembling the unit. Secure the shaft hand tight. Post back to advise if you need further help
Oct 07, 2009 | Kirby G4 Bagged Upright Vacuum
Whats a product key for mark of chaos
I am sorry but due to your EULA we cannot provide you with a key for this software. You must contact the publisher for a legally obtained key. FixYa TOS does not allow for us to assist with copies of keys, codes, ids, or software as it is against the law.
Software Counterfeiting
This type of piracy is the illegal duplication and sale of copyrighted material with the intent to directly imitate the copyrighted product. In the case of packaged software, counterfeit versions often include copies of CDs or diskettes containing the software programs, as well as related packaging, manuals, license agreements, labels, registration cards, and security features.
Software Piracy is stealing. If you or your company were caught pirating software, you could be held liable under both civil and criminal law. If a copyright owner brings a civil action against you, the penalties in the U.S. may be up to $150,000 for each program copied. The U.S. government can also criminally prosecute you. If you are convicted, you can be fined up to $250,000, sentenced to jail for up to five years, or both.
Jul 29, 2009 | Deep Silver Warhammer: Mark of Chaos for...
Rainbow se trying to fix
small red washer on top - motor is the top. Also on only everyother fan spins.
Small fan with the small hole up
Barrel Spacer
Large Fan with the the hole down
Hour Glass spacer - this spacer has a washer welded to the bottom of it - spacer down!
small fan hold down.
Lower motor housing
Hope you changed the bearing while you were where here.
Give it a spin by hand and make sure there is no grinding.
Hope this is right, doing it from memory, have a picture at work.
Good luck
M
Sep 23, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow SE (1991)
little fan first, then hour glasss spacer washer side down then larger fan, with spacer sticking throug then small fan. then normal spacer. assambley starting from top part down, your local vacuum cleaner shop should have switches or contact rainbow, but will be cheaper to go local store
Mar 26, 2008 | Rainbow E series Canister Wet/Dry Vacuum
eBay Auctions Logo
99 people viewed this question
Top eBay Computers & Internet Experts
Jesse Walters
Jesse Walters
Are you an eBay Computer and Internet Expert? Answer questions, earn points and help others
