Question about ATI ALL-IN-WONDER 2006 EDITION, (256 MB) AGP Graphic Card
System reboot and lockups with AIW2006 AGP running Windows XP
System does not boot up properly and hangs without launching windows explorer. Also when I run Microsoft's Event Viewer it appears that ati2mtag is not loaded or there is an error. Also the system will hang or produce blue screen that states hardware failure with the graphics card. I am running 2GB of system memory. Pentium 4 3GHz processor and Via PT800CE North bridge and Via VT8237 south bridge chipsets. These chipsets enable AGP 8X which I am running.
  • ScottyBugs Feb 19, 2008
    Thanks for the assistance. 1.5GB of system memory. DDR 400 one module 1GB the other .5GB.
    Genius:
  • 3,587 Answers
Hmm..memory allocation issue? how much you got on board that machine?
Posted on Feb 19, 2008
  • Patrick Michaels
    Patrick Michaels Feb 19, 2008
    ok..go to the system setting under control panel, and adjust the memory usage for best performance(usually is set for Windows decides) and you may find it helpful.
    got backup for that machine?
When I shut down windows xp it restarts I stopped auto restart and got a blue screen with this disciption on it Stop: c000021a [Fatal system error] 0x00000000 (0x00000000 0x00000000). any idea
Click on my computer.
Right Click on the C: drive.
Choose Properties.
Tools tab.
Error checking: Check now.
Choose automaticly fix file system errors.
Start, Yes, OK, Reboot the PC.
On boot a blue screen will launch and run for 5 - 20 minutes.
It wll reboot into windows when completed.
Sep 27, 2010 | Microsoft Windows XP Home Edition
Xp pro sp3-after running macfee quick clean. on boot-explorer.exe "the application failed to initialize properly 0xc0150002"
Issue may be a corrupt explorer.exe (The file that actually launches the desktop). There is a lot of discussion on how an AV an bork explorer.exe here and several solutions.
http://www.annoyances.org/exec/forum/winxp/t1061853506
The one I recommend you try 1st is: Fire up the task manager (CTRL+SHIFT+ESC), File, new task, cmd and then c:\windows\system32\restore\rstrui.exe from the command prompt (edit the command if you didn't install windows in c:\windows). See if system restore can rescue explorer for you.
If that doesn't work, there are several other flavors of repair possibilities, last of which is reinstalling Windows
Mar 05, 2010 | Dell Precision M90 Notebook
The system hang during winxp install
If its hanging during install you need to turn virus protection off in the bios. Have a root around in the bios and you'll see it sooner or later, If you need further help just shout.
May 23, 2009 | Acer Computers & Internet
Windows XP Pro hangs on reboot after installation
Try removing your AGP card and enabling the onboard graphics again. It is possible your Radeon is a 3.3v, but this board only supports 1.5v cards. Take a look at the manual at ftp://download.intel.com/support/motherboards/desktop/D845GERG2/BV2RG2_English.pdf
Dec 29, 2008 | Intel 845GE Motherboard
Windows XP hangs up and never continue opening...
Go to Windows Explorer Right click C:\ go to properties / Tools / click Error check new box pops up tick small box to fix errors and reboot. On reboot windows will scan disk and fix any errors in system files then restart.
If windows restarts OK problem solved If not
Boot from windows CD and after all drivers loaded windows will ask what you want t do 0Install Repair etc" press the R key for repair and follow instructions from there
Warning until window finishes installing do NOT press any keys when it reboots
Nov 21, 2008 | Asrock M266A Motherboard
My laptop is not switching on
  1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
  2. When you see the "Welcome To Setup" screen, you will see the options below This portion of the Setup program prepares Microsoft
    Windows XP to run on your computer:
    To setup Windows XP now, press ENTER.
    To repair a Windows XP installation using Recovery Console, press R.
    To quit Setup without installing Windows XP, press F3.
  3. Press Enter to start the Windows Setup. note.gifTo Repair Install, press ENTER
    \r\n'); FP_changeProp(/*id*/'layer1',0,'style.borderStyle','double','style.borderWidth','3px','style.padding','5px','style.backgroundColor','#F9F4D5','style.backgroundImage','url(\'edgbkgnd4.gif\')'); FP_changeProp(/*id*/'layer1',0,'style.visibility','visible')" onclick="FP_changeProp(/*id*/'layer1',0,'style.visibility','hidden')" border="0" height="21" width="15" /> do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
  4. Accept the License Agreement and Windows will search for existing Windows installations.
  5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read Warning#2!
  6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
Oct 22, 2008 | Toshiba Computers & Internet
Install Xp From Dos
If XP will not install from the CD or if you have a new drive with no operating system onit yet try these:
Install Windows XP from the hard drive with Windows 98 already installed:
Boot Windows 98
Insert the XP CD into your CD reader
Explore Windows XP through My Computer
Copy i386 folder to C:\
Go into C:\i386 folder and double click on winnt32.exe to launch the setup from the hard drive
Install Windows XP from DOS (ie. no OS on a new hard drive):
Boot with a Windows 98 Start Up disk
Insert the Windows 98 CD into the CD reader
Run smartdrv.exe from the Win98 directory on the windows 98 CD (file caching)
Type cd.. to back up to the root directory
Insert Windows XP CD into the CD reader
Copy the i386 folder to C:\
Go into C:\i386 folder on C: and type winnt.exe to launch the setup from the hard drive.
Oct 20, 2008 | Computers & Internet
Explorer.exe won't come up after downloading and installing new software
In my openion, Virus doesn't want to be killed by anti-virus :D You need to download DM2000 (disk manager 2000 of SeaGate) and run it in DOS mode to format Hard-Disk.
Jul 31, 2008 | Microsoft Windows XP Professional With...
Windows explorer
Both of the utilities you have listed have good reviews, but
there are three possibilities:
1) You have somehow damaged the windows shell,
explorer.exe, it's libraries or its registry entries,
while you ware cleaning your system.
In this case you will need to either re-install windows,
or at least repair windows from the install disks and
re-apply service pack 3.
2) You may still have a rogue program or a root-kit running
somewhere. Check the task manager (ctrl-alt-del),
shut down all unnecessary tasks. Then got to:
Control Panel ==> Administrative Tools ==>
Services,
and stop all unnecessary services, but do NOT
disable them, unless you know what you are doing.
they will re-start when you re-boot.
Download Mike Lin's startup monitor, and disable
all unwanted programs from starting up ==> reboot
Once you have trimmed your system to the bare minimum,
see if the problem persists.
You may also scan your system with rootkit detectors,
such as 'black light" and rootkit revealer by Mark Russinovich
3) You have a large corrupt media or picture file in your root
directory, and windows explorer is hanging while trying to
generate a preview thumbnail.
Disable: shmedia.dll = Show media
and shimgvw.dll = Show Image View
START ===> RUN
type:
regsvr32 /u shmedia.dll
regsvr32 /u shimgvw.dll
To re-enable pre-view, enter the previous commands
without the /u switch.
Martin
May 07, 2008 | Microsoft Windows XP Professional
XP-SP2 hangs on boot after installation
I think maybe better uninstalling driver, but leave card in and boot system and let windows find the card(hardware) first instead of wot sounds like windows looking for driver and freezing in the boot up process as it will look for a connection to internet for an update or driver. Normally any usb periferals should be connected after driver installation, but any pci or agp cards inserted first, then driver.
Nov 05, 2006 | X-Micro Technology XWL-11gCAG 802.11g/b...
ATI ALL-IN-WONDER 2006 EDITION, (256 MB) AGP Graphic Card Logo
69 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
