Question about Trendware TRENDnet TEW-432BRP 54Mbps Wireless G Firewall Rou Router (TN-432BRP)
My router just stops working. I have tu unplug it from power.
My router just stops working. There is no interent connection nor i can enter the setup page (192.168.10.1). I have to unplug it from power and then plug it back in for router to start working again.
    Scholar:
  • 68 Answers
Yes, sounds like you have a buggy router. I have had one of those too, just not that brand. Go to http://www.trendnet.com/asp/download_manager/list_subcategory.asp?SUBTYPE_ID=1043 and see if this upgraded firmware will fix your problem (read the notes with it, like they say) and if not, either get with your ISP (if they supplied it) or someone else.
So long as your power is good, you should NOT have to reset a router periodically. If you have an intermittent problem, you should replace it.
Do you have your router plugged in to a UPS? If not, you should do that.
Posted on Feb 01, 2010
Cannot connect to the interent with Shaw Cable. Problem just occured today. When I hook my internet directly to my computer it works fine. Shaw tells me this is a global problem with alot of their...
I had the same problem and got the same answer from Shaw when I called. Fortunately my D-Link 655 modem was less than a year old so I called D-Link support. They said Shaw made a change to their system yesterday which caused the problem.
The solution they provided was to log into the modem then go into setup, manual setup. Make sure the connection is Dynamic IP (DHCP), then at the bottom press the button Clone your PC's MAC address, then save the settings. I then had to unplug the power from my cable modem and router and wait 1 minute. Plugged in the cable modem first, once all the lights have gone through the cycle plug in the router. This fixed my problem so far.
Good Luck...
Jan 28, 2011 | D-Link DIR-628 Wireless Router
Tip
Wireless Network Reset and Setup - Linksys
If you are unable to connect your laptop wireless to your Linksys wireless access point/router, the easiest and fastest way to get going is to reset your router to the factory defaults. This will make your router work like the day you bought it.
There are 2 steps involved Reset your router, Setup/Secure a new router
Reset your router:
  • Unplug your DSL/Cable modem from power (not your access point/router) Leave this unplugged for now
Next
  • On the rear of your Linksys router you will find a small RESET button
  • With the power still on the router, Press and hold (with a pin/pen tip) the RESET button for 30 seconds.
  • Release the RESET button a wait 15 seconds for the router to reboot
almost done....
  • Unplug your Linksys router from power
  • Plug your DSL/Cable modem back in to power
  • Wait 1 minute for the modem to boot up
  • Be sure the ethernet (cat5) cable from your modem is securely plugged into the WAN port on the back of your Linksys router. This is usually labeled WAN or Internet above the jack
  • Plug your Linksys router back into power.
You will now be able to connect to the internet with your wireless device. I would advise that you follow the next steps in securing your wireless network.
Log into your router
  • Type 192.168.1.1 into your web browser and hit enter
  • In the login fields (case sensitive):
  • Username: leave_this_field_blank
  • Password: admin
  • Click OK
Once in the web interface for your router
  • Click Wireless tab - Basic Wireless Settings
  • Find the Wireless Network Name (SSID) field
  • change this to your new network name (this is the name you will see when you connect through your wireless device)
  • Find the Wireless Channel field
  • Change this from 6 (default) to 1 or 11
  • Click on Wireless Security
  • Find the Security Mode field
  • Choose WPA2 - Personal
  • WPA Algorithm choose AES
  • WPA Shared Key type in your new password you will use to connect to your network
Click Save Changes and your router will now reboot. You will now need to enter in that same password (WPA Shared Key) when you first connect with your laptop to your wireless network
Magoo
on Mar 12, 2011 | Linksys Wireless-G WRT54G Router
Our linksys wireless g router just stopped working.
In order to try to recover your router, the first thing to do is to try to reset the router to factory defaults. To do this: 1) Power down all computers, the router, and the modem, and unplug them from the wall. 2) Disconnect all wires from the router. 3) Power up the router and allow it to fully boot (1-2 minutes). 4) Press and hold the reset button for 30 seconds, then release it, then let the router reset and reboot (2-3 minutes). 5) Power down the router. 6) Connect one computer by wire to port 1 on the router (NOT to the internet port). 7) Power up the router and allow it to fully boot (1-2 minutes). 8) Power up the computer (if the computer has a wireless card, make sure it is off). 9) Try to ping the router. To do this, click the "Start" button > All Programs > Accessories > Command Prompt. A black DOS box will appear. Enter the following: "ping 192.168.1.1" (no quotes), and hit the Enter key. You will see 3 or 4 lines that start either with "Reply from ... " or "Request timed out." If you see "Reply from ...", your computer has found your router. 10) Open your browser and point it to 192.168.1.1. This will take you to your router's login page. Leave the user name blank, then in the password field, enter "admin" (with no quotes). This will take you to your router setup page. Note the version number of your firmware (usually listed near upper right corner of screen). Exit your browser. If you get this far without problems, try the setup disk, and see if you can get your router set up and working. When you get to the password prompt in setup, be sure to leave the user name blank.If this does not fix your problem, then report back with your results, including any error messages, and the firmware version number if you have it. Also report back the status of your router lights.
Nov 11, 2010 | Linksys Wireless-G WRT54G Router
Had a power cut and now router has stopped working
if the light is flashing Red then your router has "forgotten" its password for your service provider. if however the light next to it is flashing ( looks lik twisted wires ) then your router has not syncronised with the exchange.
If it has lost its password you will nedd to log on to the router through internet explorer by typing 192.168.0.1 this will get you to the authentication page. the username will be "admin" and the password "password" once in there click on "setup" and then re-enter the username and password supplied to you by your internet provider and all should be well.
If the twisted wire light is flashing then you will need to wait until the i light starts flashing
Jul 20, 2010 | NetGear WGR614 Wireless Router
I have belkin g plus router and dont want people steal my interent usage how do i stop others from usen my interent also what do i do if i only want others in my house to use our interent
To make sure your interenet is secure on a wireless router, consult your owners manual for the device (you can also download the PDF from belkin.com support page if you need.)
You will need to log into the router setup from a connected computer, and in the setup either set a WEP or WPA key. Once set you simply go to your wirless and choose connect to the router and enter the key, make sure you check the box to save the key and then you should be good.
BE SURE to write the key down somewhere for your reference so you don't have to keep changing it if something gets changed on one of the computers.
May 04, 2010 | Belkin Wireless G Plus MIMO (F5D9010)
I'm trying to access my wireless Linksys router to secure it.
First inplug power from router via the jack(not the wall outlet) and then unplug the cable going to the modem, take the blue ethernet cable that comes with router and plug into internet port now you can secure your router without worrying about internet threats. Open your web browser , in the url bar type 192.168.1.1 hit enter and a window should open, asking for username/password if you have not set one the default is admin in the username field then hit enter. If you have already password connected it and forgot password you need to unplug everything from router and then hold down reset button on back. There will be a screen that will walk you through all aspects of setup, security, firewall, wirless setup , wireless security, and it will give you a break down of all options on the right side of each window. Important to setup a passkey!!! Otherwise people can get into your network easy. once setup plug blue cable into ethernet port and modem cable into internet port. plug in power and you should be set. The cd that came with router should be first used. Do not broadcast wireless ssid and use wireless pin to connect computer.
Jan 31, 2010 | Linksys Wireless-G Broadband Router
I have a new Linksys router, and 192.168.1.1 stopped working. The setup is done, but I wanted to check something, and can't get in.
Hi Friend
please follow the steps
1. Switch on the router.
2. Now at the back of the router push and hold the RESET button for 30 seconds and after that release the button and unplug the power cable form back of the router and wait for another 30 seconds and plug the power cable back.Wait until the power light becomes solid and steady.
3. Connect the computer to the router either of the four ports named 1 2 3 or 4 and the internet wire into the internet or WAN port.
4. Click the start menu and RUN, type cmd and hit enter.
5. In the black box type ipconfig /all and hit enter. Out of those bunch of information please note down the default gateway.
6. Open the internet explorer and in the address bar type that default gateway number. You will get the router page.
7. You can configure as per your requirements now.
Enjoy
Regards
Chiranjeet
Dec 23, 2009 | Linksys WRT160N Wireless Router
Internet stopps working
if you have router connected to modem
turn of modem and router, unplug the power plug and wait atleast 25 sec
after 25 sec, power on modem and wait for all the lights turn solid green (power, wireless, internet)
then power on router and connect to modem
go to your pc and click Start>>>>RUN
type CMD
then command prompt will pop up
type ipconfig /flushdns then press enter
type ipconfig /release then press enter
type ipconfig /renew then press enter
Mar 20, 2009 | Intel D101GGC Motherboard
I lost the instructions on how to install a Linksys wireless router. I would like to down load these instructions.
cable setup
This guide is recommended for Cable Internet Service in the USA like Charter, Cox, Comcast, Cable Vision, etc.
  1. First you need to connect the device together. You need to connect your cable modem to the internet port on the back of the router, and the computer should go to one of the 4-port on the router labeled Ethernet (1, 2, 3, 4).
  2. Then turn on the modem first, wait for the lights to stabilize before powering on the Linksys router. Lights that you should have on the router are Power (solid green), Wireless/WLAN (Green sometimes flashing), One of the no. lights where the computer is plugged in (flashing), And the internet light (flashing).
After doing this step there are times that this will already get you online. If the internet will not work, you continue following the steps 3.
3. If the internet is still not working; we will need to adjust a setting on the router setup page. To access the setup page of the router you need to open your internet explorer or Firefox on the computer that is hardwired directly to the router. In the address bar of your browser (Internet Explorer or Firefox) type http://192.168.1.1/ and hit enter or click Go. It will ask you for a username and password. Just type "admin" for the password field and there is no username. If you have ran the setup CD prior to this, then use the password that you have set when were running the setup CD.
4. Once you are in the setup page of your router make sure that the Internet Connection Type is set to Automatic Configuration DHCP, then click the save the settings button at the bottom of the page. After saving the settings, click the sub tab at the very top of the page that says MAC Address Clone. Set it to enable and click the button that will say Clone or Clone your PC's MAC and save the settings again.
5. After doing step 4, do a power cycle. Power cycle is done by turning of the router, modem and computer. Leave them off for a minute, tuned them back on in this order. Modem first wait for the lights to stabilize, then the router wait until the power light become solid. Then turn on the computer. This will get you online through the router.
DSL
Configuring the Linksys Router.
These instructions assume the computers TCP/IP Properties are configured to " Obtain an IP Address Automatically"
1. Connect the Linksys power supply and connect a Lan port to the computers Lan port.
2. Go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP)
3. When "Internet Explorer" opens type »192.168.1.1[?] into the "Address" bar and click on Go
4. The "Enter Network Password" window will appear.
5. Skip user name and type admin (admin is the default password) as the password, and click OK
6. Scroll down on this page and look for (on older firmware) PPPoE or select the option for PPPoE under "WAN Connection type"
7. Username: yahootheclown@sbcglobal.net or yahootheclown@ameritech.net and your password.
8. Select the option for "Keep Alive" with a redial period of 180
9. Click on the Apply button.
10. Then click on the Continue button
11. Exit Internet Explorer
Power Cycling:
1. Shut down your computer
2. Unplug the power from the router
3. Unplug the power from the DSL modem
4. Wait for 30 seconds and re apply power to the DSL modem
5. Once the lights on the DSL modem stop blinking power up the router
6. Start up your PC
Checking your internet Connection:
1. Go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP)
2. When "Internet Explorer" opens type »192.168.1.1/Status.htm[?] into the "Address" bar and press the "enter" key or left click the "go" button
3. The "Enter Network Password" window will appear.
4. Skip user name and type admin (admin is the default password) as the password, and click OK
5. On the left of the "Status" page you will see "PPPoE Enabled", and to the right you will see the Status of the connection. It can be one of the following:
- Disconnected
- Connecting
- Connected
6. If the status is "Connected" you should be able to browse the web, if not reboot your computer
7. If you get an error message please repeat the "Configuring the router" and "Power Cycling" steps with a different username.
- If all four connections fail then please see our knowledge base articles on the error you're getting.
Once the router is configured correctly you should change the default password and record it for reference.
You should also add the "Enter Network Password" page to the Favorites List, and review the user manual.
for linksys tech support call 1800 3267114
hope this helps.
Oct 18, 2008 | Computers & Internet
Setting up the BEFVP41 Router with a Cable Modem and a Dynamic IP Address
Connecting the Router and the Modem 1. Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. 2. Shut down the computer, and unplug the power cables to both the router and the Broadband modem. 3. Disconnect the Ethernet cable from the computer and plug it into the Internet or WAN port of the router. 4. Take the Ethernet cable that came with the router (or any another available cable) and connect it to the computer. Then, take the other end of that same cable and connect it to Port 2 on the back of the router. 5. Plug in the Broadband modem's power cable and wait for all of its lights to stop blinking. 6. After the lights on the Broadband modem stop blinking, plug in the router's power cable. 7. Start up the computer. Obtaining the PC's MAC Address Windows 98SE/ME 1. Click on the Start menu, then click on the Run option. 2. When the ?Run? window opens, input winipcfg into the ?Open? field, then click on the OK button. 3. The ?IP Configuration? window should appear, select the Ethernet Adapter that the PC is using from the drop down list. 4. Make note of the ?Adapter Address? which is the MAC Address. Windows XP/2000 1. Click on the Start menu, then click on the Run option. 2. When the ?Run? window opens, input cmd into the ?Open? field, then click on the OK button. 3. When the ?MS DOS Prompt? appears, input ipconfig /all then click on the [Enter] key. 4. Make note of the ?Physical Address? of the Ethernet Adapter (normally ?Local Area Connection?). Accessing the Setup Page 1. Open a web browser such as Internet Explorer or Netscape. 2. When the browser window opens, go to the Address bar and type in the router's IP Address and click on the Go button (192.168.1.1 is the default IP address of Linksys Routers). 3. A window will appear prompting for a ?User Name? and a ?Password?. Leave the ?User Name? field blank, and type in the router's password and click on the OK button to login (admin is the default password). 4. The router's web-based ?Setup? utility should then load. Cloning the MAC Address The steps for configuring the MAC Address Cloning feature of a Linksys router vary depending on the firmware version the router is currently using. From the router?s ?Setup? page, locate the Linksys logo in the upper left-hand corner of the page. Follow the instructions below depending on which logo matches your specific screen: If the logo matches the image above ("Linksys - A Division of Cisco Systems, Inc."), follow these steps. If not, skip to the next logo version. 1. From the ?Setup? page, click on the MAC Address Clone sub-tab. 2. In the ?MAC Clone? section, set the option to Enable. 3. Click on the Clone Your PC?s MAC button. Once this is done, the ?User Defined Entry? will show MAC Address of the Ethernet Adapter of the computer you are using. Verify this address with the ?Adapter Address? or ?Physical Address? observed in earlier steps. 4. Click on the Save Settings button. Then, click the Continue button if prompted. If the logo matches the image above ("Linksys"), follow these steps: 1. From the ?Setup? page, click on the Advanced tab. 2. When the ?Filters? page loads, click on the MAC Addr. Clone tab. 3. When the ?MAC Address Clone? page loads, enter the the ?Adapter Address? or ?Physical Address? that was observed in earlier steps. 4. Click on the Apply button. Then, click the Continue button if prompted. Power Cycling 1. Shut down the computer. 2. Unplug the router?s power cable. 3. Unplug the Broadband modem?s power cable. 4. Wait for 30 seconds. 5. Plug in the Broadband modem?s power cable and wait for its lights to stop blinking. 6. Plug in the router's power cable once the modem?s lights stop blinking. 7. Finally, start up the computer and test the Internet connection.
Feb 16, 2006 | Linksys EtherFast Cable/DSL VPN Router...
Open Questions:
See all Trendware TRENDnet TEW-432BRP 54Mbps Wireless G Questions
Trendware TRENDnet TEW-432BRP 54Mbps Wireless G Firewall Rou Router (TN-432BRP) Logo
420 people viewed this question
Top Trendware Computers & Internet Experts
Prashant M
Prashant M
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
