Question about Hitachi 35CX45B 35" TV
No picture When the tv is turned on, there is sound but no picture. In testing the connections in the back when I pulled the S-video cord and pressed against the back of the set, the picture flashed on and then off. Is this a loose connection or something more expensive? The set is 10 years old and is a 35 inch tube. It is a large TV but it worked great until recently.
  • 2,130 Answers
Can you repeatedly get the picture to come back when you push on the back of the set? If so, yes, its sounds like a bad connection.
What happens when you use the tuner of the TV and with it connected to cable? Do you get a picture?
- Jim
Posted on Feb 19, 2008
Im trying to connect my coby dvd player to my samsui tv
Hi Maria,
You can hear the sound means your TV and the DVD player are working well. May be the video connecting cord ( yellow connector) between the TV and DVD player has gone bad. Please try replacing it. For testing, you can interchange it with any of the two sound connecting cords which have white and red connectors. I hope it helps.
Jan 23, 2016 | Sansui 19 in. LCD TV
MY PICTURE IS GREAT,BUT NO SOUND. WHAT CAN I DO TO FIX IT?
Make sure TV is not muted.Make sure the TV is not set to SAP (secondary audio protocol)Make sure TV input is correct (someone may have accidentally pressed the "aux" input button or similar causing the TV to use an input with no sound going to it)Make sure there is not a pair of headphones connected to the TV audio out jack on the side or front of your TV.Check all of the cables that are connected into the back of your TV. (it is possible the TV was moved slightly and a cable has become disconnected or loose)If you have a receiver or surround sound connected to your TV, turn it on and see if you get sound coming from the external speakers.Turn off the TV, cable box, and anything else connected to the TV. Sometimes turning everything off and then back on can fix the problem.If using an "S" video cable into an input on the back of your TV, these cables carry no sound, just video, so make sure you connect an audio cable too.Hook up an external device to the "TV audio out" input. This will be the test to see if it is a TV circuit board malfunction or the speakers are faulty in your TV.If you are connected to a satellite box, use the included remote and go into the "menu". Check to make sure sound settings are set correctly.
Read More: http://removeandreplace.com/2013/11/14/10-ways-fix-tv-picture-sound/#ixzz3lTeW6isH
Sep 11, 2015 | Televison & Video
Samsung tv hitron
test this steps and fix it. God bless you
  1. Make sure all power cords are connected.
  2. Try pressing the enter/play key.
  3. Make sure the TV is turned on and the input is set properly.
  4. Make sure the TV source is set properly on the TV (This is probably done on the screen; Check your TV manual).
Jul 22, 2013 | Televison & Video
My 32inch lcd tv keeps flickering it started all the sudden
TRY THIS
    • 1 Turn the TV off with the front-mounted power button, not the remote. Unplug the TV's power cord from the wall outlet. Let an hour pass before plugging the cord back into the wall outlet. Turn the TV back on with the front-mounted power button and wait until it has fully restarted. Bring up a TV channel to see if the image being presented on the LCD screen is no longer flickering. A momentary power surge can cause the circuitry inside the LG-brand LCD TV to function erratically.
    • 2 Unplug the video cable from the video connection on the back or side panel of the LG TV. If more than one video cable is connected to the TV, disconnect all of them. Disconnect the other end of the video cable from the video source device that it's attached to -- a DVD or Blu-ray player, or a satellite receiver or cable box. Blow off the connections on the video source device and on the back or side panel of the TV with bursts of compressed air. Reinsert one end of the video cable into the video source device and the other end into the video input that it was connected to. Turn the TV back on with is remote to see if the picture is now free of flickering. A loose or partially connected video cable can cause the LCD TV's screen to flicker when presenting an image.
    • 3 Turn the TV off and unplug its power cord from the wall outlet. Place a power conditioner next to the wall outlet. Plug the power conditioner's power cord into the wall outlet. Plug the TV's power cord into one of the AC sockets on the power conditioner. Turn the power conditioner on. Turn the TV on to see if the picture is now free of flickering. The RF signals in the electric line that the LG TV is drawing power from can cause flicking through interference patterns being generated.
Oct 20, 2012 | Computers & Internet
Toshiba V231 UK VHS manual is lost. Since last week I disconected and then replaced to my Toshiba TV. I can not Autotune it back to play VHS recvordings. I get sound but the tracking just flickers up the...
I believe you are using a RF wire Connecting a VHS, then searching TV station is an old way. I would recommend you use a RCA wire. By so doing, you won't need to tune any station on your TV. All you need to is select Source (AV) on the TV and the VHS would automatically display on your TV.
Below is what the RCA cord looks like:
The yellow stands for video (display), while the red and white stands for audio left and right (sound).
Purchase this cord from any electronics part store within your area, it's not expensive at all.
Look at the back of your TV, connect the yellow cord to "Video IN", connect the red and white to "Audio IN". Then connect the other end of the cord to Yellow: "Video OUT", and red or white to "Audio OUT", at the back of the VHS.
After the above connection, turn on the VHS, insert a tape, and press play. While the VHS is play, turn on the TV, select Source (AV) on your TV and your VHS will start displaying and you will hear sound.
I hope the above is clear. If you need further assistance, please let me know.
Regards.
Sep 20, 2011 | Toshiba Televison & Video
How To Connect A VCR
your question is not clear enough. Do you mean "How to connect VCR to your TV?" If yes, then the below solution is the answer to your question. But if that's not your question, please rephrase your question for proper and accurate solution.
Connecting the VCR to a TV is not a big deal. There are two methods by which you can connect the VCR to our TV.
1. You can use a RF cord.
2. You can use a RCA cord.
I would suggest you use the RCA cord because the RCA connection has a better sound and display quality than the RF. So I would direct you on how to use the RCA connection method.
Here is a picture of what the RCA cord looks like for quick identification;
As you can see from the above picture that there are three cords. The Yellow cord is for display (video), while the with and red is for sound (audio Left & Right).
Turn of the VCR and the TV.
Look at the back of the VCR, connect the yellow to 'video out' and the white and red to 'audio out'. Note that the VCR might have only one audio out, that doesn't matter, just connect any of the red and white.
Now connect the other end of the cord to the back of the TV this way; Yellow will go to 'Video in' while the red & white will go to 'Audio in'.
Turn on the TV and VCR.
Select the TV to Source/AV and the display of the VCR should appear on the TV. Or better still, you can insert a cassette into the VCR, press play before selecting Source/AV on the TV.
By now the connection should be Okay.
If you any more questions or clarifications, please let me know as I would be glad to respond.....
Yours sincerely.
Elect_Comp.
May 26, 2011 | RCA Televison & Video
How do I connect a VCR with the TV
connecting the VCR to a TV is not a big deal. There are two methods by which you can connect the VCR to our TV.
Yours sincerely.
Elect_Comp.
May 24, 2011 | Sanyo Televison & Video
Need directions on how to hook system up to tv
Check the back of the system, you will find Video out, then Audio out (left and right). Connect the yellow cord to video out, and the white & red to Audio out appropriately.
Then connect the other end of the yellow cord to "Video in" at the back of the TV, then the red and white to audio in at the back of the TV.
After connecting as directed above, turn on the TV, then turn on the system. On the TV remote control, press "AV" or "Source" depending on what is written on the remote and there should be a display. If there is no display, press the "AV" or "Source" on the remote once or twice more and there should be a display of the receiver's welcome screen on the TV. You might also need to press "Source" on the system's remote if there no display.
Let me know if you don't av display even after following the above steps. The above is the correct way of connecting so it should work.
Note; The White and Red cords stands for Audio left and right, while the yellow cord stands for Video. The yellow is suppose to allow your system display on the TV screen, while the Red and White is to bring out sound.
I hope the above helps.
Good luck.
Feb 01, 2011 | Audio Players & Recorders
No picture
Instructions
  1. 1 Make sure the power cord is properly plugged into a wall outlet if your TV is not powering on.
  2. 2 Make sure the video and audio cables connecting your TV to external devices are secure if you are experiencing a fuzzy picture or no picture.
  3. 3 Reset the parental password if you forgot the password and are unable to view certain programs. To do this, click "Menu" on your remote control and use the arrow keys to select "Parental Controls." Enter the master password, which is "4357" to reset the password.
  4. 4 Turn off the caption vision option if you are seeing a large black box on your screen. To do this, click the "Menu" button and select "Setup." Select "Caption vision" and press the "Plus" button on your controller to set the option to "Off."
  5. 5 Check the "TV/Video" setting if you're not getting a picture on your screen. You may have inadvertently selected a video input that isn't active. Press the "TV/Video" button on your remote to cycle through video inputs.
  6. 6 Alter the brightness settings if you are experiencing a poor picture or no picture. To do this, press "Menu" and select "Video." Increase the brightness settings to see if the picture begins to appear.
  7. 7 Make sure the volume is not muted if you are experiencing a clear picture but no sound. Press the "Mute" button on the remote control to turn mute on and off.
  8. 8 Power cycle your Sony Wega if it's frozen or not responding to your remote control. Unplug the power cord and wait a few seconds. Plug the power cord back in.
Dec 02, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Tube does not turn on
If TV model is Sony KV-32HS420 then mostly it requires to replace 2 ICs on DZ board, let me know if you can replace ICs on circuit board and know about TV repair to provide you more technical info.
Thanks.
Sep 16, 2009 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Televison & Video Logo
69 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
