Question about Refrigerators
Model 611 - I turned the Unit off to clean the condenser intake grill, and now cannot get it to turn back on.
  • 2 more comments
  • enteleki_ray Feb 01, 2010
    It is NOT in defrost mode. It now has a tempo reading of 40 degrees. Can you help or should I CALL MY OWN REPAIR MAN?
    IT IS NOT ISN THE DEFROST MODE. THE TEMP NOW READS 40 DEGREES/ CAN YOU HALP ME WITH THIS OR SHOULD I CVALL A LOCAL REPAIR MAN?
    CANCEL MY PRESCRIPTION. I CAN'E STAND YOUR STUPID EMAIL SYSTEM, SINCE IT IS GOING IN CIRCLES AND NOT EVEN CLOSE TO SOLVING MY PROBLEM. I WILL NOT ACCEPT ANY CHARGE TO MY CREDIT CARD AS A RESULT AND WILL NEVER CONTACT FIX YA! AGAIN. GO AWAY! M. RAY KINGSTON
    What is wrong? Obviously you don't know anything about my subzero 611.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
May have been in defrost mode. probably working now i suspect if not give a make and model #.
Posted on Feb 01, 2010
  • 1 more comment
  • harold nesmith
    harold nesmith Feb 01, 2010
    make and model #
  • harold nesmith
    have a nice day
  • harold nesmith
    i was trying to help you. i am not being paid in any way. i have extentsive knowlegde regarding your sub zero. call your repairman. sounds expensive. snicker.
Subzero 611 freezer not cooling
Could be but before that check if settings are working. Set the freezer settings to coolest and see if cools. If ok, set to desired temp.
Dec 30, 2013 | Refrigerators
Trying to understand my Candy CRU160K. first, it doesn't seem to be keeping food cold enough, have it turned down to 2. also, there's a drainage hole at bottom, wanting to know where that goes and...
If it it not cooling properly, the first thing you should do is clean your condenser grill (underneath behind the air intake). A dirty grill will effect the cooling efficiency of your unit.
The drain hole empties into a try by your compressor, but the heat and air flow from the fan will evaporate it pretty quickly unless you are cleaning the unit with a lot of water.
Jul 19, 2011 | Candy CRU16.4 Compact Refrigerator
The outside of the freezer is extremely HOT..It is cooling inside. It is in our garage and we have had 39 days of over 100 degree weather. Should we be concerned with this?
Normally when the cabinet is extremely hot it is an indication that the condenser grill is not getting enough airflow accross it to cool down the freon. Then could be because the condenser fan is not operating or the condenser grill is dirty or there is no front to back air flow.
So first thing you need to do is check and make sure the condenser fan is working (the one under your unit). If it isn't then replace the fan motor. If it is functional, then clean the condenser grill (the one underneath the unit) and if that is not the problem, then I would suggest you raise your frigerater up (put on a 2x4 or 4x4 (front to back) to increase air flow.
I have a refrigerator is my garage also, and was having similar issues until I raised my unit up, which also helped with keeping the condenser grill clean.
Jul 14, 2011 | Frigidaire Freezers
Subzero--Vacuum Condenser Signal Won't Turn Off
The vacuum condenser indicator keeps flashing on and off. I did vacuum the unit, the the indicator lights keeps flashing on and off. How can I reset it and keep it off?
Thanks,
Rob
Aug 22, 2009 | Sub-Zero 650 / O Bottom Freezer...
How do I clean the coils Model 363.9762811 Ser#L61961617
I had just posted most of this in another response. It should help you. Remove the grille from the front of the unit beneath the doors and look at the condenser coils. Most people have no clue whatsoever that those must be cleaned periodically. If the airflow is choked off by excessive dirt, the system will overheat, and the performance suffers accordingly. Let it go too long and it's compressor time. Clean with what you have available, one of those polyester featherdusters along with a good vacuum cleaner with crevice attachment along with a dust mask for yourself is highly recommended You may also want to pull the unit away from the wall so to clean from the back as well. There should be a removable panel. While you're in there, make sure the condenser cooling fan is unobstructed and turns freely.
Jun 28, 2009 | Kenmore 64802 Top Freezer Refrigerator
601R sub zero vacuum condenser notice
Your problem might be serious enough to warrant a repairman's visit. But this was my experience: An official Sub Zero repair company in NYC told me this: If the "vacumm condenser" light keeps flashing after you've opened and cleaned the condenser grill, then either pull out the plug for the Sub Zero refrigerator or turn off the circuit breaker (or fuse) in your house that leads to it, wait for some minutes and then turn back on. It is NOT enough to turn off the unit using its own internal on-off switch - it has to be totally disconnected from the AC. I did so, waited 15 minutes, turned back on, and it worked!! I had vacuumed the condenser grill twice but the "vacuum condenser" light kept flashing AND the refrig would go bonkers if set below 38. Now the flashing warning is off and it's down to 35. Great !!!
Jun 27, 2009 | Sub-Zero 601R
Vacuum condenser light of sub zero 650 is on - how to clean it
We recommend vacuuming your condenser every 3 - 6 months. Cleaning the condenser is important for the overall operations of the unit including cooling functions. A dirty condenser may lead to warm temperatures in the refrigerator and freezer. It may also cause the unit to run excessively. It may contribute to condensation or frost inside of the compartments. If the condenser is not cleaned properly it may even cause premature failure of mechanical components in the unit. Condenser Cleaning - All Models Before cleaning the unit, shut the electricity off at the control panel. When you clean the condenser, wear gloves to avoid injury from the sharp condenser fins. Use a soft bristle brush and vacuum to remove dust and lint from the condenser. To avoid bending the condenser fins, be sure to vacuum in the direction of the fins, up and down. Clean the condenser every three to six months or sooner if you have pets. 600 Series Framed and Stainless Steel louvered grilles: First remove the grille screws located at the bottom of the grille. Tilt the top of the grille forward and release the springs from behind the grille, then lift off. Overlay Panel Grille: To remove, lift up then pull out at the bottom and down to release from its mounting bracket. Remove the two black screws in the lowest louver of the grille. Tilt the bottom of the grille out and away. It will release from the top of the grille. Model 601RG Stainless Steel Grille: Remove in a similar fashion as the overlay grille panel. 700 Series All Units: At the bottom of the unit, remove the four screws holding the kick plate/grille in place. It will then slide forward, giving you access to the condenser area. 400 Series 424/424FS At the bottom of the unit, remove the screws holding the kick plate. The condenser is located behind. 427/427R: Remove the four screws holding the kick plate/grille in place. It will then slide forward, giving you access to the condenser area. 430: First remove the screws located at the bottom of the grille. NOTE: These screws (Phillips head) are accessed with the door open. Tilt the top of the grille forward and release the springs from behind the grille, then lift off. 200 Series 245, 249, 315W Remove the kick plate at the bottom of the unit, giving you access to the condenser area.
May 30, 2009 | Sub-Zero 650 / O Bottom Freezer...
Pressure keeps dropping on my jaguar boiler, no leaks in house but hot water coming from overflow outside
hi In most air-conditioning systems, the condenser unit is located outside the house and is prone to accumulate dirt and debris from trees, lawn mowing, and airborne dust. The condenser has a fan that moves air across the condenser coil. You must clean the coil on the intake side, so, before you turn off the power to the air conditioner, check to see which direction the air moves across the coils. Here's how to clean the condenser:
Step 1: Cut down any grass, weeds, or vines that have grown around condenser unit; they could be obstructing airflow.
Step 2: Clean condenser with commercial coil cleaner, available at refrigerator supply stores. Instructions for use are included. Flush coil clean (do not use hose); let dry.
Step 3: Clean fins with soft brush to remove accumulated dirt. You may have to remove protective grille to reach them. Do not clean fins with garden hose, as water could turn dirt into mud and compact it between fins. Clean fins very carefully: They're made of light-gauge aluminum and are easily damaged. If fins are bent, straighten them with fin comb, sold at most appliance parts stores. A fin comb is designed to slide into spaces between fins. Use it carefully to avoid damaging fins.Step 4: Check concrete pad on which condenser rests to make sure it's level. Set carpenters' level front to back and side to side on top of unit. If pad has settled, lift pad with pry bar or piece of 2-by-4, then force gravel or rocks under concrete to level it.
Sep 12, 2008 | Heating & Cooling
Sub-zero 650 vacuum condenser light keeps comming on
Turn the refrigerator off for a minute to reset the vaccum condenser light.
Jan 29, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
