Question about Dell A940 All-In-One InkJet Printer
Not sure how to connect power cord,
cannot figure out how to connect power cord, or if I have the correct one. I need a diagram. bought the printer used, so cord was missing.
  • Dell Master
  • 19,396 Answers
Here is the link to dell download manual page for your printer. You will need usb cable to connect to pc and power cable
link
http://support.dell.com/support/edocs/systems/a940/
cheers
Posted on Feb 19, 2008
I cant send a fax or reseave one
Sir/Madam
Solution one: Check the fax connections Use the following steps to check the physical connections, and then use the HP Fax Test Service.
Step one: Check the physical connections
  1. Disconnect the telephone cord from the HP fax product, and then examine the connector on the end of the cord. Make sure that the cord has only two wires. Figure 1: Two-wire telephone cord
  1. Four-wire telephone cordGraphic: Four-wire telephone cordIf the cord has four wires, replace it with a two-wire phone cord.
    If you must use a cord with four wires, use the converter that shipped with product. The converter allows a cord with four wires to work with a device that requires a cord with two wires.
  2. Connect one end of the telephone cord to the telephone jack, and then connect the other end of the cord to the port labeled 1-Line on the back of the HP fax product.
    Figure 3: Fax only
  1. 1 - Telephone jack2 - Two-wire telephone cord to 1-Line
  2. Connect a single-line telephone to the 2-Ext port on the back of the HP fax product.
    Figure 4: Fax and telephon
  3. 1 - Telephone jack2 - Two-wire telephone cord to 1-Line
  4. Connect a single-line telephone to the 2-Ext port on the back of the HP fax product.
    Figure 4: Fax and telephone
1 - Telephone jack 2 - Two-wire telephone cord to 1-Line
3 - Telephone
If other devices need to use the same telephone jack, make sure that they are connected to the 2-Ext port on the back of the HP fax product.
Figure 5: Fax with answering machine and telephone
  1. 1 - Telephone jack2 - Telephone cord from 2-Ext
    3 - Optional telephone cord to telephone
    4 - Optional telephone
    5 - Answering machine
    6 - Two-wire telephone cord to 1-Line
  2. Pick up the telephone receiver and listen for a dial tone. Make sure that you can dial out using the telephone keypad.
    If there is a dial tone and you can dial out using the telephone, the HP fax product is connected correctly to a working telephone cord and telephone jack. If there is no dial tone, check the configuration again and make sure that it is set up correctly.If You Still Having Hp Printer Problem Then Visit Official HP Printer Website On Below Link URL http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c02263145
Or
If You Still need HP Printer Online Help Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP LaserJet 3030 All-In-One Printer
It wont turned on
If you are encountering power problems with your printer, please go through the following checklist:
  • Make sure the power cord is plugged in securely and directly to the power outlet. Power surge protectors can draw power away from the printer.
  • Disconnect the power cord from the power outlet and the back of the printer and then reconnect it.
  • Check the power supply box (if there is one) to see if it is warm or cold, as there could be a defective power supply issue.
  • If there is access to a voltmeter, test the power supply to ensure that it registering the correct amount of voltage (most Lexmark printers have a 30Volt output).
  • Make sure the correct power supply is connected to the printer.
Mar 21, 2012 | Lexmark X2500 All-In-One Printer
No power to LexMark x6650
Jan 18, 2012 | Lexmark X6650 4-In-One Wireless InkJet...
Can't get it to turn on
Jan 18, 2012 | Lexmark Z715 InkJet Printer
Lexmark printer X9575 will not turn on
Please go through the following checklist: - Make sure the power cord is plugged in securely and directly to the power outlet. Power surge protectors can draw power away from the printer. - Disconnect the power cord from the power outlet and the back of the printer and then reconnect it. - Check the power supply box (if there is one) to see if it is warm or cold, as there could be a defective power supply issue. - If there is access to a voltmeter, test the power supply to ensure that it registering the correct amount of voltage (most Lexmark printers have a 30Volt output). - Make sure the correct power supply is connected to the printer.
Source: The Printer is Not Powering On
May 12, 2011 | Lexmark X9575 InkJet Printer
My printer is not set up to print yet what do I do
Setting up the All-in-One Follow these steps in order. When you are finished, you can click the appropriate link at the end of this document if you need instructions to install the product software. CAUTION: Do NOT connect the USB cable now. You need a USB cable to connect the product to the computer, but you will be prompted to connect it at the correct time during software installation. Step one: Unpack the All-in-One
  1. Lower the paper tray and remove all packing material. Figure 1: Lower the paper tray
  2. Lower thecartridge door and remove all packing material.
Step two: Check the contents of the box The contents might vary by country/region. See the packaging for a list of items shipped in the box. Step three: Connect the power cord and adapter Connect the power cord and adapter. Step four: Turn on the power
  1. Press the On button
  2. Wait 30 seconds for the product to start up.
Step five: Load plain paper
  1. Pull out the tray extender.
  2. Load plain white paper.
  3. Figure 6: Load plain white paper
Step six: Install the cartridges
  1. Open the cartridge door. Make sure the carriage moves to the center. If it does not move to the center, turn the product off and then turn it on again. NOTE: The product must be turned on to insert cartridges. Open the cartridge door
  2. Remove the tape from both cartridges. CAUTION: Do not touch the copper-colored contacts or re-tape the cartridges. Figure 9: Copper-colored contacts
  3. Hold the cartridges with the HP logo on top.
  4. Insert the tri-color cartridge in the left cartridge slot and the black cartridge in the right cartridge slot. Make sure to push the cartridges in firmly until they snap into place.
  5. Push the cartridge in firmly
  6. Close the cartridge door
Step seven: Align the cartridges Make sure that paper is loaded in the tray, and then wait a few minutes while the cartridge alignment page prints. After the alignment page prints, place it face-down on the glass and close the lid. Press the Scan button to complete the alignment. Wait until the green On light stops blinking. to see full diagrams please follow the link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00853006&cc=ca&lc=en&dlc=en&product=3177566
Jun 28, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
I just bought a used Lexmark X1240. The only
Yes, it needs a power cord. Refer to this Setup Guide:
X1200 Series Setup Guide
See step 2.
You can order it from Lexmark. See:
Power Cord 21B0106
If you are not in the US or Canada, Comment back and we'll track the correct one down.
Thanks for using Fixya.
Nov 25, 2009 | Lexmark X1240 All-In-One InkJet Printer
Bought a display model of the pixma mx700 series
1. If you bought it from a store bring everything back with receipt and tell them they need to correct the problem.
2. You lucky you even got a power cord what brand of printer is it. Most company's don't even supply a power cord with the printer.
Jan 04, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Power cords
Is it too late?
From the HP support:
Power specifications
. Power consumption: 50W maximum
. Source (Input) Voltage: 100 to 240 VAC*, grounded
. Input Frequency: 50 to 60 Hz
. Current: 1A maximum
* Figures are based on using the AC adapter that came with your unit (HP part number 0950-2880)
Don't know if you can get an adapter, but at least you have a part #.
Dec 10, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
85 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
