Targus PA570U Path-Through Scanner Logo
Anonymous Posted on Feb 01, 2010
I can not download my pics from the chip using a new targusThe chip works in my small HP printer but I want to get them on my desk top and into Picassa.
NIK
Level 2:
Sergeant:
  • Expert 206 Answers
  • Posted on Feb 01, 2010
NIK
Expert
Level 2:
Sergeant:
Answers
206
Questions
0
Helped
59248
Points
540
Here is the website for TARGUS
I found one refence for the PA570u but no drivers. This page has a support phone number,
Call Targus Support: 1-877-482-7487
Good Luck
Testimonial: "thanks"
I've changed windows in my Lenovo desk top now touch screen is not working which drivers must I download please
i think you will have to install the drivers for touch screen to work. Just download a small utility called 3DP chip from
3DP Chip download
Just install it and it will recognize all your hardware and will provide you the links to download the drivers.
6answers
I just purchased a Kodak printer to print my digital pictures. When I try to look at the pictures wheather the memory chip is in the camera or directly in the printer it will only read 46 of the 200 or -...
If that's the case try connecting the the camera to your computer then print all the pictures then format your memory chip to make sure this is not a problem with the memory chip...
Hope that helps.......
2answers
Can't instal printer to Desk top. Lost Disk to my HP F4280
Hi
You can download the drivers for your printer from this link---
HP F4280 printer's driver
After opening the link, select your operating system (win xp/vista,etc). After downloading the driver on to your computer, run the setup and install it. After installation is complete restart your computer.
Daniel Scott
Trying to use a re-filled ink cartridge HPf4280
I seem to recall that these cartridges are chipped and you need to get a chip resetter. Look on the base to see if a small circuit board is present. If so then you have to get it reset or buy a new cartridge.
Please rate my help++++Thanks for using FIXYA
I need to DOWNLOAD THE HP 1210 PSC INSTALLATION FOR THE DESK TOP
what OS are you using? if you are using win 7 no need, but you can visit hp.com for driver downloads
Print quality problem with Windows 7 and HP DeskJet3650.
You need drivers for win 7 only for the two printers you have .some of the mfg, have not got all the bugs out as yet. Im in the same boat .had to get a new model so i could print. Check windows web. site for driver 7up dates.hope this helps
4answers
How do i install a toner chip on my hp Cp2025
TONER CHIP on CP2025 printer:
This resource may help
http://resources.lasertekservices.com/hp-smart-chips-overriding-this-lockout-mechanism-with-reset-chips/
Gives types of chips to use, sales in USA, and certain things to take note of.
The toner reset chip replaces the original HP ID chip and is designed to be used only on refilled HP cartridges.
It is not recommended to force toner cartridges to run on empty, as this can cause damage to both the printer and the toner cartridge.
The reset chips are dedicated to one color only, so that user can not swap toners.
As for actual physical installation, just push the new ID chip in until it clicks into place. The correctly manufactured ones should be a snug fit.
I have seen techs using a drop of contact glue behind the chip-board to secure it.
Copper pads face outwards towards matching printer pins.
See photo for polarity 'square' pad.
My printer is Samsung, not HP, so your toner cartridge may be a different shape.
1helpful
2answers
I Lost My HP OfficeJet V40 Software CD
go to www.hp.com and click on "Support and Drivers". Type in the name of your printer and you can download the drivers onto your new computer so your printer will work.
2answers
New vista windows working with a wireless routerand a new laptop
this can be done..want to do a Shared screen experience? send me a note to my email from my profile.
Top Targus Office Equipment & Supplies Experts
k24674
Are you a Targus Office Equipment and Supply Expert? Answer questions, earn points and help others
