Tv does not have power. power cord is good and so is fuse, but no power in tv. led light on TV does not come on.
  • edwardmartin Feb 04, 2009
    my tv will no turn on i have a philips model number 64p8342
  • Anonymous Feb 20, 2009
    I have the same model #. It started last summer when the tv would not turn off. It had to actually unplug the tv to get it to turn off. It would start back up just fine and then it would do it again. The last time it it would not turn on at all, with the remote or by pushing the on off switch on the tv. I called a service tech and they came out and told me the tv was junk and to buy a new one, charged me $120 and left. a few months later I still had this huge tv in my living room wondering what to do with it and decided I would just try to plug it back in and turn it on. It worked! Like nothing was ever wrong with it. Last week it would not turn off again so I unplugged it and now it will not turn on again. I wonder if it is something in the switch or something. I love the tv but not the current issues. Don't know what can be done to fix it..any answers?
  • 126 Answers
Well check bridge diodes first probally more then one fuse also transitter leakey cap bad solder or open bad resistor trouble soot if you can not perform call service tech.
Posted on Feb 19, 2008
Our LG TV will not power on. No light, no sound, nothing. How can we check the fuse on the power supply? Or could it be the power cord?
Hi Dfhamilton,
Damages due to lightening surge can go to any extent in a tv set. If you can, please open the back cover and check the fuse. Replace with the same rating one if you find it blown. Switch on the set. If it works, enjoy watching. If it blows again, please consult some TV tech.
Good Luck.
Aug 17, 2015 | LG 42LE5400 42-Inch 1080p 120Hz LED LCD...
Tip
My television does not start up
Hi.
If there is no power at all, no led on, and no sign of life whatsoever, that means that the problem is either the power cord, or the internal power supply board.
In that case test the TV using a different power outlet (eventually use an extension). If the power cord is fused, like in UK for example, then check and replace the fuse in the power cord.
If instead the TV stays in stand-by, with the LED light on, but does not respond to remote, or to the buttons on the chassis, then the TV is in protect (safe) mode because an internal fault had been detected.
In that case the TV is probably faulty.
Follow the troubleshooting on this article: Why my TV does not start up and remains in...
If that does not work, contact the manufacturer at the number listed on the owners manual to get the TV repaired by a licensed technician.
Regards.
on Feb 18, 2010 | Televison & Video
My tv no have power
First thing if you are able is follow the power cord inside and check the fuse it goes almost directly to.
Dec 16, 2012 | Sharp 21B-S10 21" TV
Element (FLX-3210) I lost sound when I unpluged my pc plug from my laptop to the TV. Then I went to the tv output which had picture on the screen but no sound. Once the power was turned off the tv it...
The tv turn on now have power and LED power light indicator is on and solid green?Yes,than it is the main Tuner signal board had a short some where and it is the problems and the causes.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Nov 29, 2010 | Element Electronics FLX3210 32 in. LCD TV
HAD A POWER SURGE NOW MY TV WONT POWER ON
The tv power LED light now totally dead or power LED light indication flases?The tv power supply board is dead.That the board,where the power a/c cord plug into it.Tries website like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 11, 2010 | Sceptre X23BV-Naga 23 in. LCD TV
SAMSUNG LN52B610 TV TURNED OFF BY ITSELF. CANT TURN TV ON. NO RED LIGHT ON TV FOR POWER. OUTLET WAS CHECKED AND HAS POWER. CORD IS IN GOOD CONDITION. PLUGS FIR SNUG IN...
Hello.
If you have multimeter available you can actually check if voltage present at the end of your power cord first.
If it's OK than you have to remove back cover from your TV and locate power supply board. It's very easy - it should be next to the power cord receptacle. First look for capacitors that have bulged tops instead of flat ones. If you locate any - replace them and check if it's going to take care of problem.
Right next to receptacle connection is fuse located and you have to check if it's open. Replace it if needed. If new fuse got blown right away - you have short in power supply board. If fuse is OK - connect power cord and using multimeter try to figure out if 5V is supplied from Power supply board to the main board (the one that have all inputs attached to it). If 5V is present but power LED in front of the TV is still dead - you could have problem with main board.
Best regards.
Russ.
Aug 17, 2010 | Samsung LN52B610 52 in LCD TV
Does toshiba 27d46 have a reset button? my tv will not turn on and the led light is not on either. checked the power cord & outlets. help!!!
check for the blown FUSE after the power cord.Check standby power section for a defective component.
Apr 27, 2010 | Toshiba 27D46 27" TV
The TV will not turn in (by remote or from the tv)
Is the standby LED light off ? Do you hear clicking sounds when you press the power button on the TV ?
If not it's probably the power supply board. Look at the fuses(s) on the power supply board. If the fuses are good you may have to replace the board if bad.
Mar 13, 2009 | Hisense TL1700 17 in. LCD Television
Hitachi 43GX10B power issue
Remove back of TV, plugin AC cord & observe which LED's light / stay lit / go out ..
base your continuing research on what you see...................T.
Oct 30, 2008 | Televison & Video
Televison & Video Logo
99 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
