Changing a belt on a GE WWA6600MAL. Do I remove the coupling to the pump to install the belt?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
Yes, to get belt past then reinstall. three bolts on motor. loose them put belt on tightned motor after taking slack out of belt
Posted on Feb 01, 2010
Testimonial: "Thank you for your input it was very helpful!"
I would like instructions on changing a water pump in 2005 Chevy uplander V6 3900
This is probably the easiest water pump of all vehicles to change.
Water Pump Replacement
Removal Procedure
  1. Drain the cooling system.
  2. Loosen the water pump pulley bolts.
  3. Remove the drive belt.
  4. Remove the water pump pulley bolts and pulley.
  1. Remove the water pump bolts, pump, and gasket.
  2. Clean the water pump mating surfaces.
Installation Procedure
  1. Install the water pump gasket and pump (1).
Notice: Refer to Fastener Notice in Service Precautions.
  1. Install the water pump bolts.
    • Tighten the bolts to 10 Nm (89 inch lbs.) .
  1. Install the water pump pulley and bolt until snug.
  2. Install the drive belt
  3. Install the water pump pulley bolts.
    • Tighten the bolts to 25 Nm (18 ft. lbs.) .
  1. Fill the cooling system
  2. Inspect for leaks.
Aug 18, 2013 | Cars & Trucks
How do I replace the moter belt
Hi
Use screwdrivers to remove the screws in the rear access panel of the washer and then pull off the panel.Locate the pump coupling, which is the rubber part that connects the motor to the water pump, and unscrew the clamps securing it to the motor. Once the coupling is removed, tension is removed from the belt.Slide the belt off of the pulley assemblies and slide the new belt in its stead. Reattach the coupling with the mounting clamps and check the tension on the belt. You should be able to wiggle the belt a bit, but not more than an inch or so.Close the access panel and turn on the machine. Run it through a cycle while observing it to see how it handles the belt change.
Also check the bellow link :-
http://www.ehow.com/how_5545267_replace-ge-washer-belt.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 02, 2011 | GE WSXH208A Front Load Washer
Procedure on changing waterpump
  1. first drain the cooling system.
  2. loosen bolts on the waterpump pulley and remove the inner fender cover on the pass/side.
  3. remove the surpentine fan belt, note; make a diagram of the belt routing so belt will go back on the right way.
  4. remove the bolts you loosened on the pump pulley, use a pry bar to pry engine back to have enough room to remove the waterpump pulley.
  5. remove the bolts holding waterpump, you will want a pan under the van to catch coolant when waterpump is removed,
  6. remove the pump and clean old gasket off the block and install new pump,
  7. reverse to install new pump and fill system with coolant allow engine to run until thremostat opens,hope this is helpful. heres a few diagrams of the waterpump and the cover and the belt routing, good luck and hope this is helpful.
Oct 27, 2010 | 2005 Dodge Caravan
Where is water pump and drive belt located on 2003 corolla ? Dealer recommended it needs changing along with timing chain tensioner which they say is leaking oil . I usually fix my own cars after doing my...
Water Pump Removal & Installation To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Drain the engine coolant.
  3. Remove the right lower splash shield.
  5. Remove the 6 water pump mounting bolts. Remove the water pump and O-ring (except XRS). toy_car_18_eng_wtr_pmp_set_blts_sst.gif
  6. Using special tool 09960-10010 or equivalent, remove the water pump pulley bolts and pulley (XRS).
  7. Remove the 6 water pump mounting bolts. Remove the water pump and O-ring (XRS).
To Install:
  1. Install a new O-ring on the timing chain cover. toy_car_18_eng_wtr_pmp_blt_torque.gif
    Note: Bolt lengths are indicated in the illustration bolt (1) 1.18 inches (30mm) bolt (2) 1.38 inches (35 mm)
  2. Install the water pump (except XRS).
    1. Tighten the mounting bolts (1) to 80 inch-lbs (9 Nm).
    2. Tighten the mounting bolts (2) 8 ft-lbs (11 Nm).
  3. Install the water pump (XRS).
    1. Tighten the mounting bolts 80 in lbs (9 Nm).
    2. Install the water pump pulley using special tool 09960-10010 or equivalent. Tighten the mounting bolts 11 ft lbs (15 Nm).
  4. Install the right lower splash shield.
  5. Install the drive belt.
  6. Fill the cooling system.
  7. Check for leaks.
Oct 09, 2010 | 2004 Toyota Corolla
Where is the water pump
Water Pump REMOVAL & INSTALLATION 5VZ-FE Engines Fig. 1: The water pump is located on the front of the engine block, behind the timing cover 93163p92.jpg
Fig. 2: Once the retainers are removed, pull the pump away from the block 93163p97.jpg
Fig. 3: Scrape any remaining gasket material from the block before installing the new pump 93163p98.jpg
Fig. 4: Water pump mounting bolt locations 93163p88.jpg
Fig. 5: Front view of the water pump and thermostat housing 93163p99.jpg
WARNING
This procedure requires the removal of the timing belt. This is an extensive procedure requiring precision work, particularly at assembly. For more information, refer to Timing Belt Removal and Installation. Do not attempt to remove the belt without consulting the procedure; extreme engine damage may occur. Fig. 6: Apply sealant to the areas shown 86823pi7.gif
Fig. 7: A and B bolt locations 86823pi8.gif
Fig. 8: Exploded view of the water pump arrangement — 5VZ-FE engine 93163g19.gif
  2. Remove the timing belt. For additional information, please refer to the following topic(s): Timing Belt Removal and Installation.
  3. Remove the idler pulley.
  4. Remove the thermostat.
  5. Disconnect the oil cooler hose from the pump.
  6. Remove the seven bolts and the tension spring bracket and then remove the water pump. To install:
  7. Clean all parts well. It is good practice to carefully clean all threaded openings, especially those exposed to coolant to remove rust and scale so at assembly, an accurate torque reading is obtained. This is important since gasketless applications like this depend on even clamp loads from the fasteners to avoid distortion and leaks. Remove any old sealer (Toyota calls it packing) from the pump and mounting area of the engine. Keep oil off the mating areas.
  8. Apply Formed In Place Gasket (FIPG) sealer to the pump-to-block mating surface and then tighten the bolts marked A in the illustration to 13 ft. lbs. (18 Nm). Tighten those marked B to 14 ft. lbs. (20 Nm). NOTE: The parts must be installed within 5 minutes of application of the sealant. Otherwise you must remove and reapply the sealer.
  9. Connect the oil cooler hose.
  10. Install the thermostat with a new gasket.
  11. Install the idler pulley.
  12. Install the timing belt.
  13. Install the drive belts and adjust the tension.
  14. Refill the cooling system and check for leaks.
2RZ-FE and 3RZ-FE Engines
  1. Disconnect the negative battery cable.
  2. Drain the cooling system.
  3. If equipped with an air conditioning compressor or power steering pump drive belts, it may be necessary to loosen the adjusting bolt, remove the drive belt(s) and move the component(s) out of the way.
  4. Remove the fluid coupling with the fan and water pump pulley.
  5. Remove the water pump. To install:
  6. Clean the gasket mounting surfaces.
  7. Install the replacement water pump using a new gasket.
  8. Install the water pump pulley and fluid coupling with the fan.
  9. Install the removed engine drive belts.
  10. Fill the cooling system.
  11. Connect the negative battery cable. Start the engine and check for leaks.
  12. Bleed the cooling system.
1FZ-FE Engine Fig. 9: Exploded view of the water pump mounting on the 1FZ-FE engine 86823pk0.gif
Fig. 10: Detach the oil cooler hose from the clamp on the fan shroud 86823pk3.gif
Jul 13, 2010 | 1997 Toyota RAV4
Timing chain is loose how do I replace or tighten
You need to pull out the timing cover. 4-6 hours of work. Here is the step to remove the Cover, then you need to remove the Sprockets.
  1. Remove the oil pan.
  2. Remove the power steering belt if so equipped.
  3. Remove the air conditioning belt, compressor and bracket if so equipped.
  4. Remove the fan clutch (fluid coupling), with the fan and water pump pulley.
  5. Matchmark and remove the crankshaft pulley(s). This bolt will be very tight. Use the counter-holding bar, properly installed, to hold the crankshaft while loosening the bolt. Use the pulley extractor or gear puller to remove the pulley from the shaft.
  6. Remove the water bypass pipe.
  7. Remove the fan belt adjusting bar. If necessary, remove the lower power steering bracket for access.
  8. Disconnect the heater water outlet pipe.
  9. Unbolt the timing chain cover assembly. Be careful to loosen only the correct bolts.
To install:
  1. Install new gaskets over the dowels on the timing chain cover. Slide the cover assembly over the dowels and pump spline. Insert the retaining bolts and tighten them. Tighten the 8mm bolts to 9 ft. lbs. (13 Nm) and the 10mm bolts to 29 ft. lbs. (39 Nm).
  2. Temporarily install the adjusting bar to the alternator. Install the adjusting bar to the chain cover and tighten the bolts to 9 ft. lbs. (13 Nm).
  3. Install the heater water outlet pipe.
  4. Install the water bypass pipe.
  5. Install the crankshaft pulley and bolt. Use the counter-holding tool to hold the pulley and tighten the bolt to 116 ft. lbs. (157 Nm). If equipped with air conditioning, install the second crankshaft pulley.
  6. Install the water pump pulley and fluid coupling with the fan.
  7. Adjust the tension on the drive belts.
  8. Install the air conditioning compressor bracket, compressor and belt if they were removed.
  9. Install the power steering belt and adjust it.
  10. Attach the oil pan.
  11. Install the radiator.
Jun 04, 2010 | 1987 Toyota Pickup
How to replace a water pump on a 1995 bmw 318is
  1. Disconnect the negative battery cable. Drain the cooling system.
  2. Remove the distributor cap and rotor. Remove the rotor adapter, the dust shield and the distributor housing.
  3. Remove the fan. The fan must be held stationary with tool 11 5 030 or some sort of flat blade cut to fit over the hub and drilled to fit over 2 of the studs on the front of the pulley. Remove the fan coupling nut; left hand thread-turn clockwise to remove.
  4. Remove the belt and pulley.
  5. Remove the rubber guard and distributor and or upper timing belt cover.
  6. Compress the timing tensioner spring and clamp pin with the proper tool.
Observe the installed position of the tensioner spring pin on the water pump housing for reinstallation purposes.
  1. Remove the water hoses, remove the 3 water pump bolts and remove the pump.
To install:
  1. Clean the gasket surfaces and use a new gasket.
  2. Install the water pump in position. Note the position of the tensioner spring pin. Torque M8 bolts to 16-17 ft. lbs. (20-24 Nm) and M6 bolts to 6-7 ft. lbs. (8-10 Nm). Connect the hoses.
  3. Release the tensioner from the holding pin. Install the upper timing cover. Install the pulley and tighten the bolts to 6-7 ft. lbs. (8-10 Nm). Install the belt and tighten.
  4. Install the fan, distributor housing and dust shield. Tighten the rotor adapter to 39-47 ft. lbs. (55-65 Nm). Install the rotor, O-ring and cap.
  5. Add coolant and bleed
Dec 30, 2009 | BMW 318 Cars & Trucks
Changing water pump 2000 ford focus
Changing a water pump is pretty basic. Since the coolant system is a closed system you only need to be concerned with that system. For instance you since you have to mess around with it anyway you might as well change the thermostat and flush the coolant system. Make sure your radiator hoses are in good shape and that's about it.
If you have basic mechanical skills and tools you will have no problem replacing a water pump.
As far as information with the actual replacement there are a number of experts here including myself that could explain how to do it.
However no matter how good our explanations are it just can't compare to a good repair manual.
A repair manual for your car at Auto Zone would likely cost between $12 and $15. It is a great investment if you are going to keep your car for any length of time. When you sell, it shows the buyer you took the time to maintain and repair it right.
I personally like Haynes Manuals.
I hope this helps.
Nov 11, 2009 | 2000 Ford Focus
How do you remove the water pump on a 2006 monte carlo
  1. Drain the cooling system. Refer to Draining and Filling Cooling System (LS4 Static Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9 Static Fill) Draining and Filling Cooling System (9C1, 9C3 Static Fill) Draining and Filling Cooling System (LS4 GE 47716 Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9, 9C1, 9C3 GE 4771 Fill).
  5. Remove the water pump bolts.
  6. Remove the water pump and gasket.
  7. Clean the water pump mating surfaces
    1. Position a NEW water pump gasket and the water pump to the engine front cover. Notice: Refer to Fastener Notice.
    2. Install the water pump bolts. Tighten the bolts to 10 Nm (89 inch lbs.) .
  1. Install the water pump pulley and bolts.
  2. Install the drive belt.
  3. Tighten the water pump pulley bolts. Tighten the bolts to 25 Nm (18 ft. lbs.) .
  4. Fill the cooling system. Refer to Draining and Filling Cooling System (LS4 Static Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9 Static Fill) Draining and Filling Cooling System (9C1, 9C3 Static Fill) Draining and Filling Cooling System (LS4 GE 47716 Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9, 9C1, 9C3 GE 4771 Fill).
  5. Inspect for leaks.
Hope this helps
Oct 01, 2009 | 2006 Chevrolet Monte Carlo
Changing power steering pump
Power steering pump special tools
Power Steering Pump Removal & Installation Power Steering Pump (2V) To Remove:
  1. Before servicing the vehicle refer to the precautions at the beginning of this section.
  2. Disconnect the battery ground cable.
  3. Remove the accessory drive belt.
  4. Remove the alternator.
  5. Drain and remove the radiator coolant recovery reservoir.
  6. Position a drain pan under the power steering pump underneath the vehicle. Disconnect the hydraulic pressure and return lines and allow to drain.
  7. Remove the idler pulley from the power steering pump support.
  8. Remove the belt tensioner.
  9. Remove the bracket mounting bolt located under the belt tensioner mounting.
  10. Remove two retaining nuts from the bracket mounting studs. Remove both mounting studs, and pull off the power steering pump support with the pump attached.
  11. Clamp the pump support bracket in a suitable vise.
  12. Remove the power steering pump pulley from the pump shaft using Pump Pulley Remover T69L-10300-B, or equivalent. Remove the three bolts retaining the power steering pump to the power steering pump support and remove the power steering pump.
To Install:
NOTE: The pulley must be installed within 0.010 in (0.25 mm) flush with the power steering pump shaft.
  1. Install the power steering pump to the power steering pump support. Tighten the mounting bolts to 18 ft-lb. (25 Nm).
  2. Install the power steering pump pulley using Steering Pump Pulley Replacer T65P-3A733-C, or equivalent; the pulley face must be flush within 0.010 inch (0.25mm) of the pump shaft.
  3. Install the power steering pump/pump support and torque nuts/bolt to 24 ft. lbs. (33 Nm).
  4. Install the bracket mounting bolt located under the belt tensioner mounting.
  5. Install the belt tensioner.
  6. Install the idler pulley to the power steering pump support.
  7. Connect the hydraulic pressure and return lines.
  8. Install the radiator coolant recovery reservoir.
  9. Install the alternator.
  10. Install the accessory drive belt.
  11. Fill the power steering reservoir with power steering fluid.
  12. Connect the battery ground cable.
  13. Run the engine and check for leaks and proper operation. Bleed the power steering system if needed.
Jun 28, 2009 | 1999 Ford Taurus
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
