Question about Zanussi ZX99 / 5 Bottom Freezer Refrigerator
Zanussi ZX99 temp alarm problem, how to de-activate alarm ?
I have a Zanussi ZX99 with the same temp alarm problem as others have had, however both compartments do not warm up at all, so I think it may be the sensor, does anyone know the location of the alarm module itself ?, as I would like to de-activate until I fix the problem. Thanks
SOURCE: Zanussi ZX99/5SI
I had this problem with my ZX99. In my case it was caused by faulty temp sensors not making the defrost system kick into place. The defrost cycle works by heating an element for every week or so for a few minutes.
Posted on Aug 01, 2007
  • 66 Answers
SOURCE: zanussi zx99/5 freezer working fine
This may be an airflow problem. These are things to check. Make sure the temp control in the fresh food section for both the freezer and the fresh food is set half way between coldest and warmest temp setting. Over adjusting these settings can cause poor air circulation and make the fresh food section too warm. When openning the freezer, the evaporator fan should be on or start shortly. If the evaporator fan stops working, there will be no circulation to cool the fresh food section and will need to be checked to see if it is bad. If bad it will need to be replaced. The evaporator in the freezer section may be iced over causing poor air flow to the fresh food section. You may need a service tech to check this part. If the evaporator is iced over, stopping air circulation, the button thermostat or defrost element may on the evaporator may be bad and could possibly reqiure a technician to replace it Check the first two things and let me know what you find and how it is doing after reseting the temp control. I will be happy to help you in any way I can..
Posted on Nov 10, 2008
SOURCE: zanussi refrigerator/freezer model ZX99/5
I had the same problem...it was a defrost problem in the freezer....mad i know...fridge doesnt work but freezer does...so its the freezer problem right!!!
This is how i solved it....there is fan behind the freezer compartment....you need to remove all the freezer draws then the plate at the back of the freezer compartment(everything is accessible from inside the freezer only) once removed you can put your hand up inside the gap(make sure power is off and unplugged) just in reach is the fan which you should be able to rotate with your fingers...mine was covered in ice and not able to move as a result the cold air couldnt be blown up into the fridge(the only thing controlling the air into the fridge is a flap and depending upon what fridge setting you have this determines how much cold air its letting in.)
If the fan has been frosted up you need to defrost the freezer....and source a new defrost sensor.
hope it helps.
Posted on Mar 28, 2009
  • 8 Answers
SOURCE: zanussi zx99/5 not working ,lights still working
sounds like the thermostat inside the fridge has gone.
The information I have provided is a guide and is not directly related to the make and model of the appliance brand you have but seems to cover the majority of household fridge freezers I have come accross. There is a dial inside the fridge usually up on the right side wall of the fridg where the light is. It is usual for the thermostat unit to be inside the plastic housing behind the dial. It is easy to replace the thermostat because I have done it myself and it worked. I am not an expert so if I can do it then anybody could. the unit is usually a standard replacement unit which costs roughly £20.00 available from fridge freezer repair shops. I got my replacement from Sale Appliances, Victoria Avenue, Southend-on-Sea, Essex. The unit comes with the thermometer type wire which fixes to the back of the fridge - inside that is- already attatched to it and all you need to do is remove the screw holding the housing in place (unplug from mains first of course), remove bulb, prise off the plastic housing to reveal thermostat unit, take some detailed pictures of how the wires are attatched or take detailed notes and diagrams, pull off the eelectical connectors (may need a pair of pliers to help, but must be gentle so as not to rip wires out of the connectors), put in new thermostat and rewire as it was before. You will not have to literally rewire the thing but simply slide the wired connectors onto the correct place. The connections are numbered both on the old unit as well as the new unit. Dont worry if the connectors on the rear of the new unit is different to the old one so long as you connect the wires to the same number it wont matter where that connector is located e.g. number two always fixes to the number two marked on the unit, number 3 to numbr 3 etc.
Posted on Aug 08, 2009
  • 1891 Answers
SOURCE: i have a zanussi electrolux zx99/5w the freezer is
LOOK INTO THE FREEZER SIDE AND IF THE BACK OF FREEZER HAS ICE OR FROST BUILD UP / THE PROBLEM IS A DEFROST PROBLEM . The ice build up is blocking the air flow through the cold coil . the correction would be to repl the heater of the a d c control whitch controls defrost .. hope this helps ,mm
Posted on Jul 22, 2010
Fridge temperature rising - currently at 10 degrees. Internal temperature alarm not being triggered. Freezer not affected. Motor running when door opened/closed.
Although I have never worked on a Zanussi unit, from what you have said it is a classic frost build up in the cooling tubes, which is usually a result of defrost system failure. To verify this you can manually defrost your unit. If the problem goes away, then you need to troubleshoot your defrost circuit, because it will be back in days or weeks.
Sep 14, 2011 | Zanussi ZX99 / 5 Bottom Freezer...
I have zanussi zx99/5w and fridge not working and freezer cold but not freezing
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 17, 2010 | Zanussi ZX99 / 5 Bottom Freezer...
I have a zanussi electrolux zx99/5w the freezer is working but the fridge isn't cooling down
Jul 22, 2010 | Zanussi ZX99 / 5 Bottom Freezer...
Zanussi Zx99/5SI fridge not chilling freezer Frozen over
Tell you what, first do a good 12 hour defrost and restart. Chances are you left the door ajar accidentally. (even though you say you never,) Most of the time there is the issue. If it continues after that, let me know and ill go through the defrost procedure (the cheap way)..
Sep 26, 2009 | Zanussi ZX99 / 5 Bottom Freezer...
Zanussi refrigerator/freezer model ZX99/5
hope it helps.
Feb 24, 2009 | Zanussi ZX99 / 5 Bottom Freezer...
Trips Electric every 7-8 hours
you actually have in a way since the timer on the defrost goes into every 8 hours.
Jan 30, 2009 | Zanussi ZX99 / 5 Bottom Freezer...
BAD SMELL/CONSTANT BEEPING OF ALARM
if you have a gas like oily smell id advise calling a tech get a factory authorized tech as seal systems are most often under extended warrenties and get your food some where cold sorry but that would be my best advice
Dec 31, 2007 | Zanussi ZX99 / 5 Bottom Freezer...
Zanussi ZX99 / 5 lights flashing
I have the same problem and cant get to the bottom of it. As you say the fridge is fine and remaining at the temperature that you want it (as does my freezer section of it) and does become extremly annoying after a while.... I would be gratfull if anyone else has a cure for it !
Nov 21, 2007 | Zanussi ZX99 / 5 Bottom Freezer...
Zanussi ZX99/5SI
you have a fault in the defrost system - possibly due to a faulty module
Jul 14, 2007 | Zanussi ZX99 / 5 Bottom Freezer...
Zanussi ZX99 / 5 Bottom Freezer Refrigerator Logo
69 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
