Question about Lexmark X5150 All-In-One InkJet Printer
Lexmark x5150 scanner locked
Just put in two ink cartridges have a new computer installed the printer scanner. when i turn on the printer it clicks and tells me to unlock scanner then press power, i tried all buttons and will not let me do anythiing. please help! thank you mike
  • 1 more comment
  • antcat3 Apr 28, 2008
    I have the same problem and I even unlocked the scanner and I still have the same problem. It keeps clicking and the scanner wont return to the other side.
  • Anonymous May 07, 2008
    printer says unlock scanner then power off. I can't find my printer book to find a fix. How do I unlock the scanner?
  • ouedlbir Apr 27, 2009
    deverouiller scanner
Unlock Scanner message
The scanner is locked. to unlock it
1. Press Power to turn the All-in-one off.
2. lift the scanner unit until the scanner support holds it. To the left and beside the scanner support is the scanner lock
3.pull the scanner lock toward you to unlock the scanner.
4. close the scanner lid.
5. power on.
Posted on Jul 13, 2008
  • Ditto van Biljon Jun 11, 2012
    It worked on the x6170 as well.
    Thanx a mil !!!
    Genius:
  • 3,587 Answers
How to replace ink cartridge
I hope you already got your cartridge replaced. If not, here's a link to the Lexmark website on How to Install the Cartridges in the Lexmark X5150. This also applies on replacing cartridges. http://bit.ly/akqijS. Follow the instructions.
In some cases, the ink cartridge carrier won't position itself in the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the white tape in the middle inside the printer. The other end of it is connected to the carrier. Gently slide the carrier to the center. Load the cartridges. Close the cover. Plug the printer back to power source. Hope this helps.
Jun 11, 2010 | Lexmark X5150 All-In-One InkJet Printer
I can't figure out how to replace the ink cartridge. How do you remove the old ink cartridge and put in a new one?
Here's an article in the Lexmark website that will guide you on how to replace the ink cartridges on your Lexmark X5150 printer. Just click on this link: http://bit.ly/bKZ15F. Follow the instructions carefully. By the way, in some cases, the ink cartridge carrier doesn't move in the loading position even when the printer is on when you lift the scanner unit open. If that happens, unplug the printer from the power source. With the scanner unit open, hold the solid white tape you see in the printer. Slowly slide the cartridge carrier to the center for easy access. Replace the cartridges. Close the cover, close the scanner unit. Plug the printer back to the power source. Hope this helps. If you need more assistance, just place a comment so I can get back to it.
Apr 19, 2010 | Lexmark X5150 All-In-One InkJet Printer
Cartridge Error message on our Lexmark X5150
The Lexmark machines are designed to kick out anything it suspects may be refilled. If your old cartridge has bad print nozzles this may be tripping the error. Printers are typically for sensitive with their color cartridges anyway because the manufacturers make more money on the color ones. You can try looking around the settings on the machine and in the printer preferences to see if you can tell it to ignore the ink levels and see if you can continue to print.
Dec 19, 2009 | Lexmark X5150 All-In-One InkJet Printer
I have a lenmarx x5150 printer and have no manual with instructions.How do I use it and replace ink?
  • Press the "Power" button to turn on your Lexmark
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color ink cartridge.
  • Step 4 Remove the new black ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black cartridge into the slot on the left side and push it down. Slide the color cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the cartridge until it clicks closed. Push the purple plastic cover down over the cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
Nov 19, 2009 | Office Equipment & Supplies
Ink
Ensure the All-In-One printer is powered on.
Lift the scanner unit
The cartridge holder will move to the center of the All-In-One
Press down on the cartridge carrier latch to raise the carrier lid.
Remove the used cartridge. NOTE: If you are removing both cartridges, repeat the preceding two steps for the second cartridge.
Remove the protective tape from the back and bottom of the new cartridge(s).
WARNING! Do not touch the gold contact area on the back or the metal nozzles on the bottom of the cartridges
Insert the new cartridges into their respective carriers.
Close the carrier lids so that they remain closed.
Close the scanner unit, taking care to keep your hands out from underneath the scanner unit as it is being closed.The control panel display will prompt you to load paper and print an alignment page. NOTE: The scanner unit must be closed before you can start a new scan, print, copy, or fax job.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 07, 2009 | Lexmark X5150 All-In-One InkJet Printer
Unlock scanner keeps appearing on my lexmark x85 printer
Go to the Lexmark web site here: http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:0:0:0
- In the SEARCH BY MODEL box, type in X85 and click SEARCH
- In the SEARCH THE KNOWLEDGBASE box, type in UNLOCK SCANNER. It will show some instructions for the X83, but that was the little brother of the X85, so should work.
Steve
Feb 23, 2009 | Lexmark X5150 All-In-One InkJet Printer
Hardware error o504
It shows color cartridge is missing because either the cartridge is not well placed or it is not there.
When you try to run the Clean option from the Ink Cartridge menu, the following message may appear: Hardware Error 0504.
To resolve this issue:
  1. Take both cartridges out of the printer.
  2. Switch off the printer using the power button.
  3. Disconnect the power cable from the back of the Lexmark X5150.
  4. Leave the power cable disconnected for 30 seconds.
  5. Reconnect the power cable and switch the printer on again.
  6. Reinstall the cartridges. (Follow the instructions on the LCD screen or refer to the following document: How to Install the Cartridges in the Lexmark X5150)
Jan 11, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark 5150
I went to the Lexmark site and downloaded the manual. Looked for my problem 'Cartridge Error 50c' and found that my color ink was empty. It took some playing around, but that was it.
Aug 11, 2008 | Lexmark X5150 All-In-One InkJet Printer
Ink problems
Your printer an " original ink " manufacture by lexmark printer don't use genirec printer connot detect.
Dec 11, 2007 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
1,315 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
