Question about Acer TravelMate 8104WLMi Notebook
Need to dissassemble Acer 8104WLMi to replace power connector which has broken center pin. Have all screws removed, but seems to be a screw holding top to bottom under keyboard. need to get this screw out. Can't remove keyboard or etc. Redneck
    Sergeant:
  • 226 Answers
Hi, I don't know if this matches your laptop but, try this link.
http://www.mediafire.com/?7vccgcxxbvt
Just click on the long yellow box to start downloading.
I hope this helps
Regards - Anthony
Posted on Feb 01, 2010
Need to dissassemble my sons gator to put in a new gear drive ---how do i get to the gear drive is threre a disassembly guide or diagram for this
remove the center caps of the rear wheels then use a 13mm wrench on each side and loosen the bolts for the rear wheels, when loose remove the wheels and axle, then remove the red pin on the fron of the bed, then the two black pins on the rear of the bed, then lift the bed off, then lift the green plastic panel off this will expose the motors then, disconnect the wires from the motor and remove the two screws that hold the gearbox in place then take the gearbox and motor assembly out then remove the two screws that hold the motor to the gear box
Mar 23, 2011 | Peg Perego John Deere Gator HPX Ride on...
My acer aspire 3680 could not power on by bat and adaptor
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Oct 08, 2010 | Acer Aspire 3680 Laptop
I have an Acer Aspire 7736z which wont charge. Ive already found that the battery connector/battery pin/battery port whichever youd like to call it has snapped off. Any information on how to fix it? where...
DC Jack diagnosis:
Sep 28, 2010 | Acer Computers & Internet
Acer 5570z will not boot up or turn on
It could be one of the following:
1. Bad/damaged power jack.
2. Bad motherboard.
DC Jack diagnosis:
Sep 26, 2010 | Acer Aspire 5570-2067 Notebook
Not working dont get power in motherbord
Sep 23, 2010 | Acer ASPIRE 3680-2022 Notebook
Acer travelmate 5520 will not switch on when powered by battery or ac
Sep 22, 2010 | Acer TravelMate 5520 Notebook
Need to disasseble my subx2 boombox to replace the attenna plug found only 3 screws under the handle and its not releasing
After dissassembling my subxr2, I have come to the conclusion that the issue with my antenna not being detected is in the female contact of the antenna's plug, not with the connector in the box (as I expected to find). I have not yet verified this by trying a new antenna. Here is how to dissassemble the box in any case.
Very carefully, with a small very flat screwdriver, remove the front grille of the unit. There are 8 additional screws set in deep holes that need to be removed. Once done, the front panel will pop right off.
The inside of the case is a mess of wires. You do not need to disconnect them if you do not want to.
Pry the grill off the bottom of the box. Remove the 4 screws that hold in the speaker. This will allow you to move the speaker that is in the main body out of the way.
The antenna jack is _not_ a part of the circuit board. If you look into the box, you will see a rectangular cut-out in the edge of the circuit board. There is a wire with a silver connector that is held in place by 2 screws. Remove those screws and you are now holding the antenna jack.
Feb 23, 2010 | Sirius SUBX1 Universal Plug and Play Boom...
How toi install a new inverter on my acer 4520
before doing anything check your bios settings for the lcd to see if it is a default setting for the brightness of the lcd b/c sometimes it is set to dim to save battery life if that is the case then it should brighten up. also use the FN key on the laptop and adjust brightness before dissassembly.
you need a small bit phillips head screw driver, a small flat head screwdriver.
1. with the flathead remove screw hole covers on the face of the monitor.
2.remove screws with phillip head.
3. carefully pry the face off starting from the top and working each side, once you get to the bottom you may have to pull a little harder b/c of the double sided tape used to help hold it on.
4. with the face off disconnect cables from the inverter board and remove any screws holding it it place. replace with the new one and power on laptop before putting everyting back together to make sure it works.
Aug 28, 2009 | Acer Aspire 4520-5582 Notebook
Power door lock switch replacement
Remove or Disconnect
Door handle trim plate.
  1. .Install or Connect
  2. Electrical connector and door lock cable.
  3. Trim panel by engaging hooks on backside of panel.
  4. Push pin fastener in defroster duct.
  5. Screw from behind lamp assembly.
  6. Courtesy lamp assembly.
  7. Two screws in arm rest.
  8. Arm rest cover plate.
  9. Door handle trim plate.
There May Be A Need to Drill Out RIVETS that Hold Motor in place,. Just Replace with>>MACHINED SCREWS & BOLT'S
  1. Trim panel. See: Doors, Hood and Trunk\Doors
  2. Four tabs retaining switch.
  3. Electrical connector.
Install or Connect
  1. Electrical connector.
  2. Snap switch into trim panel.
  3. Trim panel.
Mar 14, 2009 | 2000 Buick Park Avenue
Acer TravelMate 8104WLMi Notebook Logo
148 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
