Question about HP Pavilion dv9000z Notebook
Intermittent ON/OFF on dv6000 with no display
  • 540 Answers
The rams are defective you have to replace the rams to resolve the issue.
Posted on Feb 01, 2010
Not power on
Your Pavilion DV6000 laptop is the key to your productivity, which is why it is essential that it turns on when you need it. The DV6000 is lighter than comparable models from other brands, and has a large, sharp display. While it has plenty of processing power, the DV6000 can have normal boot problems as well as problems caused by faulty battery packs that were installed in some units. Attempt to troubleshoot the laptop and find out if the laptop is eligible for a new battery pack.
1.Hard reset your laptop if there is no life at all. Unplug all peripheral devices and remove the battery. Unplug the AC cable and press and hold the power button for at least 15 seconds to drain all power. Reconnect the AC cable and hit the power button.
2.Verify that the battery pack is on the recall list if the laptop powers up without it. Fill out the form on the battery pack recall website (http://bpr.hpordercenter.com/hbpr/). You will have to input the serial number of the battery pack as well as a location to ship the replacement battery if you are eligible.
3.Hold the AC cable where it plugs into the laptop and wiggle it while hitting the power button one time. LEDs that come on and off intermittently indicate a faulty power cable. Order a replacement power cable through HP or a third-party vendor.
4.Write down any visual or audio error codes such as LEDs blinking or unusual beeping. The error sequence will be helpful when talking to an HP support person.
I hope this may help your concern.
Jan 22, 2011 | HP Pavilion dv6000t Notebook
My HP Pavilion DV6000's display got damaged. i wanna knoe how mch appv it will cost if i get it repaired. my laptop is not under d guarantee period. plzz rply ASAP.
Finding the replacement is easy;
http://www.amazon.com/Glossy-Laptop-Screen-Pavilion-DV6000/dp/B002LC7C3I
Replacing is tough
Aug 14, 2010 | Computers & Internet
My dv6000 dont start . i have black screen with one long beeb and two short beebs
That code means that the display adapter is bad. Replace the display card.
Mar 23, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Display on HP DV6000 is scrambled.
Reseat the LCD cable on the laptop end and also behind the LCD panel. Since it working on external monitor the graphic card is working fine.
Oct 14, 2009 | HP Pavilion dv6000z Notebook
Your problem is the screen itself, sounds like your graphics chip is fine by being able to use an external monitor. Change out the display, but also check the flat data cable on the back of the screen and make sure it just didn't slip out of the socket.
Display is intermittent
hi,
the problem is with the nvidia gpu. the solder on the bga balls is unleaded and does not have the flex of leaded balls. the gpus needs to be heated on an ir solder station with preheater to 210 degree C for 30 seconds. this should cure it. if it still does not work, the gpu needs to be reballed. you can obtain replacement balled gpu from ebay. you do need to prep board correctly and use proper ir solder station to do this.
Jul 28, 2009 | HP Pavilion dv6000 Motherboard
HP Pavillion entertainment dv6000 - Power goes
it is problem your laptop ram is rough position or demage change it then your laptop is active
Jul 17, 2009 | Computers & Internet
Plz help my laptop has no display dv6000
More info please. Does it show a boot screen first then go blank? Does it beep when you turn it on? Has your display flickered recently or have the colors shifted?
Jan 04, 2009 | Computers & Internet
HP Pavilion dv9000z Notebook Logo
155 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
