Question about Zodiac Baracuda G3 Automatic In Ground Pool Cleaner
My baracuda G3 stop working is not pulsating and therefore not moving. I checked the suction and the hoses even the diaphram everything looks ok.
Look inside, replace the clear tube inside of the unit.
Posted on Oct 09, 2012
  • 106 Answers
If you have suction at the bottom of the cleaner, there has to be a problem with the diaphragm. I would remove it and recheck.
Posted on Feb 02, 2010
My g3 is not working, took it to pool store and they replaced diaphram, but still not hopping or moving, suction is good but now movement.
There are a couple things to check with these pool cleaners when they stop moving. Use Pool Pulse to insure proper flow through the cleaner. Clean baskets and filter to ensure that you are not clogged. Check hose sections for leaks by lifting each section above water.
Apr 09, 2011 | Zodiac Baracuda G3 Automatic In Ground...
My barracuda is not moving and i fell is not pulsating eather why?
If your pool cleaner is moving slowly and not pulsating, there are a couple things that you will want to check and/or adjust. Make sure that the main drain is closed. It is a common problem with these pool cleaners not operating correctly if the drain is not closed. Use your flow gauge to make sure that there is adequate flow. Poor water flow through the cleaner can cause these problems. Backwash the filter and clean out any skimmer baskets. Clogs can cause loss of suction and prevent movement. Make sure that the diaphragm is not damaged. Check for hose leaks and air entering the line at all connections.
Apr 02, 2011 | Zodiac Baracuda G3 Automatic In Ground...
I have the zodiac g3 i hear it pulsating but i looks like it has too much suction and it gets stuck and does not move how do i adjust it
You need to use your pool cleaners flow gauge to test for proper flow. Keeping the hose submerged, attach the gauge to the hose and turn on the pump. The red indicator, when viewed from the side, should be at the 3 setting. If the flow is too low, check and clean the pool filter and baskets. If the flow is too high, verify that valves controlling the suction lines are in the correct position, change your flow setting on the Flow Keeper valve, or open the main drain slightly.
Jul 03, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Baracuda G3
Check your pool cleaners hose to make sure that it is not becoming tangled. Storing the hose in a coiled position will cause this. If it is not moving and it is not the hose, you could have a leak in a connection somewhere. If the cleaner is getting adequate suction, it should be moving. Try adjust the hose weights to make sure the cleaner is at a 45 degree angle to the pools floor.
Jul 06, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Has good suction but wont move
Is there a tile stuck in the condom shaped diaphram when you look into the cleaner from underneath. Could be any kind of rubbish make sure you look deep inside as debris gets stuck right at the top.
This diaphram is removable check also that it does not have a hole in it.
Cheers Bazzard
May 08, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
My zodiac g-3 just does not move .I have a new filter cartridge.I have good suction to the hose.no visible obstructions.Please help.
Check suction on bottom of vac. You may have suction where hose plugs into wall but not into cleaner. If there is suction there, than diaphragm most likely has a rip or tear in it. If no suction on bottom of cleaner, than look for a broken hose or an obstruction somewhere in the hoses.
Mar 21, 2010 | Zodiac Baracuda G3 Automatic In Ground...
No movement with my g3 baracuda
A small rip or tear in the diaphragm will cause that problem. When you put your hand over the mouth you are creating more suction to the diaphragm. Replace diaphragm.
Mar 01, 2010 | Zodiac Baracuda G3 Automatic In Ground...
G3 is not moving, but has suction? Please advise.
I had the same problem. come to find out there was somehting stuck in the diaphram. (a piece of mulch). Once I removed it, everything worked fine. Take your Barracuda apart and check the diaphram for blockage.
Mar 21, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Zodiac Baracuda G3 Automatic In Ground Pool Cleaner Logo
1,791 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
