Question about Toshiba 53H71 53 in. Rear Projection Television
When you turn the tv on the pic is sguiggly for a few mins.
When you turn the tv on at first aftera few hours of sitting. the pics is sguiggly. it does this through out the whole pic. but it clears up starting at the bottom first then gomoves to the top but the top does not clear all the way up. you see the sguggly in words at the top. it does do the same thing on the meun display and opther channels or on the dvd player also. thank you if you can help me. thank you.john
  • 2 more comments
  • type2joe Mar 17, 2008
    I have a 57 in Toshiba rear projection tv with the same issue. It started out with small squiggly lines at the top of the tv, but it has spread to the entire tv within weeks. It takes about 15 minutes for the TV to become viewable. Mine was purchased in 2003 from HH Gregg, where I purchases 5 year extended warranty which had expired 2 weeks ago...
  • Anonymous May 13, 2008
    I am having the same problem only it clears up in about 4 mins.
  • desertdea Nov 16, 2008
    I also have the same problem...I'm new to FixYa, so when the original poster rates it "Fixya" as it says at the bottom, does that mean it worked? How much does this fix cost and what is the best place/way to get this done?
  • allwayzlooki Dec 17, 2008
    if i hook up a blu ray dvd player will that come in clear similar to high def channels on cable, i am waiting for digital tv conversion and hoping i can salvage the tv because i have no problems with digital or hd channels
    Genius:
  • 1,694 Answers
Bad Hyper module = No longer available = rebuild only by qualified tech or send PTS Corp.....Toshiba part # 23786198
..............T.
Posted on Feb 19, 2008
Screen keeps cracklin then picture goes off its doing it evey few mins i have to turn it off then back on again to get pic back
This is the same problem I've been having. My display died a few days ago. Repair guy said walmart will end up replacing it or refunding my money. had this tv for just over a year
Feb 23, 2010 | Philips 47PFL7403D 47 in. LCD TV
Been gone 3 months, came home turned on tv and had a pic for 5 min,it went out, sound stays on and can change channels but no pic. Turned on again after leaving set off for an hour, again, sound but no...
Had the same issue sound but no picture, try wiggling the connections to the back of the tv, if that does not work try using a different hook-up, I ended going from the component jacks to the DVI hook-up and this took care of the problem, hope this helps!!
Dec 28, 2009 | Panasonic PT-53TW53 53" Rear Projection...
1. After being on for 1-2 hours the pic goes out and turns to "the green screen of death". Pic will not come back on unless TV cools for 30+ min. 2. When I switch from DVD source to cable TV source the pic...
You got an issue with overheating.  TV is designed to shut off to protect electronic components if TV overheats.  Take it to the shop and have them open this thing up to identify the faulty circuit.  Also, check to make sure your not blocking the heat vents.
Nov 11, 2009 | Hitachi 70VS810 70" Rear Projection HDTV
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
Cant see picture on my tv screen on cable mode vcr ok
its usually your cable box or sat box. reset by unplugging box let sit for 10 min.
Jun 04, 2009 | Televison & Video
Set dont like to be cold
Resolder all pinns on FBT on the Deflection board.
Jan 16, 2009 | RCA D61W20 61" Rear Projection Television
When set cold it doesnt have pic
check capacitors cp150 cp114 cp120 if cp150 is puffed up on top it is Bad so replace other 2 as well.2200uf 16v and Two 220uf 35v.
Jan 15, 2009 | RCA D61W20 61" Rear Projection Television
DCT6412 DVR Box
When that happens its most likley you had a power outage and the box reset.  Well kinda reset but not all the way.  You can unplug the power and wait about 10sec and plug it back in and wait a few min to a few hours, and If that doesn't work get a new box.
Oct 04, 2008 | Arris DCT6200 DTV Receiver
No pic but have sound
CHECK C268 (22 UFD 50 V) OFF C OF Q215 V-PROTECTOR ON THE SIGNAL PCB
Mar 22, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Help with tv
does your tv make noise the bearing usually go out on those color wheel sets so do the lamps on that model if you are confident go for a repair at home here is a shortcut http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/ if this is the year click the link above
Feb 16, 2008 | Televison & Video
Toshiba 53H71 53 in. Rear Projection Television Logo
69 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
