Question about Kenmore 63672 Convection/Microwave Oven
How can i replace a schneider microwave oven light bulb - the light which comes on when the oven is operating?
Take the outer casing off, just remember there is one security screw from the eight you take out. once you have done that then there is a metal sheild around the bulb holder 2 further philips screws to take then just replace the bulb and re assemble, note the cover is like tongue and groove to get back on so make sure you line them up before screwing back together.
Posted on Jul 03, 2011
  • Mal Mitchell Nov 01, 2011
    Not quite as easy as stated but essentially a job anyone can do with the right tools. Screws on my casing required a Torx security driver and both philips and pozidrive screw drivers.two screws under the casing plus one security screw and three others. In my case the bulb had vibrated loose and was replaced. The two screws holding the bulb shield may not need to be removed as the bulb is held by two tags that can be straightened to allow access. Once replaced all screws put back in their correct order making sure that the ****** and groove cover arrangement is secure. Simples.
Light does not come on
Lamp replacement involves removal of the cabinet.
Mar 26, 2014 | Emerson MW8987B/W Microwave Oven
Interior light bulb burned out
make this test and fix it. GOD BLESS YOU
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Oct 31, 2013 | Samsung SMH8165STE Microwave Oven
Microwave heats, but the turntable and lights don't work
see the chart for light 1)
  • Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  • Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction
  • 2) the carousel inside your microwave won't turn when you run it, the small motor that operates it may be broken.
    God bless you
    Sep 30, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
    The lights wont come on
    test this and fix it. God bless you
    Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#6#ixzz2aavxew74
    Jul 30, 2013 | Microwave Ovens
    Light bulb
    follow this steps and fix it. God bless you
  • Jul 29, 2013 | GE JES1384SF Microwave Oven
    Whirlpool oven g2p 62f ss
    see the diagram attached, and fix it. God bless you
    Jul 08, 2013 | Neff Microwave Ovens
    HOw do i replace the inside bulb?
    Hi. I just told you, there is no acces for the bulb in microwaves. Bulb replacement is not supposed to be a user level maintenance operation. You will need to remove the microwave outer cover to replace the bulb.
    Here again my instructions: How do I replace light bulb.
    Regards.
    Apr 08, 2010 | Jenn-Air JMC9158AAS Convection/Microwave...
    Replace light bulb on the Neff H7871 combined oven and microwave.
    The bulb is positioned at the top of the oven, accessible only from the outside. You'll need to pull off the top and bottom trim strips, remove the bottom trim strip locators, remove 2 fixing screws from the left edge of the oven (with door open), and the 2 fixing screws from behind the top trim strip. The oven should then just slide out. You only need to pull it out 6 inches or so to gain access to the bulb cover. You'll need a T20 driver to remove the cover, then the bulb unscrews as it has an SES fitting. Bob
    Mar 17, 2010 | Neff H7871 Convection/Microwave Oven
    Replacing lightbulb in Sharp R953M combi microwave oven
    most microwave ovens built in the last 20 years do not have an
    access panel to the light bulb. you must remove the screws on the back of the microwave that hold the outer sleeve in place.
    Then pull upward and backward on the sleeve to disengage it
    from the front lip of the chassis. the light bulb should be close to the front of the microwave behind the control panel. Some lights
    are not unscrewable from the socket, but the socket and bulb
    come as an assembly.
    Mar 26, 2008 | Microwave Ovens
    Hotpoint RVM1425BA-003 Microwave Oven Stovetop Light Does Not Work
    The problem is almost certainly on the control panel, which we repair nationwide for $39.95 postpaid.
    This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
    This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
    If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
    disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
    Oct 14, 2007 | Hotpoint RVM1425 Microwave Oven
    Kenmore 63672 Convection/Microwave Oven Logo
    355 people viewed this question
    Top Kenmore Microwave Ovens Experts
    William Miller
    William Miller
    Chuck
    Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
